Go to Post You know what they say, the mind is the second thing to go and I can't remember the first. - GaryVoshol [more]
Go Back   Chief Delphi > Technical > CAD > SolidWorks
Unread 02-08-2012, 03:23
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Lightening Pattern Help?
Originally Posted by Adam.garcia View Post
Thanks to the both of you. I have updated the gearbox. Is there anything else that you can see that should be improved upon/changed/added?
What purpose does the inner snap ring groove serve on the output shaft?
2001-2004: Team 100
2006-Present: Team 254
Unread 09-08-2012, 10:36
Adam.garcia Adam.garcia is offline
Design Mentor
FRC #0004 (Team 4 Element)
Adam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really nice
Sorry about the late response. The inner Snap ring is designed to hold the other side of the wheel in place. I added this feature to the output shaft to ensure that the wheel would be held in place. If I were to take it out, what would prevent the wheel from sliding inwards?
“The object of education is to teach us to love what is beautiful.”
“Never discourage anyone who continually makes progress, no matter how slow.”
Unread 09-08-2012, 10:55
Peck's Avatar
Peck Peck is offline
worse then failing: proving murphy
FRC #1619 (Up-A-Creek Robotics) and FTC # 4633)
Peck will become famous soon enough
just wondering: did u stress test these plates, including for collisions that may be less then ideal?
edit: o, and did u example the irl ability to travel to ensure the gears stay where u want and don't generate undesired interactions?
Cad, Electrical, Machining, Debugging (old school), PR, Distraction elimination
TEAM 1619
__UP-A-Creek Robotics__
It ain't done till it's over-done
Unread 09-08-2012, 14:42
Cory's Avatar
AKA: Cory McBride
is this for a standard cantilevered wheel drivetrain?
If so, your wheel is captured by your bearing block in the outside of the frame rail.
If not, add a spacer. Your shaft is all but 100% guaranteed to fail at that snap ring as it stands.
There's no need to perform FEA on those plates. By visual inspection they look similar to multiple other successful gearboxes. 1/4" Aluminum plate is ridiculously strong, even pocketed out like that.
2001-2004: Team 100
