Go to Post How come the dropped tool ALWAYS rolls under the exact center of the workbench? - DonRotolo [more]
Unread 22-07-2012, 18:30
joelg236 joelg236 is offline
4334 Retired Mentor & Alumni
AKA: Joel Gallant
joelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond reputejoelg236 has a reputation beyond repute
VEX Cortex RobotC help
Hello everyone,
I am working on a the code for a VEX robot, using RobotC for Cortex. I have never used C, C++ let alone robotc (Java is my primary language). So far, I am having a tough time understanding how to write the code for our robot.
I'll give you a description of what it is and what I'd like it to do. It is a 4 wheeled robot with an arm controllable by 1 servo (We only had 5 motors and the arm was the only part that only had to move a certain degree). There is an intake that has 1 motor to control it.
So, the tl;dr version is 4 motors for driving, 1 servo to move the arm and 1 motor to do intake.
What I want to do is do tank drive on the 4 motors, have the two triggers (Equivalent to R1 and L1 on PS3) move the arm up and down, and have the "A" button turn on the intake.
I havn't been able to get much past the template. I have the 4 motor tank drive working, but that's it.
#pragma config(Motor,  port2,           frontRightMotor, tmotorServoContinuousRotation, openLoop, reversed)
#pragma config(Motor,  port3,           backRightMotor, tmotorServoContinuousRotation, openLoop, reversed)
#pragma config(Motor,  port4,           frontLeftMotor, tmotorServoContinuousRotation, openLoop)
#pragma config(Motor,  port5,           backLeftMotor, tmotorServoContinuousRotation, openLoop)
#pragma config(Motor,  port6,           armServo, tmotorServoStandard, openLoop)
task main()
  while(1 == 1)
    //Right side of the robot is controlled by the right joystick, Y-axis
    motor[frontRightMotor] = vexRT[Ch2];
    motor[backRightMotor]  = vexRT[Ch2];
    //Left side of the robot is controlled by the left joystick, Y-axis
    motor[frontLeftMotor] = vexRT[Ch3];
    motor[backLeftMotor]  = vexRT[Ch3];
    //Servo?
    //Intake?
I can answer any questions that might help you understand what I'm trying to do. Need this to be done this week (5 days) and I don't have enough time in the day to learn a lot of the syntax. All help is appreciated.
Thanks!
Joel
All opinions are my own.
