Go to Post In any case, don't beat yourself up over it. Only 24 teams get to play in elimination rounds. Sometimes you're in the 24, and sometimes you aren't. - jgannon [more]
Unread 11-08-2012, 04:19
yarden.saa's Avatar
yarden.saa yarden.saa is offline
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
yarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond reputeyarden.saa has a reputation beyond repute
Chains
Hi,
My team has a metal factrory that helped us in this season. We want to improve the way we are using our resources. We are going to make drivetrains like this http://www.chiefdelphi.com/media/img...64ffa096_l.jpg from sheet metal. The problem we had this season was the chains; it was hard to connect and disconnect the chains because it was tight. it is almost a closed system so we had to put the gearbox not inside the drivetrain as you can see in the photo attached.
So my question is: What the other teams that build sheetmetal drivetrains do in the case of chains?
Yarden
2016 - Curie Sub-division Winners, Regional Winners
2015 - Carson Sub-division Winners, Regional Winners
2012 - 3339 Captain and Dean's List Finalist
Unread 11-08-2012, 05:34
androb4's Avatar
androb4 androb4 is offline
..is trying to take this year off.
AKA: Andrew A.
androb4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to beholdandrob4 is a splendid one to behold
Re: Chains
If I am reading this correctly..you mean that there was too much tension in the chains??
This is when chain tensioners come in. Make the chain the next smallest size and add a chain tensioner.
You can use this: http://www.andymark.com/product-p/am-0286.htm
Or for a more DIY approach: Cut a 1 1/2" long, 1/2" PVC down the middle of the circle. Make notches for zip ties with a file. The attach it to the chain.
FRC 441 Mentor 2012-2015
FRC 441 Alumni 2009-2012
FTC 4673 Alumni 2011-2012
FRC 1484 Alumni 2006-2008
Unread 11-08-2012, 06:31
yarden.saa's Avatar
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
Re: Chains
No, I meant that there is not enough work space in order to connect and disconnect the chains
Unread 11-08-2012, 06:45
Billfred's Avatar
Billfred Billfred is offline
Re: Chains
Funny you should ask this--we ran into this quandary on our 2010 robot that I had to dig for photos on.
Our fix that year was to pull the side of the drive system off, fix it, and put it back on. That would involve drilling out ten rivets, which isn't TOO bad...but we put them on tight enough that across five events and two robots we never really had to do it.
Unread 11-08-2012, 07:24
yarden.saa's Avatar
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
Re: Chains
As one of our mentors say: "we have a real estate problem".
We don't have problem during events, but we want to put the gearbox inside and when we tried to do so it was almost impossible dealing with chains.
Unread 11-08-2012, 07:45
Billfred's Avatar
Re: Chains
One thing that can help is visible in that photo: those white plastic cylinders allowed us to route chain around things (such as the space the bumps that year would occupy). That year's gearbox setup was basically the guts of an AndyMark Shifter (plus another input gear as an idler to fit the third motor), so a Toughbox or CIMple Box would be even easier to implement.
The key, as ever, is good planning and starting with snug chains. I would try it out as a prototype before putting it into production on an FRC robot.
Unread 11-08-2012, 13:04
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Chains
I hope some teams that have enclosed drivetrains can comment on some of their ways to address this.
The short version is that it's a design issue. You need to consider the chains and create access to them for installation and service. It could be as simple as a removable plate.
Unread 11-08-2012, 13:24
artdutra04's Avatar
VEX Robotics Engineer
FRC #0148 (Robowranglers)
Re: Chains
If you recruited a sheet metal sponsor and would like to pursue drive trains like the one you linked to; simply make the outer chassis rail removable. Then you can take the entire outer rail off to access the wheels and chain.
If you are going this route, calculate your chain paths ahead of time and design for an exact number of chain links. Then when it comes time to assemble the drive train, you can simply make all the loops of chain ahead of time and pop them in place as you mount the wheels, sprockets, and any spacers or shaft collars.
For tensioners, you can use floating idlers in the chain runs, or add a lot of standoff mounting options in the drive train. Press a Delrin sleeve over the standoffs and then move the standoffs around as necessary to act as a chain tensioner.
Art Dutra IV
世上无难事,只怕有心人.
