Go to Post These teams aren't elitists, but they sure are elite. - [more]
Unread 02-07-2012, 16:57
gyroscopeRaptor's Avatar
gyroscopeRaptor gyroscopeRaptor is offline
Registered ConfUser
AKA: Mark McGivern
FRC #3633 (Catalyst)
gyroscopeRaptor has a spectacular aura aboutgyroscopeRaptor has a spectacular aura about
Spikes not working (Solved)
We are working on the robot for the 3rd of July parade and our spikes are not working. We are using one to control a compressor and one to activate a valve. We had the spike that was controlling the compressor working, but it has stopped working oddly. It has an orange light. We have tried using two other spikes for this and the valve spike, but the other two only show an orange light and do not react.
edit1: The lights on the sidecar change.
Unread 02-07-2012, 17:04
BigJ BigJ is offline
AKA: Josh P.
BigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond reputeBigJ has a reputation beyond repute
Re: Spikes not working - URGENT
A spike showing an orange light means it's not getting signal. Did you change your code?
See also: a search for "spike orange light"
http://www.chiefdelphi.com/forums/sh...orange+lig ht
http://www.chiefdelphi.com/forums/sh...orange+ligh t
Unread 02-07-2012, 17:07
Jon Stratis's Avatar
Mentor, LRI, MN RPC
FRC #2177 (The Robettes)
What is the Digital Sidecar (DSC) doing? There are two small LEDs next to each of the relay ports that should light up to show which direction it is signaling.
If those aren't turning on, check the following:
- Code
- Power LED's on the DSC - all of them should be lit up
- Try replacing the DSC.
If they are coming on but the Spike isn't responding, try the following:
- Get a multimeter and probe the DSC output. You should be able to see the pins switch voltages with the lights.
- If the pins look good, plug the PWM cable back into it and probe the other end of the cable, where it plugs into the Spike.
- If the cable looks good, check how you're inserting it into the spike. Make sure it goes in straight, push a little bit to make sure it sits fully, and ensure ground is on the correct side (check that it matches ground on the DSC!).
Unread 02-07-2012, 17:08
cgmv123's Avatar
cgmv123 cgmv123 is offline
FRC RI/FLL Field Manager
AKA: Max Vrany
FRC #1306 (BadgerBOTS)
Check your fuses.
Since the robot doesn't have to be competition compliant you can replace all your fuses with auto-resetting breakers. The same ones that go into the power distribution board.
Also make sure you have the spikes plugged into the relay portion of the sidecar, not the PWM/Servo/Jaguar/Victor portion.
Unread 02-07-2012, 17:11
Mentor, LRI, MN RPC
Also, if you can make pictures of the important parts available - PDB, DSC, Spike - while in operation (aka LED's on the DSC lighting up when it should be triggered), it could help diagnose. Ensure you have things properly labeled, so we know where the power from the PDB is coming from, which side of the Spike it's going into (double check this, don't assume!), which port each spike is connected to, etc. Something could jump out at us that we wouldn't think to tell you just from a problem description.
Unread 02-07-2012, 17:15
O-H
FRC #0048 (Delphi E.L.I.T.E.)
Are the PWM cables running between your Spikes and the Relay Outputs on the Digital Sidecar fully seated? Are they oriented correctly? For red/white/black cables, the black wire should correspond to the (-) pin on the Sidecar and the pin labeled "B" on the Spike.
Unread 02-07-2012, 17:23
Registered ConfUser
AKA: Mark McGivern
Smile Re: Spikes not working - URGENT
Thanks to everyone for your advice. It turned out that the PWM cable was not working properly. Who knows how many times it has been pushed in and out over a year and a half? Thanks again.
Unread 02-07-2012, 18:31
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Thanks to everyone for your advice. It turnd out that the PWM cable was not working properly (who knows how many time time it has been pushed in and out over a year and a half). Thanks agian.
This is exactly why I Hate PWM's. They always break or fall out. we actually started hot glueing ours in this year. but they break all the time, so idk if its worth it...
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 02-07-2012, 18:43
CalTran's Avatar
CalTran CalTran is offline
MST Rolla Senior
LIKE. We did the exact same thing. They had somewhat less breaking, but turned into an absolute pain for on the fly changing of the victors/jags.
Academic Student (Forever)
Unread 02-07-2012, 19:38
Registered ConfUser
AKA: Mark McGivern
We epoxied our cables in on our robot this year but the connectors are becoming worn and we had to scavenge cables from 2011 and 2012. They'll be epoxied later tonight. Thanks to everyone, and we will have pictures and video of our EOD robot after the parade.
Unread 02-07-2012, 19:41
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
How does the hot glue affect the device? Any downside other than having to clean out the glue in order to replace the cable?
The views expressed are mine and should not be construed to represent the views of anyone else.
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
We've had some issues seating the PWM connectors but after they are seated. They are strain relieved and then hot glued. Never touched them since Our FIRST regional.
Rich, its really easy to just take off the hot glue, like 5 minutes worth of work.
-RC
R.C.
MadTown Robotics Team 1323
Unread 02-07-2012, 20:09
Registered ConfUser
AKA: Mark McGivern
There may be some residue from the adhesive. We used epoxy, and there is definitely some residue that may have made it harder to reseat and that caused this problem to begin with. That said, the upsides (keeping a compressor working through a match vs. having it unseated and fail) far outweigh any downsides, and 99.9% of situations the cables should be glued or epoxied into their seats on both ends.
Unread 02-07-2012, 22:12
ratdude747's Avatar
Official Scorekeeper
AKA: Larry Bolan
Another reason I like CAN... If the cable works, it will work virtually forever... Even if somebody messes up and snaps a clip, all that is needed is another clip which can quickly crimped on. Not to mention that you can never get a cable backwards and aside from the left black Jag port of the first Jag (serial CAN), you cannot get the wrong port ever. Now if they only made competition legal CAN relays... that IMHO would be awesome.
Unread 02-07-2012, 23:06
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
We use clear silicone bathroom caulk (it comes in a nice toothpaste-ish tube) for all PWM and other signal wire connectors, plus black duck tape on the radio. It's fairly sticky, and fairly easy to remove.
Kettering Motorsports
