Go to Post I like how the photo is of John Neun, and everyone is still making fun of John V-Neun - Jay Trzaskos [more]
Unread 10-01-2003, 18:34
maxgebhardt's Avatar
maxgebhardt maxgebhardt is offline
resident insomniac
#0555 (we dont have a team name, and what are you gonna do about it!)
Team Role: Student
maxgebhardt is on a distinguished road
Send a message via AIM to maxgebhardt
deadline
arg! if anyone has any clue about the specs contribute it, seeing as we all need the drive trains finished soon, in my case Monday (originally), but without output data, I'm not sure I'll meet that deadline for my team. also, if anyone can clear up the figures given on sprockets by MSC, it would be appriciated seeing as I'm at a disadvatage with no engineer help this year.
Unread 10-01-2003, 20:41
President, VEX Robotics, Inc.
Look Here
I have compiled the data. Most of which is in the manual where the drill motor is listed, but I had to experimentally determine the free amps.
Look here:
http://www.chiefdelphi.com/forums/pa... SC&sort=date
You will find data for the Fisher-Price, Drill and Chiaphua. I am 100% sure about the Fisher-Price and Chiaphua, but 95% sure about the drill. From my initial test, the numbers look good.
The link is to the white papers section from a presentation I gave at the Novi Kickoff. I updated the motors with the new information. This should be enough for you to get working until FIRST gets their numbers together.
Please note that there is another white paper regarding the Fisher-Price motor that I posted. It is the motor manufacturers data sheet and it corresponds with my number in the presentation.
-Paul
Unread 10-01-2003, 23:18
resident insomniac
Team Role: Student
thank you
Always remember... "with sufficient thrust pigs fly just well thank you."
team motto:
Trust, Love and Magic 2003
AFLAC 2002
Will stop for broken speed controlers 2001
{CPA}Maxzilla UT 2004
Unread 12-01-2003, 20:58
Umm Errr...
a word of advice. if get the brilliant idea of hooking the drill motor and gearbox directly to the battery , be sure u are holding both parts of the transmission. This tranny does not stay together well!!
1139 Alumni
Unread 12-01-2003, 21:38
gc02 gc02 is offline
gc02 is on a distinguished road
Drill Specs
The specs for Bosch 3360 drill, which is where I'm guessing this motor comes from, on the boschtools.com web site lists the drill as having a stall torque of 400 lb-in (45.3 N·m) and a no-load speed of 450 rpm in low gear. Doing a little math that gives it a stall current 185A at 12V and a peak power output of 527 watts. In high gear you'd get stall torque of 12.7 N·m and a no-load speed of 1598 rpm and with no gear box you'd get stall torque of 1.06 N·m and a no-load speed of 19170 rpm.
Greg
Enigma Industries
Unread 13-01-2003, 09:35
ROB at RAGE ROB at RAGE is offline
ROB at RAGE is an unknown quantity at this point
The motor stall torque is also in the parts list, this times the reduction ratio and assume the efficiencies are similar to the old transmissions, 80% in high and 70% in low. This will get you most of the way. Remember the torque of D.C. motors is linear between max at stall and 0 at free speed RPM.
Unread 14-01-2003, 17:46
DanielJay's Avatar
DanielJay DanielJay is offline
#0035 (Sigma Squared)
DanielJay is an unknown quantity at this point
Send a message via AIM to DanielJay Send a message via Yahoo to DanielJay
has anybody gotten the specs from the manufacture? I must have missed the specs and I am looking all over for the specs from the manufacture. Can anybody help. Please attach the file to the forum and I will get back to it. Thanks.
DanielJay
Webmaster, Electrical, And anything else
www.wlhosting.com - for all of your hosting needs.
Unread 15-01-2003, 15:08
KennethToronto's Avatar
KennethToronto KennethToronto is offline
#0820 (Delta Tech)
KennethToronto is an unknown quantity at this point
Send a message via ICQ to KennethToronto
Drill motors: 19670 RPM
Drill motors (with gearbox in low): 461.52 RPM
Drill motors (with gearbox in high): 1629.66 RPM
So are these numbers correct? I've been checking out all the threads about the drill motors and these are the only numbers I've found.
North Toronto CI
Delta Tech Team 820 Robotics
Unread 15-01-2003, 16:29
First posted a bunch of specs today:
http://www.usfirst.org/robotics/2003/specsheets.htm
Be careful though, the "drill motor" specs seem to be for two different motors. Was there more than one type of drill motor in the kit?
Greg Christensen
Enigma Industries
Unread 15-01-2003, 19:37
resident insomniac
Team Role: Student
thank you
I bow down to your superior ability to stand the first ability to not post things and hunt them down! now maybe I can actually get some work done! thank you!
team motto:
AFLAC 2002
Unread 15-01-2003, 19:49
rbayer rbayer is offline
Blood, Sweat, and Code
no team (Teamless Orphan)
Did anyone else notice that the Drill Motor curve is for motors running at 11V? Any ideas on how a 12V setup would compare? I'm guessing it's almost identical, but then again, strange things happen when you up the voltage to motors.
Unread 15-01-2003, 21:22
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Greg Christensen
Enigma Industries
Could it be that the specs are for Forward and Reverse?
Just a thought!
Unread 16-01-2003, 08:35
Matt Leese Matt Leese is offline
Been-In-FIRST-Too-Long
FRC #1438 (The Aztechs)
Matt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond reputeMatt Leese has a reputation beyond repute
Send a message via AIM to Matt Leese
I'm even more confused by the drill motor gear specs (assuming that's what they specify). From the looks of things, it specifies a 13 tooth gear at a 20 degree pressure angle. Now, I counted the number of teeth on the output gear of our motors. It was most definitely 15 teeth. I only counted one motor but I'll check out the other one tonight. Anyone know what's up with that?
Matt
Unread 16-01-2003, 09:42
Just a thought!
If you look at Skill Bosch Motor Curve the motor's part number is different from the part number listed in the kit of parts documentation.
Greg
Enigma Industries
Unread 16-01-2003, 09:52
It Checks Out
The part number on the motor data curve IS the same number as printed on the motor. The FIRST manual is inaccurate. The raw numbers printed in the chart for 12V (lower left corner) checks out with what FIRST gave us and with what I noticed for free amps.
-Paul
Portable cordless drill press Gui Cavalcanti Technical Discussion 25 03-08-2003 22:21
drill motor mounts- again Jeff Sharpe Motors 6 07-04-2003 23:20
Emergency drill trade/sell Anarkissed General Forum 3 16-02-2003 22:37
Q&A Discuss: HOT drill motors CD47-Bot Extra Discussion 1 27-01-2003 13:31
