Go to Post If enough students "get it," the team will begin to. And if enough students "get it," the smart ones will seek out all the extra help they can get. That's how I found Chiefdelphi... - Joe G. [more]
Unread 12-01-2003, 17:23
Miles Miles is offline
Miles is an unknown quantity at this point
Question Stacker with a vacuum
Our team was considering using a vacuum to lift containers. Any suggestions? And what do the rules say about this? Any information at all would be helpful and greatly appreciated!
Unread 12-01-2003, 17:57
HolyMasamune's Avatar
HolyMasamune HolyMasamune is offline
41246017 O-('_'Q)
AKA: Y C
None #0840 (Aragon Robotics Team)
HolyMasamune is on a distinguished road
Send a message via AIM to HolyMasamune
I think the rules say that you can't use vacuums in the competition. Not sure though, can someone confirm this?
Unread 12-01-2003, 18:05
KaeleyAnne KaeleyAnne is offline
#0058 (Riot Crew)
KaeleyAnne is an unknown quantity at this point
Rule M12 states that "only the allowed air cylinders may be used to generate vacuum," so a vacuum can be used.
co-captain
Unread 12-01-2003, 18:08
41246017 O-('_'Q)
AKA: Y C
I thought the air can only go one way in those cylinders, which means that it's only a one time use unless you can somehow save up the air in there.
Unread 12-01-2003, 18:09
Brett W Brett W is offline
#0843 (WYVERNS)
Brett W is on a distinguished road
Rule M12 States
M12 Only items listed under the PNEUMATICS section of the Kit list may be used to
store, generate or transmit compressed air or vacuum, with the following exceptions:
· Suction cups may be fabricated from legal Kit parts, as defined in rule K1 below.
· Tubing may be compressed in order to block the flow of air.
· Tubing may not be compressed in order to generate compressed air or vacuum.
· Only the allowed air cylinders may be used to generate vacuum.
WARNING!
You may only use pneumatic components from the pneumatics kit.
Custom-made pneumatic components (fittings, air cylinders, pumps,
valves, etc) are not allowed. Additional off-the-shelf pneumatic
components are not allowed.
My understanding is that you can only use the kit of parts stuff with the addition of those exceptins listed in rule M12. So if you can somehow make a vacuum with just those parts provided in the kit with out modifing them then go ahead and suck away. This is just my interpretatin you should double check with FIRST seeing as i am not an official FIRST guy. I hope that this helps
Brett
Unread 12-01-2003, 18:13
D.J. Fluck
Posts: n/a
Vaccums are legal as long as supplied pneumatics are the only pneumatics used and they are possible with the kit of parts supplied.
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Creating a vacuum with the cylinders is very easy. Start by pushing the rod all the way into the cylinder. Now, put your thumb over the lower port and pull on the rod. Notice that your finger gets sucked in a little? That's a vacuum!
Unread 12-01-2003, 19:09
#0843 (WYVERNS)
Don't forget your team can do anything you want before you read this. Once the air cylinder is fully extended you lose a little of your suction power causing the amount grip to decrease and then it is easy to knock the bin off of the suction cup. There is another way. Our team figured it out and is making it work, But that is a secret. You could try the cylinder idea if you like i haven't tested it but our mentors say that it probably won't work.
Brett
Unread 13-01-2003, 17:10
tenfour's Avatar
tenfour tenfour is offline
AKA: Chris
#0696 (The Circuit Breakers)
tenfour will become famous soon enough
Send a message via AIM to tenfour
NO OTHER DEVICES
I THINK THERE IS A RULE THAT SAYS NO ADDITIONAL PNEUMATIC DEVICES......THAT MEANS NO VACUME PUMPS!!!!
GET IT OUT OF UR HEAD!!
-SIR STATE THE OBVIOUS ALOT
-2004 Arizona Regional Finalists (thanks 80 and 498)
-2004 Arizona Regional Sportsmanship Award
-2003 Los Angeles, CA Regional Finalists
-2003 Phoenix, AZ Regional Semifinalists
-2003 Phoenix, AZ Regional 3rd Seed.
-2002 Los Angeles, CA Regional Semi-Finalists
-2001 Los Angeles, CA Regional Semi-Finalists
FIRST Mantra - When Lawyer-ism fails, Gracious Professionalism Prevails.
(Yes, it is "BCR Orange")
Unread 13-01-2003, 17:19
GregT GregT is offline
GregT will become famous soon enough
Send a message via AIM to GregT
Re: NO OTHER DEVICES
WHO SAID YOU NEED A "VACUME" PUMP TO MAKE A VACUUM? I CAN THINK OF AT LEAST 5 WAYS TO MAKE A STRONG VACUUM THAT DOESN'T REQUIRE THE USE OF A RESTRICTED PNUMATIC DEVICE.
And do you like being talked to in all caps? CAPS ARE THE EQUIVLANT OF SCREAMING IN TYPE. Would you want to be screamed at? I know I don't like to be, try and use proper capitalization or no capitalization at all.
Greg
The above was my opinion. I'm wrong a lot. I'm sarcastic a lot. Try not to take me too seriously.
Unread 13-01-2003, 17:54
Suneet Suneet is offline
Physicist-In-Training
None #0599 (RoboDox)
Suneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to beholdSuneet is a splendid one to behold
Send a message via ICQ to Suneet Send a message via AIM to Suneet
In 2000, we had this cool thing with the pneumatics called a Vaccum Ejector that turned pressure into an equivalent vaccum. Perhaps FIRST should provide them again...
Unread 13-01-2003, 18:16
#0843 (WYVERNS)
What is the challenge in that. I think FIRST has purposly made it harder than that to make a vacuum.
Brett
Unread 17-01-2003, 17:40
matt111 matt111 is offline
#1024 (McKenzie Kilabytes)
matt111 will become famous soon enough
i thought about this but didn't want to risk it not working (being a rookie team) but if it works , more power to ya
Unread 17-01-2003, 23:17
JimO JimO is offline
JimO is an unknown quantity at this point
creating vacuum with air cylinder
You can create a vacuum pump with the cylinder and two check valves, but those aren't allowed, right? You can perform the function of the check valves with solenoid valves--a bit of a hack but should work.
Now, is there anything in the rules to forbid you capping off the 2x4 extruded aluminum pieces and creating vacuum tanks?
Unread 17-01-2003, 23:22
Moshingkow Moshingkow is offline
Moshingkow is an unknown quantity at this point
Re: creating vacuum with air cylinder
I dont think so, but I dunno how your gonna make that much of a vacuum without a pump...
On a related note:
Theres a way to make your robot have ALOT more air pressure stored then you have in the canisters using extrusions, and I believe it would be legal. so ponder away...
pic: Another unsed stacker, wings down CD47-Bot Robot Showcase 11 30-04-2003 21:36
how many of u actually used the stacker if u had one? HolyMasamune General Forum 21 14-04-2003 13:12
A stacker repents... Jason Haaga Rules/Strategy 24 03-03-2003 19:10
Image Discuss: Team 753 Working on the Stacker CD47-Bot Robot Showcase 2 22-02-2003 01:05
Next Question - Check Valve archiver 2001 7 23-06-2002 23:18
