Go to Post Welcome to FIRST, the place where you can be competitive in a team. Here people can learn more in one year of FIRST than in four years of high school. - dude__hi [more]
Unread 06-28-2012, 10:38 PM
2185Bilal's Avatar
2185Bilal 2185Bilal is offline
Driver, Ld. Programmer, Electrical
AKA: Bilal Majeed
FRC #2185 (Ramazoidz)
2185Bilal will become famous soon enough
Post Different IDE
Can you program and compile the frc robot code in another IDE except for Windriver, may be like eclipse
RAMAZOIDZ
2009 Toronto West Regional - Regional Winners
2009 Waterloo Regional - Regional Winners
Unread 06-29-2012, 09:08 AM
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Re: Different IDE
Windriver is actually a proprietary offshoot of Eclipse. If you switch to Java, Netbeans has all the FRC tools built into the special plugins you install (And if you really want to you can probably finagle a workspace in Eclipse to give proper compile errors for Java ME + WPILib java code until you want to deploy.)
Unread 06-29-2012, 09:43 AM
Data Nerd
FRC #0079
Re: Different IDE
I currently use my text editor of choice (I'm partial to TextMate but Chocolat is starting to replace it) and a UCPP make file. I then simply ftp the code to the robot.
So, yes, you can. It just requires a little more set up time. I'm currently looking into using the alternative toolchain that uses GCC and DOESN'T require me to have Wine installed. If I can get that working it'll be the last step before I can dump the build process off to a remote machine that pulls from a git repo.
Unread 08-15-2012, 10:53 AM
arthurlockman's Avatar
arthurlockman arthurlockman is offline
Team Captain
FRC #0172 (Northern Force)
arthurlockman is an unknown quantity at this point
Send a message via AIM to arthurlockman
Re: Different IDE
I've gotten building and uploading working in Sublime Text 2. I've actually made a little build script that relies on UCPP. Here it is, try it out. It might do what you want.
Arthur Lockman
Twitter: @arthurlockman
a.rthr.me
Unread 08-15-2012, 12:26 PM
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
Re: Different IDE
Check out this thread: Universal C++ Project - C++ programming for Linux, and more.
Team 980 is using the environment developed by nikitakit. Loading code is much faster than in WindRiver's environment.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
