Go to Post Chief Delphi down for a few hours ON A WEEKEND??? This is MADNESS! - [more]
Unread 08-08-2012, 20:13
Gigakaiser Gigakaiser is offline
AKA: Brandon Hjelstrom
FRC #0987 (High Rollers)
Gigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant future
Re: Autodesk Inventor Question
SOLVED:
Here is the solution if anyone else needs it:
-After you create the assembly (in my case the left drivetrain) create a new PART.
-Go to manage->insert->derive and select your assembly. There are extra options that will change depending on your needs in this window.
-Go to the options tab
-select "mirror"
Now you have a second "assembly" to place in your final robot assembly. Since it is derived from the first (left drivetrain) changing the first assembly will update both. This is very useful, especially for those designing symetrical components.
FRC Team 987 - It's not enough
Unread 09-08-2012, 08:12
ttldomination's Avatar
Sunny
Good guy OP.
Posts solution to his problem when no one answers with a solution.
Thanks,
Sunny G.
1648: 2013-2014
5283: 2015
