Go to Post Any FIRST pit is my favorite because that means I'm enjoying a FIRST competition so I'm just plain happy anyways. - Koko Ed [more]
Unread 07-07-2012, 19:09
Re: Turning LEDs on/off
Originally Posted by rsisk View Post
I have an LED wired to the digital side car power and ground pins. I want to be able to turn it on/off programatically, but it always stays on. I am using Labview to open a digital output sand setting it to false, but the LED is always staying on.
I have the jumper on the DSC's port.
What am I ding wrong? Should the LED be wired to the ground and signal pins?
The power stays on. Only the signal turns on/off. Whether or not the LED will illuminate when you connect it between signal and ground depends on how much current the LED requires to illuminate, and how much current the signal can source. What's the part number of the LED?
Unread 07-07-2012, 21:07
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
I think you are right when you say that you should wire to signal and ground, just don't mix up positive and negative on the LED, they make a nice pop sometimes, you can also run LEDs on spike relays if they are 12 volt
Edit: Also the signal may not carry enough current to power LEDs in which case you should use a spike
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 07-07-2012, 21:35
rsisk's Avatar
rsisk rsisk is offline
The GURU Channel
AKA: Richard Sisk
FRC #2493 (Robokong)
LEDs from SuperBrightLED
Qty | Product / Options | Price/ea |
12 | RL5-G7532: 5mm Green LED | $ 0.54 |
RL5-G7532: Green LED
Resistors from www.MOUSER.com
299-82-RC
299-82-RC
82ohms
Assuming the flat side of the LED is the negative side.
Going to try the ground/signal setup now.... thanks
The views expressed are mine and should not be construed to represent the views of anyone else.
Unread 07-07-2012, 21:57
Why did you select 82 ohm?
Unread 07-07-2012, 23:26
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
I used the calculator linked below to determine the resistor. Forward current was 20mA, source voltage was 5v and the forward voltage was taken from the LED specs.
http://led.linear1.org/1led.wiz
When I switched to the signal tonight, there was no light when I set the DIO to true or false. When the LED is on power and ground, it comes on
Unread 08-07-2012, 00:40
Sounds to me like the output impedance of the DIO signal line is too high to provide enough current to light the LED (as mentioned in my earlier post).
Disconnect your LED circuit and put a voltmeter (a cheap $10 one will do) between signal and ground at the DIO output. Flip the DIO true/false and confirm that you are getting 5 volts and zero volts.
Now connect your LED circuit (leaving the voltmeter connected between signal and ground). My guess is that you will no longer see 5 volts. The load from the LED acting on the impedance of the signal source will drop the voltage below that necessary to provide the current to light the LED.
Unread 08-07-2012, 00:48
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
Now connect your LED circuit (leaving the voltmeter connected between signal and ground). My guess is that you will no longer see 5 volts. The impedance of the signal source will drop the voltage below that necessary to provide the current to light the LED.
I'll check as soon as the show is over (the robot is part of the play Something's Afoot). If that is the case, what is the solution?
If I use a spike to control it, I assume I will need a different resistor to handle a 12v input? Or I run 5v throught the spike?
Unread 08-07-2012, 01:00
Instead of using the signal as a power source to drive the LED, you could use the signal to control a transistor which switches the DIO power line.
I'll draw a sketch and post it here in a few minutes.
Unread 08-07-2012, 01:08
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
Very cool thanks Ether.
Unread 08-07-2012, 01:19
Something like this.
edit: corrected resistor value
Unread 08-07-2012, 03:46
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
When I buy the FET, is there anything specific I need to look for? Probably going to Radio Shack to find one tomorrow. If not available then will probably go to mouser.
Unread 08-07-2012, 04:37
Your application is really light load and low voltage, so most FETs will work fine. Here are the general things you look for:
Type: Your options are "N" or "P" channel. Either can be made to work, but Ether drew the schematic with an N channel. N is generally preferred because they have better electron mobility.
Vds: Maximum voltage from Drain to Source, or how much voltage you can block. You need at least 5V, but I've never seen a normal discrete FET with a Vds rating less than 5V.
Vgs: Maximum voltage from Gate to Source, or how much signal voltage you can apply. Again, most FETs can handle 5V just fine.
Vgs_thresh: Minimum voltage from Gate to Source to guarantee turning on the FET. Most FETs will be in the 1 to 3 V range, so you'll be fine.
Rds: Resistance from Drain to Source while on. Subtract this from the 82 ohm series resistor you calculated. It'll be relatively small, you can likely ignore it.
Ids: Maximum current from Drain to Source while on. It needs to be more than 20mA. Just about any FET that is big enough to be in its own package can handle this.
Unread 08-07-2012, 13:55
rsisk's Avatar
The GURU Channel
AKA: Richard Sisk
OK, just got back from Radio Shack trying to get the right components. The transistors were hard to match up, so I got a couple.
One is a MOSFET N-channel transistor and the other is a bag of NPN-Type transistors. I've included pictures below. My guess is the MOSFET is the closest match and where I am starting to build the circuit.
Am I correct in assuming the following:
Source - The +5V/82ohm/LED side of Ether's diagram
Drain - The ground side of the diagram
Gate - The DIO Signal/100Kohm side of the diagram
Here are the components I purchased, 100K-ohm resistors, MOSFET transistor, and NPN transistors
And the back of the MOSFET transistor and NPN transistor bag
Unread 08-07-2012, 15:20
DonRotolo's Avatar
Back to humble
FRC #0832
The DSC Digital I/O does not appear to be able to sink 20 mA.
Ether's transistor switch should work fine. A FET (especially an IFF510) may be overkill, a plain NPN switching transistor will be fine.
All these parts (resistors, 2n2222 or 2n3906 transistors) are available at Radio Shack.
Unread 08-07-2012, 15:26
source (in this case)
