Go to Post So remember, we may be envious of teams who can do water jet cutting and has every possible monetary and engineering advantage, but there are many more people who are envious of every team who has a chance to compete. - Rombus [more]
Unread 09-08-2012, 12:52
realtime runtime code throughput margin monitoring
I'm wondering how many teams add runtime throughput and scheduling monitoring in each thread (or parallel loop) of their practice or even competition deployed code.
Something like the following
* thread start *
t0=system_microseconds();
if (t0-t1)>TBD1 err1++; //scheduling monitor
t1=t0;
* put thread code here *
if (system_microseconds()-t0)>TBD2 err2++; //thread throughput margin monitor
* thread end *
"err1" and 'err2" could be displayed on the dashboard for each thread.
Unread 09-08-2012, 19:34
Todd's Avatar
Todd Todd is offline
Software Engineer
FRC #1071 (Team Max)
Todd is just really niceTodd is just really niceTodd is just really niceTodd is just really niceTodd is just really nice
Re: realtime runtime code throughput margin monitoring
I'm planning on going through this exercise with our students next year. I meant to this year, but we fell short of time.
As far as I see it's the next step toward system stability after we work out a few more of our selective failure cases.
Unread 09-08-2012, 20:11
plnyyanks's Avatar
Data wins arguments.
AKA: Phil Lopreiato
We had this in our code, to a certain extent. We sent loop execution times to our custom dashboard, where they would be monitored and used to check that everything was running okay. If our main loop ever ran much over 20 ms per iteration, then we'd be worried (the vision loop ideally would be at about 100 ms). Code for reference.
Unread 09-08-2012, 20:25
Were they monitored by software in the dashboard which counted and flagged individual outliers, or did you mean they were monitored by the driver (whenever he had a chance to glance at the screen)?
Unread 09-08-2012, 20:38
The LV template project contains a folder called Support Code. In it is a VI called Elapsed TImes.vi. Placing it into any loop or recurring code will result in a table of elapsed times being updated to calculate and show the period of the calls. The easiest way to view the times is to open the Elapsed Times panel. This is typically used for debugging and later deleted, but could be transmitted back to dashboard if a team wanted. I have no idea how many times it was used.
Greg McKaskle
Unread 09-08-2012, 20:48
plnyyanks's Avatar
AKA: Phil Lopreiato
The latter. Although, while debugging, writing, and tuning code, they were watched very closely and we didn't let the code go into "production" until functionality was there, as well as low loop times/CPU usage.
Thankfully, it was never necessary to actively monitor these, although having software do it is a good idea for next year.
Unread 09-08-2012, 20:52
Greg, do you know roughly how much runtime overhead is incurred by this? e.g. Could it reasonably be put into all the parallel tasks in an FRC robot project?
Unread 09-08-2012, 20:55
How often was your dashboard screen display updated?
Unread 09-08-2012, 21:05
plnyyanks's Avatar
AKA: Phil Lopreiato
Not all that often (I don't remember, but maybe ~200 ms). Which, of course, now that I think about it, doesn't really help catch situations like you're thinking of... Anyway, it's a good idea to implement next year.
Unread 09-08-2012, 21:35
I don't have an overhead number, but I have seen it raise the CPU. The code is in about six loops in the Driver Station and I saw no need to delete it. I decided not to leave it in the default robot code loops and chose to let teams do it for themselves. I hope to get around to adding some high-water mark and stats to it and perhaps I can find a way to leave it in all loops. Time will tell.
Greg McKaskle
Unread 09-08-2012, 21:59
JamesTerm's Avatar
JamesTerm JamesTerm is offline
Terminator
AKA: James Killian
FRC #3481 (Bronc Botz)
JamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to beholdJamesTerm is a splendid one to behold
[/i]
I've taken a low-tech solution to this type of task... where I use printf statements that can be turned on by ftp of lua script... I get roughly 10-11ms iterations of a single thread (I cannot see the need for any more). All functions work with a delta time (double dTime_s) parameter to deal with uneven slices of time... this way I need not do anything fancy with the Sleep(10).
For the numbers I find interesting I use a separate homemade app to read the text and translate into a bmp file graph. So it's paritally real-time... partially post process.
Unread 09-08-2012, 22:13
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
We ran a slightly modified Elapsed Times in our robot code, and it wasn't the biggest cause of CPU usage (sorta...)
The biggest cause of CPU usage while not permanently deployed seems to be updating VI front panels. If you have enough inclusions of Elapsed Times, it seems to update the front panel array every time it changes (Every tick of every loop). If you create a slower loop somewhere (we ran ours at 75ms I think) to read the array of times from Elapsed Times, it is significantly less CPU hungry than simply opening Elapsed Times. We used the same loop to read the CPU load cluster and print it to the same debug screen, and that information (CPU usage by thread priority) was also extremely useful.
It was a very useful VI. We had it in about 10 or so tasks.
Kettering Motorsports
Unread 10-08-2012, 07:29
If you create a slower loop ...
Good to know. The panel was the simplest way to see the data, but it will transmit all modifications to to the host each call, and the array is constantly changing. Maybe something like that will allow it to be in the framework by default.
Thanks.
Greg McKaskle
