Go to Post I enjoy the brainstorming that's going on here, you guys out think me most of the time. Keep it up. - fnsnet [more]
Unread 03-07-2012, 20:16
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Re: CIM Motor Failure
Originally Posted by sanddrag View Post
Yep, been there done that. Not a continuous duty motor, not even close.
The CIM motor data sheet indicates that the motor is designed for intermittent duty. Its specified test load is 64 oz-in running from a 12V supply, which corresponds to 4320 RPM on the motor's speed-torque curve -- the mechanical load is about 204 Watts and the motor is dissipating about 120 Watts as waste heat (in its armature windings and brushes) at this load.
Its specified test cycle (for endurance) is:
3 minutes at the above rated load, counterclockwise, followed by
2 seconds off, followed by
3 minutes at the above test load, clockwise, followed by
30 minutes off,
and then the cycle repeats, until the motor has run 1000 cycles.
So the motor is designed to run for about 100 hours at 200 Watts mechanical output from a 12V supply, with 16% duty (i.e., 30 minutes off for every 6 minutes running). Exceeding this load and duty will overheat the motor. Seems like that is what Al's team did.
Richard Wallace
since 2003
Last edited by Richard Wallace : 03-07-2012 at 21:13. Reason: corrected losses; motor is drawing 27 Ampere at the specified test load
