Re: pic: 254 2010 Gearbox 1
We used a mix of Andymark gears that we lightened/changed bores and Martin gears that we lightened/put our own bores in.
Funny to see this pop up I was just thinking about this gearbox last night.
You mentioned changing the bores on the AndyMark gears. We were talking about doing something similar, specifically boring a 3/8th bore out to a 1/2 and then broaching it. I was wondering if you could give a bit more information about what set up you used and how you went about it.
-RC |
Cory, what material do you guys use for your side plates?
#8
Do you mount encoders on one of the transmission axles (and then have to account for which gear you are in) or other location?
#9
For the manual stuff at school, we have HSS boring bars we bought in a 9 pack from MSC or Enco. TBH, if you just call MSC or a tooling rep, they'll tell ya what you need and sometimes they'll even donate it. Gearbox Plates are 6061 - T6 and they pocket them. Quote:
-RC |
#10
Just wondering, what are the prices and lead times like for Martin gears? We've been using SDP-SI, and I was wondering how they compared. Just looking at their catalog, their selection in some regards is certainly larger.
#11
McMaster can also get you any Martin gear that is not listed in their catalog. I don't know how the lead time/price compares to Motion. SDP is probably the worst supplier we use. For a few years we've been referring to them as (Out of) Stock Drive Products. We've had some quality issues as well. Also very expensive. Quote:
I've never liked these as they tend to have large tip radii and are not very sharp. Something like this would be great, but kind of expensive. You could find similar HSS/carbide tipped tools elsewhere for cheap. We have a 1" indexable boring bar that works great. Same as this. Inserts can be expensive (about $5 ea), but the ones we get are designed for aluminum (all we use it for) and are extremely sharp, which is beneficial on small lathes. You can also use the inserts for OD turning, with a different tool holder. Last edited by Cory : 17-08-2012 at 02:39. |
#12
And their billing system is a nightmare. The web orders don't interface properly with the rest of the order system, so if you have a problem with one, you have to get a different department to pull it up for you. Also, I worry about their IT resources. After all, I've been experiencing the same technical problems for years now, and despite me mentioning them repeatedly, it doesn't seem to be corrected yet. (For example, they've got billing information that has been out of date for maybe 9 years, and no matter how many times I tell them to correct it, it still comes back every time.) |
| pic: 254 2010 Gearbox 4 | craigboez | Extra Discussion | 5 | 25-12-2010 19:38 |
| pic: 254 2010 Gearbox 6 | craigboez | Extra Discussion | 10 | 22-12-2010 22:13 |
| 254 Gearbox Analysis | craigboez | Technical Discussion | 8 | 22-12-2010 09:17 |
| pic: 254/968 Gearbox - Destructive Testing Results | Travis Covington | Technical Discussion | 23 | 19-06-2007 14:58 |
| 254/968 Gearbox Assembly Time Study/Analysis | Travis Covington | Technical Discussion | 8 | 08-05-2007 13:40 |
