Go to Post 1 alliance wins a given tournament but all teams teams have a chance to define, chart, and create their own success. - PayneTrain [more]
Thread Tools Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
  #46   Spotlight this post!
Unread 09-01-2012, 02:01
TSIMFD
AKA: Sean Lavery
FRC #1712 (DAWGMA)
Re: Air Defense System
Did a mentor just seriously suggest that hitting a rapidly moving target by using the provided control and sensors in a FRC environment would be easier than hitting a stationary target? Then rule out the strategy because of the safety concerns regarding a foam ball?
Really?
  #47   Spotlight this post!
Unread 09-01-2012, 02:13
Kpchem Kpchem is offline
FTA, CSA, and all things technical
AKA: Kevin Emery
Kpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to beholdKpchem is a splendid one to behold
Originally Posted by tcjinaz View Post
And if I am sitting in the opposition's key, I'm at 84in for the sensor, shooter or both.
If you are in the opponent's key, then you are on the carpet on your alliance station's end of the court, and therefore you can only expand to 60 inches as per rule G20.
[G20] (emphasis mine)
"Robots in contact with the carpet on their Alliance Station end of the Court are limited to 60 in tall. Otherwise, Robots are limited to 84 in tall.
Violation: Foul; or Technical-Foul for repeated or continuous violation."
FRC 360: 2008-2011
Full-time Volunteer: 2012 - forever
  #48   Spotlight this post!
Unread 09-01-2012, 02:49
theprgramerdude theprgramerdude is offline
WPI Freshman
AKA: Alex
FRC #2503 (Warrior Robotics)
theprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud oftheprgramerdude has much to be proud of
Originally Posted by gyroscopeRaptor View Post
Also, pushing the balls up may likely push them out of the court, incurring a foul under <G13>.
This makes any uber-fan idea flawed, IMO.
Completely feasible, IMO. It's not a matter of generating tornado-strength winds here, it's simply about generating a directed draft that, for the fraction of a second that the ball is in the jet stream from the fan, apply a force that alters it's momentum to the side by a tiny amount. By the time the ball reaches the next, it'd have moved enough to possibly cause a missed shot.
A similar idea is with making space objects miss Earth; a small force early in flight can cause a huge gap later. For this, the fact that the shots need to be rather precise means that the fact that time in flight is short wouldn't matter if a decent amount of force is applied.
The balls weight will prevent any serious deflection, but a draft from a decently-sized fan (20"?) powered by a few motors should provide quite a bit of push necessary to move anything in it's way.'
Edit: And a brilliant idea just occurred to me: Why not have an active targeting system combined with the air knife idea?
I.E. A giant fan is always running when needed, producing a huge draft, which is then directed into a controlled funnel system that automatically turns towards and directs the air into the path of inbound basketballs. It'd have the force bonus of a funnel while being capable of constantly hitting the ball, drastically increasing the impulse given to the ball, changing it's course.
Attending: MN Duluth Regional
  #49   Spotlight this post!
Unread 09-01-2012, 06:45
Ninja_Bait's Avatar
Ninja_Bait Ninja_Bait is offline
Former Prez of Making Things Go
AKA: Jake Potter
FRC #0694 (StuyPulse)
Ninja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond reputeNinja_Bait has a reputation beyond repute
NASA historically doesn't try to hit other things. Other Agencies (SDI, <litany of US DoD orgs> et al) have tried and succeeded to do so, repeatedly.
That's what they do all the time. They hit Mars, the Moon and at least two (?) asteroids with little probes. And the planets are slow and much bigger than the probes, and it's STILL not easy.
As for deflection, I think everyone is overestimating the effects of "tiny" disruptions. If I aimed and shot a ball intended for the middle of a hoop, it has more than 5 inches of tolerance in any direction. If it hits the rim or backboard first, there is still a good chance of it scoring. You can't push it far enough.
You can't fix something that isn't broken... but you can always break things that aren't fixed!
  #50   Spotlight this post!
Unread 09-01-2012, 07:35
staplemonx's Avatar
staplemonx staplemonx is offline
The Idea Guy
AKA: JJ Biel-Goebel
FRC #1389 (The Body Electric)
staplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond reputestaplemonx has a reputation beyond repute
I like the idea and in general you only need to impact the trajectory of a ball by a few degrees. We are putting this on our want list and may get to after we bag the robot.
crazy engineer
www.jjbiel-goebel.com
helping team 1389
http://team1389.com/
  #51   Spotlight this post!
Unread 09-01-2012, 07:56
CliffyTheGamer's Avatar
CliffyTheGamer CliffyTheGamer is offline
FRC #4070
CliffyTheGamer is on a distinguished road
I love the idea.
"One has to look out for engineers they begin with sewing machines and end up with the atomic bomb"
  #52   Spotlight this post!
Unread 09-01-2012, 23:11
tcjinaz tcjinaz is offline
Tim
FRC #3853
tcjinaz has a spectacular aura abouttcjinaz has a spectacular aura about
Really?
I'm a software guy; are we ever serious about hardware? And I didn't say it was easier; but it is a defense mechanism with offensively capable hardware.
Actually, I think I ruled the idea out first on rule <G13>, which has a safety bent to it.
And in response to another post, the key is not carpet, it is HDPE. So if my 'bot is entirely in the opponent's key, it is not on carpet, and can extend to 84inches.
Software Mentor
3853 Pridetronics[
  #53   Spotlight this post!
Unread 09-01-2012, 23:28
Josh Murphy's Avatar
Josh Murphy Josh Murphy is offline
AKA: Josh
FRC #0051 (Wings of Fire)
Josh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond reputeJosh Murphy has a reputation beyond repute
Actually, only the top of the key is made of hdpe, which is protected if your opposition is touching it. The rest of the key is carpeted.
-Josh Murphy-
  #54   Spotlight this post!
Unread 09-01-2012, 23:37
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #0020 (The Rocketeers)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
The entire key is HDPE. The semicircular velcroed HDPE area is the key. This does not include the rectangular carpet area outlined by the "purely for decoration" tape.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
  #55   Spotlight this post!
Unread 09-01-2012, 23:45
AKA: Josh
The key in basketball is generally the entire painted area under the basket. The semi-circle is commonly called the "top of the key". My point here is that if they plan to park on the key and extend, all an opponent has to do is drive into them and they would incur a technical foul.
-Josh Murphy-
  #56   Spotlight this post!
Unread 10-01-2012, 11:37
Rocketeeringer's Avatar
Rocketeeringer Rocketeeringer is offline
Team Role: Communications
Rocketeeringer is on a distinguished road
depends, rules G28 and G44 together protect robots in the key and alleys but G45 protects robots from others trying to intentionally incur a penalty
  #57   Spotlight this post!
Unread 28-06-2012, 23:48
Tim
FRC #3853
For those of you who doubted my SAM suggestion:
http://www.ustream.tv/recorded/21334084
Software Mentor
3853 Pridetronics[
  #58   Spotlight this post!
Unread 29-06-2012, 14:53
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
For those who just want the punch line, begin watching at 38 seconds. This is truly epic.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
