Slightly off topic: Regarding installing master links, has anyone used a pair of "pliers" (somewhat modified with hooked tips) that hook into links at the ends so the chain can be pulled tight enough to insert the master link?.
I would imagine a large zip-tie would also work if the tension is low enough (with safety glasses in case of high-energy zip-tie failure events ).
