Go to Post I say: Chutes & Ladders in FRC 2008! - petek [more]
  #91   Spotlight this post!
Unread 30-06-2012, 10:53
Adam Freeman's Avatar
Adam Freeman Adam Freeman is offline
Forever HOT!
FRC #0148 (Robowranglers)
Adam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond reputeAdam Freeman has a reputation beyond repute
Re: 2012 FRC Team 1717 Uncut
Originally Posted by LeelandS View Post
Wow... This surprises me. I knew of a handful of teams throughout the season who effectively used camera cross hairs. 1507, a shooter powerhouse at Finger Lakes, won the regional with those cross hairs. I believe I heard at one point 217 was using them as well, and 67 had borrowed the code for them for some time (thought this may be incorrect. Memory doesn't serve me well nowadays).
But I never expected 1717, one of, if not the, most precise shooters in the world, would use them. This really convinces me that you don't need complex systems to do well.
Leeland...you are correct. We switched to cross hair aiming at the Troy district and immediately saw a jump in our scoring numbers. It was worth approximately 2 balls/match.
Congratulations to 1717 on an incredible season. Easily the most accurate shooter this season.
2005 FIRST World Champions (330, 67, 503)
2009 FIRST World Champions (111, 67, 971)
2010 FIRST World Champions (294, 67, 177)
  #92   Spotlight this post!
Unread 01-07-2012, 11:16
LeelandS's Avatar
LeelandS LeelandS is offline
Robots don't quit, and neither do I
AKA: Leeland
FRC #1405 (Finney Falcons)
Team Role: Tactician
LeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond repute
Originally Posted by smistthegreat View Post
Not trying to hijack the thread, but I just want to clear this up. We did not use crosshairs. We just had the straight camera feed that we used to line up.
Also, this thread is just full of awesome.
Gah. Sorry again Bryan. It seems most of the things I was told about 1507's robot were unconfirmed and not quite correct -_- I'm really sorry I keep getting the info about your robot mixed up.
My heart will forever lie with SparX
1126: 2008 - 2011; Where it All Began.
1405: 2013 - Present; A Wanderer is Born.
Work hard, play hard. And maybe someday...
  #93   Spotlight this post!
Unread 01-07-2012, 18:44
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
Originally Posted by jakemochas View Post
It is a reflective photointerrupter with emitter and detector facing in the same direction. We have 16 black marks that are evenly spaced on the side of the flywheel to provide data for the detector.
Do you happen to know what part number that sensor is? I have been trying to find out what types of sensors are good but have no idea where to start looking for those sensors, let alone what ones are good/suitable for FRC.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
  #94   Spotlight this post!
Unread 18-07-2012, 22:16
jakemochas jakemochas is offline
Programmer
FRC #1717 (The D'Penguineers)
Team Role: Student
jakemochas has much to be proud ofjakemochas has much to be proud ofjakemochas has much to be proud ofjakemochas has much to be proud ofjakemochas has much to be proud ofjakemochas has much to be proud ofjakemochas has much to be proud ofjakemochas has much to be proud ofjakemochas has much to be proud of
As promised, here are several pictures of our swerve module. On this particular module, there is no turning sensor or wheel encoder, but the brackets that mount each one are present. As you can see in the photos, this module has a two speed coaxial shifting transmission for the drive and a single speed transmission to turn the modules. Nearly all of the parts were custom fabricated. All internal parts including our gears were made in our shop. The sheet metal box structure for the wheel module and transmission plates were made by one of our sponsors.
Enjoy!
http://www.chiefdelphi.com/media/img...3d8c8fb0_l.jpg
http://www.chiefdelphi.com/media/img...3a6d3087_l.jpg
http://www.chiefdelphi.com/media/img...e1d66bd4_l.jpg
http://www.chiefdelphi.com/media/img...614b368a_l.jpg
http://www.chiefdelphi.com/media/img...f757dd0a_l.jpg
  #95   Spotlight this post!
Unread 20-07-2012, 13:54
Programmer
Team Role: Student
As promised, we have posted pictures of our wheel modules (they can be seen in recent images or you can search "1717 wheel module" on CD). On this particular module, there is no turning sensor or wheel encoder, but the brackets that mount each one are present. As you can see in the photos, this module has a two speed coaxial shifting transmission. Nearly all of the parts were custom fabricated. All internal parts including our gears were made in our shop. The sheet metal box structure for the wheel module and transmission plates were made by one of our sponsors.
To make sure everyone's questions get answered, I would appreciate it if all of the questions are posted in this thread.
Enjoy!
Jake
FRC Team 1717
  #96   Spotlight this post!
Unread 20-07-2012, 14:04
JamesTerm's Avatar
JamesTerm JamesTerm is offline
Terminator
AKA: James Killian
FRC #3481 (Bronc Botz)
JamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to behold
Enjoy!
Jake
FRC Team 1717
Thanks for the pics of wheel modules... sorry I missed your msg last month I sent you one recently. I'm having problems with CD notifies via email.
  #97   Spotlight this post!
Unread 21-07-2012, 17:16
Programmer
Team Role: Student
Originally Posted by 42! View Post
Why was it that you choose to use custom gears for the Rs-550 reduction over banebots planetary gearboxes? Was there any weight saving this way?
We are using Banebots RS-550's for our turning transmissions. We tried to use Banebots transmissions in the past for our swerve, but found them to be too unreliable for our liking.
Our turning transmissions have now run for hundreds of hours on our practice robot and there is no visible wear on the teflon/anodized coating. They have required no service other than the initial lubrication with dry grease. Our current turning transmission gear-train weighs less than a Banebots as well. Also, the backlash is a little better than the Banebots but not by much.
