Go to Post Math, it's great stuff - AdamHeard [more]
Unread 08-06-2012, 12:01 AM
jamie_1930's Avatar
jamie_1930 jamie_1930 is offline
FRC #2228 (Cougartech)
Team Role: Student
jamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to beholdjamie_1930 is a splendid one to behold
Re: 2008 Festo Solenoid
right now just based on the assumption of 1 watt.
P=EI
P/E=I
1W/12V=.0833333A=833mA
E=IR
E/I=R
12V/.083333A=144ohms
Tomorrow I'll hook up the compressor and give this a try. Also if anyone was wondering the project is basically a claymore for airsoft games. I've already assembled most of the project, but when it's done you'll be able to stake down the claymore and run back to a position with the clacker (not sure if that's the technical term but it's the switch I'm using to set off the claymore) and then when you hit the switch it'll shoot baking soda, flour etc. (In airsoft most claymores and mines shoot flour or a similar material instead of bbs)
Team 2228(FRC) - Drive Team Lead, Drive Coach, Mechanical Team
Team 3750(FTC) - Team Lead
2009
Team 2228(FRC) - Mechanical Team, Driver at RIT, and Hartford Regionals, and Drive coach at Ruckus
*Second Place at Ruckus
Team 3750(FTC) - Team Lead, and Drive coach at Clarkson Regional
*Second Place at Clarkson Regional
2008
Team 1930(FRC) - Worked on Mechanical, Electrical, and Programming.
