Go to Post Inspiration and recognition does not equal "advanced shop class". What's better for your team is not better for all teams. Remember that. - DonRotolo [more]
Unread 16-07-2012, 22:21
Tom Ore Tom Ore is offline
FRC #0525 (Swartdogs)
Tom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond reputeTom Ore has a reputation beyond repute
Re: pic: More fooling around with mecanum wheels
Originally Posted by MattC9 View Post
Have you tried shifting with mech's befor?
We did a mini-octocanum drive last year and had mecanums with fixed raised wheels for climbing the ramp in 2010. We've never done a shifting version. (The mini wheels were 2" diameter Colsons.)
Unread 16-07-2012, 23:24
Gregor's Avatar
Gregor Gregor is offline
#StickToTheStratisQuo
AKA: Gregor Browning
What is mini-octocanum? Is it standard octocanum with smaller "tank" wheels?
FRC 2011-xxxx Volunteer
How I came to be a FIRSTer
<Since 2011
Unread 17-07-2012, 03:39
Yes. Since we wanted a wide robot there wasn't much room for the second set of wheels. We tucked 2" diameter Colson wheels in as close as possible to the 6" mecanum wheels.
Here is a picture of the module. It worked really well except for being rather heavy. (The frames were aluminum not Lexan.) If we did it again, we'd work on bringing the weight down.
Unread 17-07-2012, 03:49
GRT808's Avatar
GRT808 GRT808 is offline
AKA: Grant
FRC #3008 (Kalani Falcons)
GRT808 is just really niceGRT808 is just really niceGRT808 is just really niceGRT808 is just really nice
What CAD software is this?
Personally, I am interested in what you did you color the bearings. I haven't been able to make them look like the shiny metal bearings you have.
Very nice render!
2009 Hawaii Regional Rookie Inspiration Award
2010 Hawaii Regional Chairman's Award
2011 Hawaii Regional Entrepreneurship Award
2012 San Diego Regional Entrepreneurship Award
2012 Hawaii Regional Entrepreneurship Award
2012 Hawaii Regional Chairman's Award
2012 World Championship Judges Award
Unread 17-07-2012, 04:55
Very nice render!
We use Creo. I made the bearings chrome. The other parts are aluminum, steel, brass, plastic, etc. Creo has lots of material choices and then choices for each material. For example, under the aluminum choice you can pick brushed, anodized blue, anodized red, cast, matte, polished, satin or scratch. The room for rendering is set to glossy white plastic.
Unread 17-07-2012, 06:58
Nemo's Avatar
Nemo Nemo is offline
Team 967 Mentor
AKA: Dan Niemitalo
FRC #0967 (Iron Lions)
Nemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond reputeNemo has a reputation beyond repute
Tom, you're the man. You make some really sweet models, even if you're just fooling around with some of them.
Unread 17-07-2012, 11:53
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
If the wheels were 2.5" instead of 3", I'm not sure why this is infeasible at a first pass. I think this design would be robust enough for a FRC bot on a flat field under 2 conditions: 1.) The lexan that supports the outer edge of the dead axle were replaced with C-Channel and 2.) The robot frame only mounts to the C-Channel.
3"x1.5" C-channel with 0.2" leg thickness would work great. The added ounces of the Aluminum C-Channel would be offset by leaving the gearbox plates as polycarbonate. All robot impact forces resolve through the C-Channel, and the polycarbonate only needs to be strong enough to rigidly cantilever the CIM as shown.
GitHub
