Go to Post In my opinion, the right mix of student, mentor, and engineer involvement is when everyone gives it 100%. - Jack Jones [more]
Unread 11-01-2003, 19:02
mistresshawk's Avatar
mistresshawk mistresshawk is offline
#1083 (The CREW)
mistresshawk is an unknown quantity at this point
Question Good Beginner Websites
I'm a rookie, with a team that's just starting up this year. I was wondering if anyone has any good websites with manuals/tutorials to learn PBASIC, geared towards someone whose experiance with programming is limited to programming her TI-83 Calculator.
Help?
Hawke
' There are very few problems that can not be solved with orders ending with "or die."'
Unread 11-01-2003, 19:09
Raven_Writer's Avatar
Raven_Writer Raven_Writer is offline
2004 Detroit & Pittsburgh Winners
AKA: Eric Hansen
FRC #0005 (RoboCards)
Raven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really niceRaven_Writer is just really nice
Send a message via ICQ to Raven_Writer Send a message via AIM to Raven_Writer Send a message via MSN to Raven_Writer Send a message via Yahoo to Raven_Writer
Re: Good Beginner Websites
Help?
Read the PBASIC manual, and visit http://www.innovationfirst.com/firstrobotics/ and http://www.parallax.com. InnovationFIRST has some info on the code, and Parallax has some documentation also.
AIM: wisprmylastbreth
EMail: nightskywriter@gmail.com
Y!: synsoflife
"ai yoru ga" -- "Love the nights"
Unread 11-01-2003, 19:39
Damian Manda's Avatar
Damian Manda Damian Manda is offline
The Damian
Damian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud ofDamian Manda has much to be proud of
Send a message via AIM to Damian Manda
Luckily the commands are very similar in PBASIC and TI-Basic.
I dont know any websites, but here are some commands:
(TI-Basic is first, followed by PBASIC)
For(x,1,10)...End
For x = 1 to 10...Next
If x=1..Then..Else..End
If x=1 then..else..endif (2.5 syntax)
1-->x
x = 1
While x=1 ... End
Do While x=1 .. Loop
If you want any specific commands, I might know them as well.
-Damian Manda
Unread 11-01-2003, 22:52
Geoffrey4283 Geoffrey4283 is offline
Geoffrey4283 is an unknown quantity at this point
"Error: Expected a label"
Hi, i'm just trying to see if anyone can explain to me the reason for thparticular error, or jsut help me figure out why my line of code won't work. We're just playing around with the EDU-Robots and some optical sensors from last year. Explain why simply adding this line of code after the Relay Feedback LIghts portion of the default code, and before the Output data, isn't working:
if rc_sw1 = 1 then drive_L = 190
It gives the error displayed in the subject of this "Expected a Label." I really don't know what it's asking for. It highlights drive_L and says expected a label. Can anyone help on that one? I've compared all previous uses of the variable drive_L, and there doesn't seem to be any difference from the way they've used it, to the way that I've used it. Any help would be appreciated, so thanks.
Geoff
Unread 11-01-2003, 23:33
Geoff_494 Geoff_494 is offline
#0494 (Martians)
Geoff_494 is an unknown quantity at this point
Send a message via AIM to Geoff_494
In the old PBASIC syntax, IF...THEN loops can only be directed to a label, you can't put a command after the THEN statement. Working could would be something along the lines of:
IF rc_sw1 = 1 THEN motor_fwd
*insert code here for the rc_sw1 <> 1 condition*
motor_fwd:
drive_L = 190
Also, what optical sensors are you using? If you're using the banner sensors from last year, the 7.2 volt battery pack that came with the EduBot won't be enough to power them. You'll have to use an external circuit that delivers 10-30 V (consider 2 9V batteries in series).
