Go to Post I didn't say this! - Max Lobovsky [more]
Unread 22-07-2012, 22:14
42!'s Avatar
42! 42! is offline
College Student
42! is an unknown quantity at this point
Bevel Gear Machining.
This is a bit of a random query. For an off-season project our team is needing to produce some rather large bevel gears on our 3-axis Tormach CNC machine. The specs of these gears would be 16 DP and 45 teeth. Anyone have any insight into the process of bevel gear machining? Any tips or advice would be appreciated.
Unread 22-07-2012, 22:26
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Bevel Gear Machining.
For gear making you are going to need at least an lathe and 4th axis for the tormach. We have cut out regular gears with a 4axis on a CNC mill before but with bevel gears I assume it is a more complex operation?
Here's a cool vid of bevel gears being made on manual machine: http://www.youtube.com/watch?v=7yld4VboYg0
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 23-07-2012, 15:24
quinxorin quinxorin is offline
Mentor now :(
AKA: Ian Pudney
quinxorin will become famous soon enough
The hardest part of machining a bevel gear - or any gear - is the spacing between teeth. You can make the bevel portion easily with a lathe (watch the video) - but you need a 4-axis mill to make the spacing, or at least to do it "the right way."
Of course, it can still be manufactured with a 3-axis mill if the vise can be rotated precisely: put the gear on a shaft in the vise, cut a slot, rotate it the correct number of degrees, cut the next slot, and so on. The tricky part is when you run out of vise freedom - you have to align the gear again to continue cutting.
You can make it even better if your mill's head can be rotated - this will allow a consistent depth with the bevel gear grooves, rather than being far deeper at the wider portion (which would reduce strength).
Or, if your vise doesn't turn, there's always trig - with a CNC machine, shouldn't be too hard. However, a rotating head won't help, so you will have a gear with deeper grooves at the bottom than the top.
"Sed res docuit id verum esse, quod in carminibus Appius ait, fabrum esse suae quemque fortunae."
- Every man is the architect of his own fortune.
Unread 23-07-2012, 17:18
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Another method would be to simply lathe a blank and send it out to a gear shape/hobbing shop.
Its a whole lot less work, but CNC milling your own is pretty fun!
-RC
R.C.
MadTown Robotics Team 1323
Unread 23-07-2012, 17:37
DonRotolo's Avatar
Back to humble
FRC #0832
The issue with bevel gears is that the teeth (and spaces between them) are not constant - they taper. Some careful clamping and indexing can help get the blank aligned with the cutting tool properly, but you need to use a tool that is narrower than the narrowest space and let it run its path. A specially-shaped cutter is best, tapered so it cuts the flanks of the teeth properly.
Get a bevel gear - any - and study it to plan out your buts. Make a few from wax or aluminum to get the feel and plan out the holding and indexing.
Unread 23-07-2012, 18:28
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
That is a really odd size of gear and sounds like WAY too much work to make it. May I ask what exactly you're doing and how you determined you need this size of gear?
Unread 23-07-2012, 19:02
David Guzman's Avatar
David Guzman David Guzman is offline
AKA: Dave
FRC #1251 (The Techtigers)
David Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant futureDavid Guzman has a brilliant future
Do you actually want a Miter Gear? 1:1 Ratio?
If yes, ignore rest of post.
Martin Sprocket Catalog shows a Bevel Gear with 16P 48 Teeth. But bevel gears work in sets. This particular one is a 3:1 ratio.
Part # BS1648-3
Team 1251 The Techtigers
2010 FL Regional Winner (BIG thanks to 86 and 1612)
2009 FL Regional Finalist (BIG thanks to 79 and 744)
2008 FL Regional Winner, FL GM Industrial Design, SC GM Industrial Design
2007 FL Regional Winner, FL GM Industrial Design, Palmetto Regional Finalist, Palmetto Motorola Quality.
2006 Palmetto Regional Winner, Daimler Chrysler Team Spirit Award
2005 FL Regional Judges Award, FL Regional 3rd seeded and finalist, Palmetto Regional Xerox Creativity Award, Palmetto Regional 1st seeded and finalist
2004 UCF Regional Rookie All-star Award
Unread 23-07-2012, 19:52
42!'s Avatar
42! 42! is offline
College Student
Thanks for all the responses guys. In particular the last one. As it turns out this bevel gear does need to have a 3:1 ratio. The small pinion bevel gear (16 tooth) will most likely be a purchased item, However for a variety of reason it would be preferable to machine the large bevel gear ourselves. In particular I was looking into using a three axis process like this http://www.youtube.com/watch?v=vw4ZX8VDIqY which is often used to make large bevel gears. Is this process a feasible one ?
Unread 24-07-2012, 23:06
Seth Mallory Seth Mallory is offline
FRC #0192 (GRT)
Seth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond reputeSeth Mallory has a reputation beyond repute
In 2011 we used the bevel gears from some power tools from Harbor Freight. We needed some angle gear boxes at the last minute. They came with bearings and shafts that we could mount things too and are still going strong.
Unread 24-07-2012, 23:14
Which particular tool?
Unread 25-07-2012, 11:30
FRC #0192 (GRT)
We used a 18 volt angle drill. One of the kop motors was a perfect match and we were able to use the reduction gears. You can look on line at the parts lists and diagram for most tools. If you search you can many different size of gear sets. Also winch and air tools are good sources. In 6 the hours the team had bought and made 2 angle gear boxes for 25$ each.
Unread 25-07-2012, 12:56
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
There are several different tooth forms for bevel gears; if you're planning to build something using a stock gear and a custom one, make sure you've matched the tooth forms carefully.
I'd say it's usually a lot simpler just to buy an off-the-shelf set of gears.
Unread 25-07-2012, 20:46
DonRotolo's Avatar
Back to humble
FRC #0832
Not as shown, because the bevel gear you are proposing has an angled face. In the video the tool is perpendicular to the teeth. To use a process like this, you'd need to elevate the workpiece at a precise angle, then turn it a precise arc for each tooth - i.e. have the tool perpendicular to the tooth root.
A spiral bevel gear would work OK (duh - they did it!), maybe better, with just a small extra effort in design. But you'd likely have to cut both gears yourself.
Unread 25-07-2012, 21:22
42!'s Avatar
42! 42! is offline
College Student
Alright then, That makes a bit more sense seeing as there's a good amount on the internet related to 3 axis CNC work on Spiral bevel gears.,but not on straight tooth bevel gears. Having to manufacture both gears would be a trade-off we could make. (We have a 4th axis attachment for our Tormach we could use for the pinion.) Does anyone have any knowledge related to the advantages and disadvantages of using spiral bevel gears?
Unread 25-07-2012, 23:42
Aren_Hill's Avatar
Build Nifty Things
I've debated doing this myself a few times, but never really had to pull the trigger. I did decide i'd probably take the CNC and a really long runtime route, as you definitely couldn't buy what I was after.
A guy who likes robots.
