Go to Post As we were lying the robot down to work on it "CAD me like one of your french robots" - 1uan [more]
Unread 12-01-2003, 12:22
Engineer at Medrobotics
AKA: Dr. Joe
FRC #0088 (TJ2)
The strong get stronger...
I want to explain why I think this new ruling gives strong team control of their destiny.
A strong team (let me use Wildstang #111 as an example), will very likely build an elevator machine in light of the new rules (those of you in FIRST long enough to remember Torroid Terror, Ladder Logic and Coopertiion FIRST will know that for a while Wildstang's slogan was "it can go higher... ...no really... ..it can go higher" -- I suppose that the Torroid Terror Machine could easily lift a crate 16 ft a.k.a. 13 SHU's perhaps higher and this was with a 4ft limit on the robot hieght -- YIKES!).
With such a robot and some indexing software, a team can essentially give an opponent any multiplier they choose. As long as an opponent has 16 or so containers on their side of the field (this boils down to 8 additional to the 8 from the human players), a strong team can pretty easily give or subtract 50 points from an opponent’s score very easily.
Need to boost your opponent’s score a bit? Easy. Raise a single box 8 high to give them a quick 64 points.
Would you rather only give them 30 points? That's easy too, just raise the container 2 SHU's?
How about just 15 points? Run out of the scoring zone.
Need to give 44 points? Raise it 4 SHU's and race back into the scoring zone.
Need to reduce that 50 points for the two robots they’ve got sucked down to the HDPE surface? No sweat, push a few containers out of their scoring zone and lift one container 1 or 2 SHU’s higher than the number of remaining boxes.
Never has a single talented robot had their opponent’s score so firmly in their control and so easily adjusted.
Notice that it does not even really require much work by an alliance partner. For this reason, I think strong teams that play smart will end up on the top of the seeding charts very quickly.
To some extent, I think that is the way it should be, but I doubt many realized that this new rule interpretation would add to this outcome.
I think it will be a total disaster to watch this as my mom will be always asking me, “Why did they just do that?” But that is a message for another thread.
Joe J.
Unread 12-01-2003, 12:35
Joel Glidden's Avatar
Joel Glidden Joel Glidden is offline
My heart pumps diesel.
FRC #4293 (Komodo)
Joel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of lightJoel Glidden is a glorious beacon of light
So, what happens when two strong alliances face off? If they both use the tactics detailed in the previous post, it becomes a game of chicken. Does it not? I'd like to hear some full-match scenarios that explore this line of tactics.
In any case a game of "my box is higher than your box" doesn't sound very interesting to me.
-Joel
Unread 12-01-2003, 13:14
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
yes i agree...
not interesting and not in the spirit of FIRST. i would just like to say to all teams who use this strategy, be warned that many teams will likely knock you over. so build robust because that arm that can raise a bin 17 shu's might get shattered if it falls onto a player station/field railing.
i don't see why so many people think that's a good strategy...if a team has a pusher bot with some sort of arm for pushing boxes off stacks, they can easily knock you over. you probaby won't be able to move easily, mostly because your center of gravity will be 8' in the air (assuming you build one really really tall).
so while it seems clever, you need to assess every possible situation...
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 12-01-2003, 13:45
meaubry meaubry is offline
volunteer helper
FRC #6099 (Knights)
meaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond reputemeaubry has a reputation beyond repute
For the most part, robots that are able to lift high will be careful to not drive around or engage in battle with the arm raised way up high (they know about cg management, or will learn after tipping over once). There will be mechanisms that will lift high in a relatively short time period (say, 3 seconds). It possible and most probable.
Unread 12-01-2003, 15:48
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
and the HITS get harder...
It seems to me that this game has a plethora of defensive moves. There may be team's that place boxes at 13+ SHUs, but with their bot that high in the air, Sir Issac Newton won't be so kind to them in a collision.
I'm afraid that faced with a loss due to a single box raised high above the field, alliances will simply go all out ramming the lifting robot. Simply having a powerful drivetrain, and a well built "ramming bot" that possibly travels under the bar will allow you to play an effective defensive game.
*Pushing boxes out of the score zone.
*Knocking down stacks.
*Knocking other robots off the ramp (especially those that try to control the ramp with brute force).
*Pushing other robots out of the scoring zones.
*Knocking over other robots "GASP!"
These defensive moves can all be accomplished by a simple drivetrain, if done correctly.
I feel that this will result in more defensive robots. Successful defensive robots... I think they will come from all levels of the competition, not just the "strong" teams.
Wildstang (hypothetically) may have their amazing lift mechanism. But there will always be the ambitious rookie team trying to overpower them with some amazing drivetrain (like 810 last year).
So in conclusion...
The strong get stronger, but so do the weak. This game isn't fair, but it keeps things in balance.
Unread 12-01-2003, 16:15
redbeard0531 redbeard0531 is offline
#0686 (Bovine Intervention)
redbeard0531 is an unknown quantity at this point
Send a message via AIM to redbeard0531
do you think that it is more "fair: than the original rules?
Unread 12-01-2003, 17:20
Ian W. Ian W. is offline
College? What?
no team (Gompei and the Herd)
so, if i was to simply take last years robot, give it a lift job, cut a few pounds off, and add some sort of wedge to push crates, 810 would do good, or so you say...
AIM --> Woloi
Email --> ian@woloschin.com
Unread 12-01-2003, 17:24
D.J. Fluck
Posts: n/a
If you raise that tote 10 SHU in the air, unless you are really good, you could be shoved around and tip over, and chances are that the referee would let it go since they allow ramming and they are expecting it.
