Go to Post Don't underestimate the ability of a highly skilled technician with simple tools (and don't overestimate the ability of an unskilled fool with exotic tools!). - dlavery [more]
Unread 15-08-2012, 21:20
Matthew.Mc's Avatar
Matthew.Mc Matthew.Mc is offline
Pulverizer
FRC #0907 (East York Cybernetics)
Matthew.Mc is on a distinguished road
Re: Questions-Thoughts/Input On First Drivetrain Design
Originally Posted by Garrett.d.w View Post
You can put a hex output shaft in a supershifter. You then connect the shaft directly to a hex bore wheel. You should support both sides of the shaft with bearings.
Situate the wheels where you want them, then rotate the supershifters around their output shafts until you find a suitable mounting position. With the design of your frame, you will probably be mounting to the face of the supershifter.
This year, ours wound up rotated about 45 degrees and mounted to the frame using L brackets.
If you want an example, I can provide a CAD model and pictures.
If you could post a picture of a CAD model of how you mounted the Shifter it would be nice. Thanks
Unread 15-08-2012, 23:54
IanW's Avatar
IanW IanW is offline
Rookie Mentor
AKA: Ian
FRC #0997 (Spartans)
IanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond repute
Couple of things:
  • The sheet thickness is almost certainly fine. See example below. However,
  • Using a router to cut material will probably be challenging. As I understand it, the bit will tend to grab the material and yank it around with thin sheet. Granted, I don't personally have experience with this, but I've heard this said previously in other threads
  • The sides are probably beefier than they need to be. Again, see example below
This past year my team and Team 1983 used a similar sheet metal design:
FRC 2374
FRC 1983
Both of these designs were from before kickoff and thus modified to address the challenges of the game.
Both teams only used one piece of sheet metal on the side panels, not a full box like you have. We then pop riveted the sheets to pieces of angle aluminum. Our rivets were on a 2" spacing. The chassis seemed to hold up quite well.
Good work though, good luck on your future iterations.
Website
Facebook
Unread 16-08-2012, 00:42
Matthew.Mc's Avatar
Pulverizer
Originally Posted by IanW View Post
Couple of things:
FRC 2374
FRC 1983
Thanks for showing me the designs. There quite simplistic but look quite sturdy. Also I have done projects on the CNC with 0.050" sheet Aluminium and it just took some tuning with the spindle speed and feed rate.
Originally Posted by rcmolloy View Post
Yeah I would assume a 3/16" rivet every half inch should do you just fine. The current pattern seems to be way overkill.
Also, add some fillets to your pocketing patterns as well. It definitely helps the end mill for the router to eliminate the precise corners that you have going on there. Even more so, if you ran this, it will still have the mill's OD in each corner of your triangles. I would advise you make the fillets to your the mills exact OD or higher; never under.
Also, the normal/nominal thickness I have seen over the past years for sheet is a variance between .090" and 1/8". 1/8" for the beefier parts that require much of the static loads to be held and .090" for manipulation systems. (Correct me if I'm wrong guys haha)
Aside, it looks like a pretty decent sheet chassis.
I have actually printed 2 Pieces from an old design of some front plates. They were merely a test but showed me i didn't need fillets on the sharp edges.
Unread 16-08-2012, 00:58
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Here we go, hopefully this helps sort out my previous post (which after reading it again makes no sense).
The first pic is for context. The drivetrain is a 6wd West coast drive from this years competition robot. Even though the drive systems are different, the concept still holds true.Chains and extraneous hardware have been removed for clarity.
Here is a view of the rail.
And finally a fancy exploded view.
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 16-08-2012, 12:36
Matthew.Mc's Avatar
Pulverizer
Thanks. Ill look at super shifters, although there a bit more bulky which I don't really mind but it would be nice to learn more about the normal shifters. I'll probably just wait until I can buy them when its back to school so I can really understand them and perhaps make a variation of them.
Thanks again
Unread 16-08-2012, 13:38
IndySam's Avatar
IndySam IndySam is offline
FRC #0829 (Digital Goats)
Super Shifters are a bit wider because of the extra gear reduction needed to be able to directly drive the wheels. The black housing can be simply replaced with 2" aluminum spacers which is how many teams run them.
When we have used them we have incorporate the front plate into the frame to save even more bulk.
