#256
Re: [FRC Blog] Einstein Report Released
Nick was referring to the intentional interferer. How did THEY find the bug, and test it, before using it on Einstein. Lots of people (including the report) don't buy the person's story that they "accidentally" found out by killing 2056 in SF2-1. @Ed Law: I hadn't thought of the REASON they came to the FTA's, but now that you say that, I think you're right. They probably suspected that someone else knew, and was targeting THEIR alliance. Otherwise, why would they admit to the crime they'd (to that point, anyway) gotten away with? |
#258
Sorry, I should have been a little more clear about what I meant. I understand this was an issue with the D-Link robot AP firmware. What I meant is when did the individual themselves find this issue, and when did he prove to himself the existence of this issue with the firmware. I in no way meant for that to be intended as "Why didn't FIRST know about this earlier?" or something of that nature. I also want to comment on the "witch hunt" that CD is seemingly brewing. While I would love to hear from this person about the hole itself and how they discovered it, I think they have already paid the price for it. I think for their personal identity to be revealed would only lead to more despair for that person. However, I would like to see a statement from their team over the subject. I think we'll see one soon. -Nick |
#259
More importantly even if you find out this person is the tip of the iceberg, who is to say how straight an answer we'll get about the rest of the story. Plus if we assume that someone was using it to cheat we'd have to assume they'd not be so silly to get caught otherwise it's of no value to cheat. This person knew that other people were aware of what they might be capable of. Logically all suspicion would flow to this person. It's not the best way to cheat and not get caught. As others have written, maybe the individual feared the use of this attack against their interests (it doesn't matter either way with regards to their involvement). With all the other issues I don't think we'll ever know the full extent of how much the 2 wireless issues could have contributed. Last edited by techhelpbb : 16-07-2012 at 12:23. |
#260
I did not acknowledge that there is an issue with the A ver of the 1522. The problem is an interaction of the firmware loaded on the Cisco router to fix another problem noted earlier in the season when used with A version. It was discovered in testing after St. Louis that the Cisco firmware and the Dlink AP were affected when used together. Please read page 7 and 8 of the report. Please note that the report also states that this updated firmware was only installed at week four events. That being said, a user testing with wifi devices at their home field could not have discovered this vulnerability. In addition, it could only be discovered at an event using a 5GHz enabled wifi device of which, until recently, there were limited numbers of such devices available. |
#262
So this means that people had a place to start looking weeks before Einstein. Whether they could find the specific interaction as you said would require a Cisco unit with that firmware (and very few people knew that information). I suppose one could take from that they discovered this by messing with other fields (who knows when or how). It seems from what I've seen that this person was sure they had something (which is sort of damning). I was never able to find anything extremely unusual about this 1522 I got from them. So it fits that you'd need this and some external set of factors that do not exist in my environment but do exist on the actual field. Course I can only rely on the information I was told that nothing besides this AP was changed to remedy the issue (otherwise one could argue that something was an issue in their robot as additional stimulus and had changed by the time you reviewed it for this report). The only way I can think of that someone could have stumbled on this without effecting a field would be to have exactly what's on the field. This seems unlikely given the way Cisco handles firmware and we know the version of firmware matters. That or perhaps they could have compared the 2 versions of the D-Link 1522 AP noticed a change in the behavior which points to the soft spot. Obviously attacking the field till you find it would be easier and in this case require less technical skill and resources. Course that would almost certainly mean that whoever insisted on bringing this forward had already done something they shouldn't or seen someone else do it. Last edited by techhelpbb : 16-07-2012 at 13:34. |
#263
In the last paragraph of page 9 of the report, it states: Quote:
Thank you. |
#264
Brian,
The reports of some people involving ver. A were simply anecdotal, unconfirmed reports that seemed to point in one direction when other things were ignored. If anyone can take anything from the report I hope it is that there are many things that can manifest the same way as an attack that are in fact not related. Go to the report and search for "buffer" to see one of these problems described. |
#265
Obviously I didn't spend all that time and money to build those little oscilloscopes because I thought FIRST merely had AP issues (though I admit that while I knew and still know more ways someone could interfere with the wireless I never thought anyone would be that devious or in this case so easily caught). Still it leaves it out in the open that at some point, perhaps multiple times, someone tested that exploit before they tried to demonstrate it. Additionally, I do agree with what you seem to conclude that this person didn't intend to rig the rankings. Surely this particular tampering is not the only issue and focusing on it too much distracts from the bigger issues we all must face from it. I'm not sure we'll ever know the full extent of what happened without adequate logs. Last edited by techhelpbb : 16-07-2012 at 14:36. |
#266
I also agree with what Greg and many others have said, that the individual should come out and admit their mistakes. I have full faith that the FIRST community at large will accept this individual's apology and move on, having learned from this ordeal.
But what I would not like to do is add on to this pressure that's amounting on this individual to speak out. Whether I think he/she should or not is a different matter; the decision is not mine to make. If the individual chooses to remain hidden, he/she may have to deal with the consequences of the discontent team members, and that's up to the individual. That said, I think this is very important as well, to keep things in perspective. FIRST is a community unlike the public at large, with the distinction lying on its gracious professionalism. I have no doubt that the community will continue to uphold and cherish this unique characteristic through difficult events such as this. |
#267
Concerning the comment about the forest and the trees, I am not sure what Lil' Lavery is getting at.
Is it that the system worked (i.e. even with all the problems discovered, we had a season with a record number of competitions and and competitors)? Is it that the system broke but is going to be fixed (i.e. There were problems but FIRST got to the bottom them)? Is it that the system is broken (i.e. even among robots that make it to Einstein, a substantial proportion have major electrical/programming problems)? Is it that the system is really broken (i.e. that the control system is a brittle mismash of marginally compatible subsystems that on its best day is can be in inadvertently brought to its knees by well intentioned programmers yet alone nefarious no-goodnicks)? I can see a lot of forests and a lot of trees. Joe J. |
#268
I think I get it... let's break this down shall we: " I realize that everyone wants to talk about the controversial and shocking part of the report, but a lot of people are missing the forest for the trees here. " "everyone wants to talk about..." This is not true but can be interpreted as an exaggerated expression to bring their point across... Ok that's fine. "A lot of people" ... this is not you... and really not some that may appear that way now with their posts. For example Greg's post... (I'm picking on him because of the timing of his post and because I have great respect for him)... the post was indeed fixed on one point (i.e. the trees). I should add I know the robowranglers like us (and many teams) will indeed study every piece of this report and make sure that we address each point properly. So let's just say some people... when it seems like a lot of people. The last part... missing the forest for the trees. The reason why I'm going through the trouble of breaking this down is because I got this feeling as well, but it is just a feeling. Basically there are posts that are applying pressure to the perpetrator and/or team, (i.e. the trees)... the forest is all the other problems not talked about as much... I'd say these are the other technical responses some of which I've been trying to say. I know someone else mentioned the idea of splitting the discussion up as well. I know when the dust settles I will want to discuss some of the other aspects of the report such as the network capping. Right now... I feel like backing off and letting the predominant discussion carry on. Last edited by JamesTerm : 17-07-2012 at 00:49. |
#270