I highly reccomend not using this tote raise strategy. Too much to risk, by chance you aid them and then you accidently lose could be costly. Also if you fall over, you risk breaking expensive parts.
Unread 12-01-2003, 18:04
DanLevin247 DanLevin247 is offline
Missing In Action
#0247 ('da bears)
DanLevin247 is on a distinguished road
Send a message via AIM to DanLevin247
Not to mention that a robot with a massive arm could be tipped over, possibly causing someone near the field to get hurt.
'daaaaaaaaaaaaaa bears!
It's all fun and games till someone gets hurt.....then it's hillarious!
Unread 12-01-2003, 18:25
Andy A. Andy A. is offline
Getting old
FRC #0095
I fear for bin raisers.
Personaly, if I were behind the controls and I saw a opposing bot trying to mess with my score like that, I'd try to stop him. That probably means ramming him, either to convince him to do something else or to tip him over if he doesn't stop. A few 'warning' taps, then I'd start hitting hard.
I don't want to see broken bots anymore then anyone else (possibly less then some), but if your pulling a strategy that puts your CG that high up your asking to get rammed. After all, you're controling a lot of points, you're probably immobile and very vulnerable. Who wouldn't go after you?
The real strong bots will figure out a way to keep from being tipped. Thats what I'm eager to see.
-Andy A.
Unread 12-01-2003, 19:01
Mike Norton's Avatar
Mike Norton Mike Norton is offline
FRC #0061
Rookie Year: 1995
Mike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to allMike Norton is a name known to all
I would love to see a robot try to play with our score. With robots last year, I know of 3 robots on their backs. and they were only about 2' in the air total. robots do go over in pushing matches. so if a robot thinks it is going to keep one of our points in their jaws there better think about it. It will be like you getting between a baby bear and it's mother.
I think this game this year will come do to who wants to play together during the seeding rounds.
You can get a big score if you make a plan with the other team. One could be as not to touch your stack. by doing this you could have a 8 high stack to start. this way if you lose you would lose with a high score.
If you tied then even better. I figure you can get 324 point if you tied the game. 14 bins on each side all robots on top. this would be hard enough to do. but if you do not do your half then that give the other team twice your score which would be a good score.
so were in the past if someone told you that they could do something and didn't do it, it was at your lost. this way if people don't do what they say you make out better.
Unread 12-01-2003, 19:15
illumanat'i's Avatar
illumanat'i illumanat'i is offline
make me care
#0555
Team Role: Student
illumanat'i is an unknown quantity at this point
Send a message via AIM to illumanat'i
you don't even have to tackle another robot, all you have to to is roll up to it and touch it... the box its holding insantly become void, useless.
their is no need to go ramming robots, just let them waste time by screwing with your points and then go and lighting tap them on the shoulder
the heavy lifting arm might mean it has less pushing power on its wheels, push the robot into a corner and watch it struggle to move as you laugh and laugh and laugh.
did i mention laughing at the stupid box lifters ('cause their stoopid)
Trust, Love, and Magic
Unread 12-01-2003, 20:10
Adam Y.'s Avatar
Adam Y. Adam Y. is offline
Adam Y.
no team (?????)
Yeah errrmmmm that would be very topheavy. We had a hard enough time last year trying to keep a robot 6ft high from falling on it's own. Mmmmmm... topheavy robots. I love it. Makes it easier to win.
Thats not a nice thing to say. It is a good idea. 16ft stackers now that I would have to laugh at.
Unread 12-01-2003, 20:41
Justin's Avatar
Justin Justin is offline
Never Forget FIRST 1992-2000
Justin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant futureJustin has a brilliant future
Send a message via AIM to Justin
Null and Void if....
Okay So,
I was reading through this thread...and it occured to me that this conversation would be a mute point and this game much simpler if we didn't have to worry about the 2X the looser's score detail. I remember back in the days when QPs were QPs and FIRST was a compeition. The winer won, and the looser lost, as happens in the real world. I think that this analogy actually does represent the corporate world offten this is a very dominant player and there our other less dominant players. How offten however do you see Microsoft and AOL actually truly working to help each other, sure they might if it is profitable but I just don't know. In addition I think that it is just much more fun to have a true competition some teams win some teams loose and that reflects _LIFE_. It would make this game much simpler I think.
-Justin
Rookie Year: 1996 (Hexagon Havoc)
Robots: Hexcalibur (96), Blue Dragon (97), El-e-Vador (98), Astrobot 2000 (99), Last Chance (2000)
Unread 12-01-2003, 22:19
skrussel skrussel is offline
no team (000)
skrussel has a spectacular aura aboutskrussel has a spectacular aura aboutskrussel has a spectacular aura about
Hi Joe!!
Hey Joe, I just want to say that it's good to hear from you again. It's just not the same, y'know?
Regards, Sue K.
No Change Rule Yields More Openness archiver 2001 16 24-06-2002 01:23
Work Safe, Play Safe, Pick Safe archiver 2000 8 23-06-2002 22:37
547 "FOWL PLAY" Pictures - Strong, Reliable Mike Rozar Robot Showcase 1 07-04-2002 11:59
How fast, how strong, how long? Wayne C. General Forum 6 24-01-2002 21:32
Team 121's Petition is just about to end Kyle Fenton General Forum 10 27-06-2001 14:30
