Go to Post Play FRC like Bruce Lee, not an MMA fighter. - Jessica Boucher [more]
  #31   Spotlight this post!
Unread 26-07-2012, 18:24
KrazyCarl92's Avatar
KrazyCarl92 KrazyCarl92 is offline
AKA: Carl Springli
FRC #0020 (The Rocketeers)(EWCP)
KrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond reputeKrazyCarl92 has a reputation beyond repute
Re: Low Res Optical Encoders for Speed Control
By the way, we were able to get the robot shooting about 50% last night without speed control. This was using the camera feed to the driver station for manual aiming and we had driver voltage control on the shooter motors. We may work toward integrating a simple non-PID speed control algorithm and vision processing from there. The vision processing part was complete during the build season, we just need speed control that works in PWM or to get our CAN working.
[2017-present] FRC 0020 - The Rocketeers
[2016] FRC 5811 - BONDS Robotics
[2010-2015] FRC 0020 - The Rocketeers
  #32   Spotlight this post!
Unread 26-07-2012, 18:53
Originally Posted by KrazyCarl92 View Post
I could post pictures if anyone is interested.
If it's not too much trouble, please do.
  #33   Spotlight this post!
Unread 26-07-2012, 21:56
AKA: Carl Springli
posted here, there are 3 pictures:
http://www.chiefdelphi.com/media/photos/38088?
  #34   Spotlight this post!
Unread 26-07-2012, 23:16
Were you thinking of trying a bang-bang controller, or perhaps a take-back-half?
  #35   Spotlight this post!
Unread 26-07-2012, 23:17
Thanks. You got a lot of hits. I guess there was some interest :-)
  #36   Spotlight this post!
Unread 27-07-2012, 10:46
AKA: Carl Springli
We haven't decided exactly yet. Haven't hooked the encoder backup since we stopped using it in competition, so that's the first step along with verifying that it works.
I had thought of a bang-bang approach where we base the original voltage on motor curves, then if the speed drops X% below the target speed, raise the voltage by Y%, or if the speed exceeds the target by X%, lower the voltage by Y%. X would be the max allowable deviation from the target speed and Y would be an experimentally determined voltage correction. If its between 100-X % and 100+X %, we would apply no voltage correction.
I'd also like to see what the students come up with. After reading about take back half control here:
http://www.edn.com/design/analog/432...ence-algorithm
that seems like a good option. It looks like a good opportunity to explore different speed control options so we may try multiple approaches to see what gives us the best results (at least that's what I would like to see).
  #37   Spotlight this post!
Unread 27-07-2012, 11:17
There's a lengthy discussion (and paper) of bang-bang here, if you haven't seen it yet:
http://www.chiefdelphi.com/forums/sh...d.php?t=105679
Here's a thread (and paper) on take-back-half:
http://www.chiefdelphi.com/forums/sh...d.php?t=105965
