Go to Post Do whatever you must to survive within the rules, but please stay within the rules. - Kevin Sevcik [more]
Unread 31-07-2012, 10:45
LeelandS's Avatar
LeelandS LeelandS is offline
Robots don't quit, and neither do I
AKA: Leeland
FRC #1405 (Finney Falcons)
Team Role: Tactician
LeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond reputeLeelandS has a reputation beyond repute
90 Degree Gearbox?
Hello CD Community!
I, along with a few others on 1405, have been working on an off-season project that we would hopefully be able to use on robots for years to come. One of the requirements we set forth was the placement of the CIM motor used to drive wheels. We're trying to reduce the amount the CIMs hang out into the center portion of the robot's drive base.
One of the ideas I came up with was using a "90 degree gearbox" on the CIM, so we could move the mounting position out of the center of the robot.
I don't know enough about this form of power transmission. I'm doing some research, but I'm hoping someone may be able to share some experiences with these gearboxes! Right now, one of my biggest concerns is that these gearboxes typically use worm gears, which, as I understand, are impossible to run in reverse. Which, if this is going to be part of a wheel set-up, tends to be an important feature...
If you have any experience using 90 degree gearboxes, I'd love to hear your thoughts on them!
-Leeland
My heart will forever lie with SparX
1126: 2008 - 2011; Where it All Began.
1405: 2013 - Present; A Wanderer is Born.
Work hard, play hard. And maybe someday...
Unread 31-07-2012, 10:54
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
Re: 90 Degree Gearbox?
A worm gear is a commonly used method for a 90 degree gearbox. And they can run in reverse, however they are usually hard to impossible to backdrive. In other words when you stopped applying power the wheels would come to a stop very quickly.
Another option for a 90 degree gearbox would be the gearset used in most angle grinders and angle drills. These use bevel gears and will be easy to backdrive.
Something else to consider is the reduction. Bevel gears will allow reductions similar to normal spur gears like you're used to working with, while worm gears are usually more suited to higher reductions ratios.
KK4KQO
http://voltair.us
Unread 31-07-2012, 11:01
LeelandS's Avatar
AKA: Leeland
Okay, I was confusing "anti-backdrive" with "can't be reversed".
I'm thinking now that bevel gears will be the way to go. We're going to be looking for normal gear reductions from this box. Definitely nothing high enough to justify using a worm gear.
Chris is me's Avatar
AKA: Pinecone
Worm gears work in both directions. For example, the Window motor transmission uses a worm gear. However, they tend not to backdrive very easily, or at all, depending on their design and efficiency. The biggest problem with a worm gear drivetrain would be the relatively low efficiency. Due to the way the worm gear interacts with the worm wheel, the design is inherently less efficient than a standard spur gearset. For a drivetrain this is particularly important.
A more efficient solution (but still less efficient than regular spur gears) would be to use bevel gears. These come with their own problems with alignment and thrust loading, but they aren't unsurmountable. Here's an example by team 192.
Generally I think efficiency is much more important in a drivetrain gearbox than packaging, so I'd use a regular spur gearbox in a drivetrain most of the time. Depending on your drive layout you may be able to arrange the transmission with the CIMs over the wheels to save space.
Unread 31-07-2012, 11:07
LeelandS's Avatar
AKA: Leeland
I thought the same thing. The spacing of the CIM is more of a "Nice to have" than anything else, so we're not trying to make our designs revolve around that idea. However, it is an interesting challenge, so we're trying to make this gearbox meet as much of the requirements as possible.
I'm looking into bevel gears right now. Fortunately, I do have some experience with these (as 1126 ran swerve this past season, using bevel gears in the module).