  #98   Spotlight this post!
Unread 21-07-2012, 17:26
gixxy's Avatar
gixxy gixxy is offline
Programming and Arduino Mentor
AKA: Gustave Michel III
FRC #3946 (Tiger Robotics)
gixxy is on a distinguished road
Awesome.
I actually get to read "The New Cool" this summer for school!
Programmer - A creature known for converting Caffeine into Code.
Studying Computer Science @ Louisiana Tech University
Associate Consultant @ Fenway Group
2012-13: 3946 - Head of Programming, Electrical and Web
2014 - 3468 - Programming Mentor
2015 - Present - Lurker
  #99   Spotlight this post!
Unread 22-07-2012, 03:11
GRT808's Avatar
GRT808 GRT808 is offline
AKA: Grant
FRC #3008 (Kalani Falcons)
GRT808 is just really niceGRT808 is just really niceGRT808 is just really niceGRT808 is just really nice
The gears with the smaller teeth in the swerve drive, are they 32 DP? Where did you get them from (you didn't make them yourselves did you, noticed the earlier post about gear making)? And do they come anodized or did the team anodize them themselves?
Also, for electrical, are those Anderson power connectors?
2009 Hawaii Regional Rookie Inspiration Award
2010 Hawaii Regional Chairman's Award
2011 Hawaii Regional Entrepreneurship Award
2012 San Diego Regional Entrepreneurship Award
2012 Hawaii Regional Entrepreneurship Award
2012 Hawaii Regional Chairman's Award
2012 World Championship Judges Award
  #100   Spotlight this post!
Unread 22-07-2012, 18:57
42!'s Avatar
42! 42! is offline
College Student
42! is an unknown quantity at this point
Thanks for the answer. It really sheds some light on the design of the module. On another gear question, Does your team manufacture their own bevel gears? Or do you source them from someone else?
  #101   Spotlight this post!
Unread 22-07-2012, 19:07
msimon785 msimon785 is offline
Fusing Function with Form
AKA: Mathew Simon
msimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant futuremsimon785 has a brilliant future
I believe in 2011, 1717 used MC #6529K14. They of course finished the bore (hex) and cut down the face width to their needs. Not sure about this year or other years, though. They may have used something different.
Mathew Simon
CAD/Design
[2013-20xx]: 973 "Greybots"
[2011-2013]: 1515 "MorTorq"
[2008-2010]: 1836 "MilkenKnights"
  #102   Spotlight this post!
Unread 23-07-2012, 11:55
Programmer
Team Role: Student
Originally Posted by David Brinza View Post
I read in the "1717 Uncut" CD thread that a couple of thousand hours were invested in this design.
Originally Posted by IanW View Post
I'm confused how ten people could even spend 2000 hours working on a model during the build season and still have time to actually fabricate it, let alone design the rest of the robot. I mean, with school, homework, sleep, and my team's build space not being open, I wasn't even able to put in 200 hours over the course of the entire build season, and that includes time spent CADding at home.
Originally Posted by SuperNerd256 View Post
I think the "2000 hours" is collectively over the course of the 4 year time period in which they started using swerve. It could be in one build season, but like you said it would be tough.
The wheel module design this year was completely new. The new motor allowance for this year allowed us to build independent swerve drive without sacrificing power for other mechanisms. We designed the module during this build season as rookie seniors. It took about 2000 man hours to both design and fabricate 10 wheel modules (4 for the official robot, 4 for the practice robot, and 2 spares). The fabrication process of the modules was quite time-consuming and tedious.
On average, we seniors put in about 500 hours during the robotics season. Some of us, including the programmers and drivers, exceeded 750 hours during the robotics season. We are able to dedicate this much time to robotics because we are in our second semester with a light course load. Also, we only get one opportunity to do this awesome competition so we are extremely excited and dedicated to building our robot!
  #103   Spotlight this post!
Unread 24-07-2012, 00:26
Programmer
Team Role: Student
Originally Posted by Gdeaver View Post
I notice the wheel position sensor is not in the pictures. What sensor did you use.
Originally Posted by Akash Rastogi View Post
Do you mean a sensor for the rotation of the module? I believe it is pictured in the black bracket in this picture
Looks like the sensor mount and a coupling but, what sensor was used. It does not appear that the timing belt pulleys are 1:1 so I'm guessing a quadrature encoder?
For turning, we keep track of our absolute position using a US Digital M4A. The sensor is setup 1:1 with the absolute wheel position. You can see the bent sheet metal bracket in Wheel Module Picture 3 to the front left.
For the drive, we are using an optical encoder that is attached to a small aluminum shaft. This shaft is directly coupled to the CIM motor and therefore one-to-one with the speed of the CIM. It keeps track of wheel rotations. You can see the flat mounting plate in Wheel Module Picture 4 right next to my thumb.
  #104   Spotlight this post!
Unread 01-09-2012, 20:23
Andrew Lawrence
Posts: n/a
Sorry about resurrecting an old thread (albeit an awesome thread), but I've been thinking about the accuracy of this shooter for the past week. Aside from the crosshairs and software put into shooting, what mechanical advantages did it have? Like what mechanically did they do to their shooter along with the code to make it so darn accurate?
  #105   Spotlight this post!
Unread 09-09-2012, 18:03
JamesTerm's Avatar
Terminator
AKA: James Killian
Jake, (or anyone else for that matter)
I have a question about swerve drive... is it common to allow some degree of freedom of being able to align the wheels perfectly straight if you want to go straight? It seems like if you tighten your grip too much you may run into oscillation. Assuming there is some tolerance what would be a good metric for this (I think I remember reading 2 or 3 degrees somewhere elsewhere in the forum).
