Go to Post I believe that your career should support your dreams. - Tytus Gerrish [more]
Unread 29-06-2012, 18:04
theNerd's Avatar
theNerd theNerd is offline
FRC #3329 (Cam Bots)
Rookie Year: 2110
theNerd is an unknown quantity at this point
Compiling Robot Code
OK, so I'm on a Linux box (Fedora 17 which i would recommend to anyone) and am writing an API for FRC robots (see here: https://github.com/theNerd247/JavaCSVReader) and need to compile the code I write using the FRC API and NOT the standard Java SE 7 API.
I have not been/don't have/DO NOT want to use ANT for many and various reasons. Instead I have a couple of BASH files written to replace all of my ANT needs, and they use the javac and javadoc tools etc...
I am mainly using the sources found in the java.util package, but I want the one that the robot uses and not the SE 7 one. Help?
Much thanks.