Unread 31-07-2012, 11:41
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
AndyMark sell their WormBox
Take a look
Unread 31-07-2012, 11:44
aechmtwash11 aechmtwash11 is offline
FRC #2783
aechmtwash11 is an unknown quantity at this point
Heres how 2783 solved the issue last year. Standard nano toughbox reoriented and a few modifications to the output shaft to allow for reorientation. (just had to add another snap ring to hold everything in place)
Unread 31-07-2012, 13:34
AlecMataloni AlecMataloni is offline
Excellence is Bliss
AlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond reputeAlecMataloni has a reputation beyond repute
Depending on how your frame is designed, you could mount the CIMs above the drivetrain like 971: https://picasaweb.google.com/lh/phot...t=d irectlink
Of course, this isn't a COTS solution, if that's what you're looking for.
Unread 31-07-2012, 13:35
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
If you go the bevel gear route, you will want as much of the gear reduction after the bevel gearset as possible. This is why you see so many coaxial swerve modules with very large sprockets on the wheel. The higher the reduction before the bevel gearset, the more force there is available to push the bevel gears apart (which they will do by default), ergo the thrust load issues Chris mentions.
The other issue with bevels is that they're relatively less efficient than spur gears at low pitch (bigger, deeper teeth), yet very easily chatter and separate at high pitch when under load (especially on a vibrating platform like a FRC robot or an aerial quadrotor). Spacing & rigid mounting are crucial with higher pitches.
GitHub
Unread 31-07-2012, 14:07
Leeland,
I would be remiss to not remind you that the CIM output bearings are not designed for high side loads. If you intend to use them, be sure to add bearings or couple to another shaft with bearings to take the loads. I have seen several CIMs used as the direct input for a worm drive only to have the motor fail when the bearings become worn.
Unread 31-07-2012, 14:44
AdamHeard's Avatar
Lead Mentor
Those aren't bevel gears, but rather a 4 start worm gear that is pretty high efficiency.
that design was first run by a student on 1425 in the 2007 season and I was very impressed by it. He argued that the efficiency of a single 4-start worm gear is comparable to the 2-4 stages of reduction of lower quality gears most teams use. It was likely still more efficient than many teams.
A worm gear of that style is also easily backdrivable.
Unread 31-07-2012, 21:03
Gray Adams's Avatar
Gray Adams Gray Adams is offline
Gray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to beholdGray Adams is a splendid one to behold
They're interesting to try, but ultimately I bet you could achieve similar results with CIMs over the wheel/frame. If you did both...that would be one hell of a space saver.
As for performance, the worm gears will break in over the season and driving dynamics will change. A robot that used to stay still on the bridge suddenly begins to roll at champs. The bot wont be able to be pushed by hand easily on week 1, but by champs it should roll...like a champ. Coasting gets easier and the gearboxes get quieter.
I think my team is working on making it removable from the frame without intruding into the center at all. As it is, a gearbox replacement means all the electronics have to come out, which really negates some of the benefits of space saving.
Unread 31-07-2012, 21:13
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
971 this year moved the CIMS over the wheel/frame. On their picasa they have pictures. Its a really really sweet setup!
-RC
R.C.
MadTown Robotics Team 1323
Unread 31-07-2012, 21:40
Gray Adams's Avatar
-RC
I was thinking of their bot specifically when I wrote that, but I guess I failed to mention them. This is what I get for trying to post from my phone.
Anyway, 971's setup is really nice, we got to spend a good amount of time chatting this season at Davis, SVR, and Champs. The fan, the mounting of the cims (and the entire rest of the robot) are all pretty fantastic.
Unread 31-07-2012, 21:53
kevin.li.rit's Avatar
Imaginary Friend
AKA: Kevin Li
FRC #0596 (SciClones)
Team Role: Student
Originally Posted by LeelandS View Post
Hello CD Community!
-Leeland
Dust off the old finney photo album and take a look at the 2009 Robot!
The output shaft of the CIM is pointed towards the sky. I may or may not have the detailed drawings somewhere.
Kevin Li
596 - Sciclones
1405 - Finney Falcons
2262 - Holliston Panthers