Unread 11-08-2012, 17:13
Tom Line's Avatar
Tom Line Tom Line is offline
Raptors can't turn doorknobs.
FRC #1718 (The Fighting Pi)
Re: Chains
We've always used enclosed drivetrains from our first bot back in '07.
Our method has always been to make the axle out of a shoulder bolt with a single nut. Pop the nut off and remove the axle and the wheel can drop out the bottom. Work on the chain to your heart's content, then replace the wheel. Of course, doing this requires exactly what Art mentioned - you have to know your centerpoints ahead of time, or use tentioners on the chains.
At nationals this year we were across from Wildstang. During pit setup day, they pulled their ENTIRE right drivetrain off with just a couple fasteners and serviced it. I pointed it out to our kids so they could get a couple ideas.
Unread 11-08-2012, 20:50
Pauline Tasci's Avatar
Pauline Tasci Pauline Tasci is offline
Rockets and Robots
FRC #3476 (Code Orange)
Pauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond reputePauline Tasci has a reputation beyond repute
Re: Chains
We encountered this too, I think this is where the first couple weeks of design really help. When designing you really have to think about how to get to every part of the robot in case of repair. We simply made all the pieces next to the drive system easily removed. We welded where we knew we would not need touch ups and screwed in where problems would usually occur.
Team 3476 Code Orange- 2014-? ~ Head Mechanical and Design Mentor
FIRST Orange County 2015-? ~Regional Planning Committee Member
Beach Blitz 2016-? ~ Event Chair/Director
FIRST Volunteer-2010-?
Team 589 Falkon Robotics- 2010-2013 ~Captain, Driver, Outreach, Mech Lead
CD Moderator~ Always feel free to PM me.
Facebook
Unread 11-08-2012, 23:27
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Re: Chains
Additionally, the mounting holes for the rollers were slotted, so that they could move in and out to help tension the chain.
The axles for both the wheels and rollers were tapped at both ends; to drop them from the bottom of the drivetrain we would simply unscrew the bolts holding them in.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 12-08-2012, 00:23
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
Re: Chains
This year was our first year doing our whole robot in sheetmetal and we will be doing it (hopefully) Forever. Great decision to do sheet.
So what makes putting the chain on a lot easier it to make BIG lightening holes on the sides. then you can get your hands in there. IF you are going to cover the tops and bottom of the drive trains, the put the chains on first and make sure they are easy to come off in case you have to replace the chains at competition.
Sheet-metal, and really all types of robots, need to have a lot of thought about assembling, disassembling, and replacing parts. Your designers need to learn what kinds of things should be done to make all those things easier and quicker to do. (PS: RIVETS ARE AMAZING WITH SHEETMETAL!).
Another thing, when putting the chains on what I do is lay your chain out over the sprockets, with the end of your chain on the sprocket, measure which link needs to be removed, then cut the chain. Then when you are putting it on to put the master-link in, put both the ends of the chain on the sprocket so they are at the distance they should be at. then you can easily put the master-link in. (sorry if that was a terrible explanation)
Hope this helps
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 12-08-2012, 02:07
yarden.saa's Avatar
Yarden Saad
AKA: Yarden Saad
FRC #3339 (BumbleB)
Re: Chains
What is the thickness of the sheetmetal you were using? it looks great and very light
Unread 12-08-2012, 11:10
DonRotolo's Avatar
Back to humble
FRC #0832
Re: Chains
Slightly off topic: Regarding installing master links, has anyone used a pair of "pliers" (somewhat modified with hooked tips) that hook into links at the ends so the chain can be pulled tight enough to insert the master link?
akoscielski3: That explanation was fine, but on small sprockets it can be difficult, and often side access is tight near the sprockets. We used that technique for our #25 chain that's out in the open.
Unread 12-08-2012, 11:37
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
Re: Chains
Originally Posted by DonRotolo View Post
Slightly off topic: Regarding installing master links, has anyone used a pair of "pliers" (somewhat modified with hooked tips) that hook into links at the ends so the chain can be pulled tight enough to insert the master link?.
I would imagine a large zip-tie would also work if the tension is low enough (with safety glasses in case of high-energy zip-tie failure events ).
