Re: Low Res Optical Encoders for Speed Control
I know we were having issues with the 360 count encoder on our shooter but that may have just been our setup. We end up moving to a cheap IR reflective sensor and piece of white tape and it's worked perfectly.
Not that I'm an expert on the API or anything, but looking at the LV implementation, there are four 4x encoders and eight counters that can be used for 1x and 2x. As stated before, they are running on the FPGA and run in parallel along with each other, PWM generation, triggers, etc. So, the encoders will not be an issue.
Greg McKaskle |
I think the actual number is 39,230.
