Go to Post Inspiration is a two-way street. - Taylor [more]
Unread 06-08-2012, 18:18
Re: How do I program a joystick deadband?
Originally Posted by F22Rapture View Post
Does this appear to be correct?
You've created a new function, but haven't called it. In order to do the equivalent of the commented out code, you would need to add another line similar to the following
double turn = turn(Xbox);
(I'm not very experienced with java, so it might not even compile with having variable named the same as a function). Notice how this isn't exactly clear, which is why Djur recommended renaming turn to something more generic. Doesn't this sound better?
double turn = applyDeadband(Xbox);
There's probably a better way to write the deadband function so that you could apply it to the throttle also easily without creating a second function. Can you think of another way to do it?
