Go to Post I love it when awards go to the right people. - David Kelso [more]
Unread 11-07-2012, 12:36
DELurker DELurker is offline
Former Engineering Mentor
AKA: William Lydick
no team (n/a)
DELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant futureDELurker has a brilliant future
Re: Press Fit
All of your bearing fit information (radial ball) can be found in the chart on page 131 at http://catalog.timken.com/WebProject...ookcode=eng11#, with the codes defined on pages 132-145.
If you can't make the holes to the specifications listed there, 0.001" undersized should work. I've found that Loctite Retaining Compound 641 works well in other applications, if you want to make the hole right at the bearing diameter.
As for press fits into thinner materials, I would recommend a flanged or snap-ring bearing with either retaining compound under the lip or 3 screws at 120-degree intervals.
With 1370 --
2012 Rutgers District Event Champions with 1676/56
2012 Lenape District Event Finalists with 2191/1691
2013 TCNJ District Event QuarterFinalists with 1143/4750, Gracious Professionalism Award
2013 Bridgewater-Raritan District Event Semi-Finalists with 4285/223
2013 MAR Championship Finalists (Backup) with 222/11/1403; Gracious Professionalism Award
Unread 11-07-2012, 12:38
MrForbes's Avatar
MrForbes MrForbes is offline
AKA: Jim
FRC #1726 (N.E.R.D.S.)
Re: Press Fit
fwiw, we made a couple gear boxes this year using flanged bearings and polycarbonate side plates, we discovered that drilling a hole with a Forstner bit will provide a sufficient press fit. There are lots of ways to do things like this.
Unread 11-07-2012, 14:25
pmangels17's Avatar
pmangels17 pmangels17 is offline
Mechanical Marauders - Alumnus
AKA: Paul Mangels
FRC #0271 (Mechanical Marauders)
pmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond reputepmangels17 has a reputation beyond repute
Re: Press Fit
Also note that polycarb cracks when you put loctite on it.
Unread 11-07-2012, 14:28
AdamHeard's Avatar
Lead Mentor
Re: Press Fit
This is an area where standardizing in design can make things a lot easier. If you only use a few common sizes of bearings, then you can get the appropriate reamers for these bearings (at some expense, but not awful; and due to design standardization they're used almost everywhere on the robot).
We have a press fit and slip fit (press being .0005 to .001 under depending on the availability of the reamers) for most bearings and bushings we use.
Most 973 robots over the past few years have most gearing running on plates that were waterjetted then reamed out by a reamer in a hand drill.
The reamer is really the best compromise between precision and the ability to use it on any given part and machine. It also allows "fixing" of damaged or out of tolerance parts.
Materials like polycarbonate that are much softer/weaker than the bearing itself will allow a much greater range of bore sizes without undue damage to or efficiency loss in the bearing.
Unread 11-07-2012, 14:58
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Press Fit
Originally Posted by Peck View Post
he isn't talking a generic drill set, he is talking a real machine shop's drill set where they have the drills accurate to tenths of a thou. An E drill is a generic and it is typically .250, accurate to the thou. If you are pressure fitting with generics... be really careful and take plenty of measurements.
There is no twist drill that can create a hole that is accurate within a tenth.
The diameter of the drill itself may be ground more precisely than on a cheapo drill, but the geometry of the tool inherently prevents it from making extremely round/accurate sized holes.
2001-2004: Team 100
2006-Present: Team 254
Unread 11-07-2012, 16:03
Brandon Holley's Avatar
Re: Press Fit
In addition to this, any sort of runout on the drill/lathe/mill you are using will compound these issues.
Reamer is the way to go if you want to have repeatable results from plate to plate. Drilling holes, milling them, laser cutting them or waterjetting them will all result in a different sized hole for the same "as designed" size.
The best way to deal with it is to ream.
One understated method of holding bearings in is green loctite (gap filling). Having the bearing slip fit inside a hole, and using appropriate green loctite does a good enough job of holding bearings in.
Also- the ball bearing/ball peen trick is a nice one if youre in a bind. We have a nice 1.5" diameter steel ball bearing. If a hole is a little bit too large, we can just stuff that bearing into the hole and whack it with a hammer. It creates a little curl of material just big enough to bite the bearing and hold it in place.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 11-07-2012, 16:08
AdamHeard's Avatar
Lead Mentor
Re: Press Fit
-Brando
On Emperor Swerve we had a 37mm bearing bore that we attempted to waterjet to exact size cutting super slow (like .7 in/min). The walls ended up being nontapered, but the kerf was larger than normal so the hole was easily .002 oversize.
We used some punches and ball peen hammer to rough up both the lip, and the inner diameter of the bore quite a bit in an even fashion around the diameter, and finished the assembly with bearing loctite.
We were able to "fill" that .002" gap in a really high load application with these methods and the bearings still have not loosened.
Unread 12-07-2012, 17:28
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
Re: Press Fit
A slightly undersized reamer is definitely the way to go. We've done all kinds of things in the past, but if you want a hole precise to .0001", use a good reamer.
We machined bearing blocks this year on our CNC mill, and some turned out as slip fits, some were press fits. Keep in mind this is the same end mill, same program, same bar of stock. You would think they all come out the same, but there is never a guarantee. Between a bit of high grit (400 or so) sand paper and snap rings, things were easily "good enough" for FRC. But...
Ideally, I would drill it undersize for the reamer and then ream it slightly undersize. Picking the size reamer you want is the hard part, but I would think .0005" under or so would be good enough. Other methods may work, but a reamer is going to give you the closest thing to a true cylinder that you can get.
