#15
Re: 2012 IRI Scouting
STINGER OUT - Stinger of any kind applied outside of frame perimeter (i.e. http://www.youtube.com/watch?v=1yEcf...ailpage#t=268s)
STINGER IN - Stinger of any kind applied inside frame perimeter (i.e. http://youtu.be/Ar6CMCwlW5k) BRAKES - Braking/stay put system - mechanical brakes, pneumatic pad onto bridge surface, etc. PID BRAKES - Deserves its own category if no other mechanical braking present, as control stops once match ends. OVERHANG(+) - Can hang at least 12" of robot off the bridge. Use OVERHANG+ if you have additional features to secure the bot that don't fall into any other category - wood blocks, wedges, tilting arm to affect COG :-), etc. 16 ...Swerve.. 25 ...Long..Stinger In..Brakes 27 ...Long.. 33 ...Wide..Stinger Out 45 ...Wide.. 48 ...Long..Stinger In..Overhang+ 51 ...Wide..Stinger In 67 ...Wide..Stinger Out 68 ...Wide.. 71 ...Swerve.. 111 ..Long..Stinger In..Brakes..Overhang+ 118 ..Wide..Stinger In 125 ..Long..Stinger Out..Overhang+ 148 ..Wide..Stinger In 192 ..Long.. 217 ..Long..Stinger In..Overhang+ 233 ..Long.. 234 ..Wide.. 245 ..Wide.. 269 ..wide.. 292 ..wide.. 330 ..Long..Stinger In 340 ..Long..Stinger In..Overhang+ 341 ..Wide..Stinger In..10" Hang..PID Brakes 359 ..Long.. 379 ..Long.. 399 ..Wide.. 447 ..Long..Overhang 461 ..Long..Overhang 469 ..Square..Stinger Out 503 ..Mecanum.. 548 ..Long..Stinger In..Overhang+ 573 ..Long.. 624 ..long..Overhang 744 ..Long..Stinger In..Overhang..Brakes 772 ..Long..Overhang 781 ..Long.. 829 ..Wide..Overhang 868 ..Mecanum.. 907 ..Wide..Stinger Out..PID Brakes 973 ..Swerve..Stinger Out..Brakes 1023 .Wide..Stinger Out 1024 .Wide.. 1114 .Long..Stinger In, PID Brakes, Overhang+ 1538 .Long..Stinger In..Overhang 1592 .Wide.. 1640 .Swerve.. 1676 .Long..Stinger In..Overhang 1714 .Wide.. 1718 .Wide..Stinger Out..Brakes 1730 .Wide.. 1732 .Wide.. 1741 .Mecanum.. 1902 .Long.. 2054 .Long..Stinger Out 2056 .Long..Stinger Out 2168 .Long..Stinger In..Overhang 2194 .Wide.. 2337 .Long..Stinger In..Overhang..Brakes 2590 .Wide.. 2614 .Long.. 2826 .Long..Stinger In..Overhang+..Brakes 2834 .Wide..Stinger Out 2949 .Wide..Stinger Out..Overhang 3098 .Wide..Stinger Out 3138 .Long..Stinger In..Overhang 3193 .Long..Overhang+ 3310 .Long..Stinger Out..Overhang+ 3322 .Wide..Stinger Out 3357 .Wide.. 3940 .Wide.. 3947 .Long.. 4334 .Wide.. |