Unread 12-01-2003, 00:18
Mongoose's Avatar
Mongoose Mongoose is offline
#0948 (Newport Robotics Group (NRG 948))
Mongoose is an unknown quantity at this point
Send a message via AIM to Mongoose
I hope you searched, there are a couple of rookie threads out there. But there's a pretty nice web site out there at http://www.first-codex.net which has some nice articles about programming. The good part is you get to use gotos and labels in your code just like in TI-BASIC.
Labels are labels in the code which... uh, label a section. You can jump around parts of your program by using the goto command. If you tell the program to go to a section marked by a label that doesn't exist, the editor screams at you.
Unread 12-01-2003, 05:35
Gobiner Gobiner is offline
#0753 (High Desert Droids)
Gobiner is an unknown quantity at this point
Send a message via ICQ to Gobiner Send a message via AIM to Gobiner
You might try contacting people from these forums on ICQ or AIM to get your questions answered. Spend enough time here and you notice a few people know everything, so just go straight for the jugular.
0N3 1337 PR0G|24MM1N6 N1NJ4
Unread 12-01-2003, 15:38
AKA: Eric Hansen
rbayer is a pretty smart dude. Just make sure your questions and/or answers don't have any spelling mistakes like "r" instead of "are"
Y!: synsoflife
Unread 12-01-2003, 15:41
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
lol. That was the day I spent filling out college apps all day. Let's just say I wasn't in a very good mood. Anyway, the point still stands: email me with any questions you may have and I normally respond within an hour.
--Rob
Unread 12-01-2003, 15:56
AJ Quick's Avatar
AJ Quick AJ Quick is offline
Your Attention Please
FRC #0006 (CogSquad)
AJ Quick has a spectacular aura aboutAJ Quick has a spectacular aura about
He's not kidding either.
-AJ Quick (Alum on Team 6)
http://www.HHSRobotics.com/
Place your attention entirely on my voice and try to ignore all the others. It is important to be able to focus on a single source of information while blocking out all the other things competing for your attention.
Unread 12-01-2003, 15:59
AKA: Eric Hansen
Usually, it's amazing if it takes him 30 mins ( )
Y!: synsoflife
Unread 13-01-2003, 10:18
Still not working
We've changed the code from the previous bit to this:
drive_L = drive_L
goto end_optics:
motor_fwd:
drive_L = 254
end_optics:
The point of all this is that when we have the optical sensor reflecting, indicated by the solid or rapidly blinking red LED on the top of the banner sensor, we want the robot to move forward. It isn't, to say the least. The problem either lies with our program, or our contact between the white sensor cable and SW1 on the EDU robot. Any suggestions?
Unread 13-01-2003, 10:26
Are you sure that rc_sw1 gets set to 1 when the sensor "sees" a target? There are two signal wires (one black, one white) coming from the optical sensor; one will be 1 when the sensors sees something, the other will be 1 when it doesn't. Try a "debug? rc_sw1" and see what happens as you move a target in and out of its field of view.
Unread 13-01-2003, 10:35
Sort of
We've tried both the black and the white wires as we've been troubleshooting, and getting nothing out of either of them. At least, no response. Where do I do the "debug? rc_sw1"? Soudns like a very good idea, I just don't know how.
Unread 13-01-2003, 10:38
Put it anywhere between the Serin and Serout. After you send the program to the RC, leave the cable connected. A little blue window should pop up on your computer screen that scrolls the values of rc_sw1 whenever the robot is running.
Debug?, along with the rest of the debug family, are the staples of bug finding. Alternatively, you can drop your code in RoboEmu and see what happens when you turn on sw1. If it works in RoboEmu, it's probably an electrical issue.
Vanilla Coke..good? bad? A. Leese Chit-Chat 41 07-01-2004 00:15
Check this stuff out: good websites LBK Rules Chit-Chat 3 15-01-2003 10:28
What makes the Good, So good? Chris General Forum 16 18-07-2002 11:09
your favorite music and tipps about good new rock music PsychoPhil Chit-Chat 26 03-07-2002 01:19
IT to be revealed on Good Morning America Joe Ross Dean Kamen's Inventions 50 13-12-2001 09:53
