Go to Post If you want to know how to build a more competitive robot, ask. GP demands we tell you, help you, guide you, teach you. - Al Skierkiewicz [more]
Unread 05-08-2012, 12:52
F22Rapture's Avatar
F22Rapture F22Rapture is offline
College Student, Mentor
AKA: Daniel A
FRC #3737 (4H Rotoraptors)
F22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant futureF22Rapture has a brilliant future
How to setup version control on Github?
I'm new to programming and while I've played around with the Github for Windows client and Netbeans and such, I haven't managed to figure out how to push my current code to Github, and don't really know where to go from there once I do. Any tips?
Unread 06-08-2012, 13:56
tech2077 tech2077 is offline
AKA: Matthew Skolaut
FRC #3847 (Spectrum 3847)
tech2077 is an unknown quantity at this point
Re: How to setup version control on Github?
For a good tutorial on most of the features of git specific to github, try try.github.com. It only covers the command line side, but it's helpful in better understanding git. When committing with Github for Windows, it's as simple as commit and sync. As for netbeans, it's as simple as putting in your git url and github login information into the team menu settings.
Unread 06-08-2012, 17:34
kenavt's Avatar
kenavt kenavt is offline
AKA: Colin S
kenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond reputekenavt has a reputation beyond repute
When 2337 looked into GitHub, I was recommended Pro Git by Scott Chacon (which is free), and was tremendously useful. I found the GitHub help to be useful when dealing with GitHub, but not with Git itself, the version control system.
As well, the GitHub for Windows client is very poor and not well-written. Frankly, my first ever experience with bash scripts (command-line) was with Git, and it was eye-opening. I highly recommend using Git bash.
University of Michigan Computer Engineering '17
FRC 2337 student alumni (2010-2013)
Unread 11-08-2012, 22:45
F22Rapture's Avatar
AKA: Daniel A
I have the repo set up between GitHub and Netbeans but it's currently empty - how do I move my existing code to it?
Unread 15-08-2012, 23:17
F22Rapture's Avatar
AKA: Daniel A
WHOOO! Finally figured it out after some google-fu
For others' reference, here are the steps I took:
Create your new repo on Github, take note of the https:// address in the edit bar (not url bar)
Install Git Bash from the Git website http://git-scm.com/downloads/
Open Git Bash
Type the following:
(Replacing "Username" with your Username, and "directory" with your directory.)
cd /c/Users/Username/directory-of-project/
Should now show a yellow highlighted directory preceded by a tilde (~)
pwd
Verifies that the current directory is the one typed above
git init
git add .
If it pops up an error message "LF will be replaced by... ", type the following: (If not, continue)
git config user.email "Your email address"
git config user.name "Your name"
git add .
Continuing...
git commit -m 'initial commit message'
git remote add origin https://github.com/YourAccountName/Project.git
That last address is the one I mentioned to take note of earlier
git push origin master
At this point it will give you a login prompt for github. When you type the username and password the characters will be invisible, but they're there. It confused me at first.
It may give you an error. If not, great, if so, type
git pull origin master
and then when that succeeds,
And now you should be done. Refresh your github repository page and the code should be there.
Unread 16-08-2012, 12:13
Ginto8's Avatar
Ginto8 Ginto8 is offline
Programming Lead
AKA: Joe Doyle
FRC #2729 (Storm)
Ginto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of lightGinto8 is a glorious beacon of light
This looks like a great step-by-step method for teams that want to set up GitHub! I just noticed two small things:
  • The "LF will be replaced by..." message is not an error. Because Windows and *nix (UNIX-like systems such as mac and linux) store line endings differently (Windows uses a sequence two characters, CR and LF, or "carriage return" and "line feed", while *nix systems only use LF), git has a feature that automatically converts between the two, so that the repository's contents are always consistent, even if people have committed from different OS's.
    The answer to this StackOverflow question can make things a bit clearer.
  • Not really a problem, but characters not appearing as you type a password is pretty standard behavior in bash. Although it can be unnerving, it's actually slightly more secure, because people looking over your shoulder can't even tell how long the password is, much less what the characters are.
Unread 16-08-2012, 15:11
Zach O's Avatar
Zach O Zach O is offline
Building an iOS app @ glacial speed
AKA: @FRCZach
Zach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond reputeZach O has a reputation beyond repute
GitHub has some great articles on setting up your environment for using Git and GitHub (setting your GitHub username globally, etc) https://help.github.com/articles/set-up-git
They also go through the process listed above with Creating A Repository
Anything past that, I agree with Colin, go with Pro Git, or check out the Git documentation http://git-scm.com/documentation
Follow me twitter dot com slash frc zach
