Go to Post Giving POWER and CHOICE to the people is the best route. - Franchesca [more]
Unread 14-08-2012, 12:35
badtkee badtkee is offline
badtkee is an unknown quantity at this point
VEXnet joystick LCD screen
Hey Everyone,
Does anyone know if there is a way to connect an LCD screen to the VEXnet joystick instead of connecting the LCD screent to the microcontroller?
thanks!
--Eric
Unread 15-08-2012, 08:58
lynca's Avatar
lynca lynca is offline
Andrew Lynch
FRC #2587 (DiscoBots)
Re: VEXnet joystick LCD screen
Originally Posted by badtkee View Post
Hey Everyone,
thanks!
When you say the "LCD screen" do you mean the The VEX LCD ?
If so, you can not program the electronics in the VEX joystick, therefore connecting the VEX LCD to the VEX joystick is not possible.
However, you can write code on the VEX controller that displays joystick values on the LCD.
History: 624 - Cryptonite --> 118 - Robonauts --> 2158 - AusTIN CANS --> 2587 DiscoBots
Bio: Andrew Lynch "How I Work" ---- LinkedIn , Facebook, Twitter
Unread 15-08-2012, 10:59
Either the VEX LCD or a generic LCD. Right now I have the VEX LCD connected to the cortex microcontroller and it displays values, but when I'm driving the robot 10 ft in front of me, that makes the LCD screen basically useless. So I'd like to have a screen on the joystick so I can see the values no matter where the robot is relative to me.
--Eric
Unread 15-08-2012, 20:20
Gigakaiser Gigakaiser is offline
AKA: Brandon Hjelstrom
FRC #0987 (High Rollers)
Gigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant futureGigakaiser has a brilliant future
You may want to set up prints in your program - as long as the joystick is connected to your computer with the serial->usb cable you will be able to read values wirelessly. If you need the values during a competition match or anything of the sort it most likely isn't legal - I don't think the joystick could even give you any data other than its own status and input values.
FRC Team 987 - It's not enough
