Go to Post Most of all, I long to give others a chance to experience what I did with FIRST, to give people from my home town that opportunity, because FIRST really is that once in a lifetime opportunity that so many people dont get a chance to be a part of. It shouldnt be that way. - Jacqui Sutton [more]
Unread 16-08-2012, 15:19
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
[FTC]: An Idea for FTC.
In relation to this post:
http://www.chiefdelphi.com/forums/sh...6&postcount=34
What are some things that the FTC community at would like to see? Right now this is entirely hypothetical because a company such as this one would have to be an approved list of parts or COTS materials.
But forget the logistics lets have some fun shall we?
- Andrew
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 16-08-2012, 16:40
jcarr jcarr is offline
Coach
FTC #3539
jcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud ofjcarr has much to be proud of
Re: [FTC]: An Idea for FTC.
Worm gears.
Ball bearings.
Motors that don't burn up.
Unread 17-08-2012, 13:02
TRWSHSHLX TRWSHSHLX is offline
AKA: Henry Lei
TRWSHSHLX is an unknown quantity at this point
1. Mecanum Wheels
2. LEGO / TETRIX / MATRIX adapters (not just to connect pieces but adapters so different systems can POWER other building systems. For example like a modified TETRIX axle to have a cross on one end to fit LEGO pieces onto it.)
3. Motor mounts (or combo motor mounts to connect motors together without taking up too much space, and better support.)
4. Custom gears (maybe not necessary with MATRIX but TETRIX gears in my opinion are way too big.) including worm, rack and pinion so teams don't have to use chains & sprocket (which is a good alternative) to achieve linear motion
5. Custom size sprockets
6. Better axles (It's part engineering too stronger axles wouldn't hurt)
7. Custom wheels!!! Especially if your team owns some special LEGO tires that no one else have
Unread 17-08-2012, 13:55
Coach
FTC #3539
worm gears
ball bearings
motors that don't burn up
