Go to Post "Hurry, we broke the drivetrain again" - Lil' Lavery [more]
Unread 16-08-2012, 16:47
Garrett.d.w's Avatar
Garrett.d.w Garrett.d.w is offline
Build Lead
FRC #2733 (The Pigmice)
Garrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to beholdGarrett.d.w is a splendid one to behold
Re: using model aircraft digital optical tach on full sized aircraft
If you are using a VW engine, couldn't you just use the tachometer that was sold with the vehicle for which the engine is designed?
"A mind once stretched by a thought will never regain it's original dimensions."
Optimists think the glass is half full.
Pessimists think the glass is half empty.
Engineers realize it's twice as big as it needs to be.
Unread 16-08-2012, 16:58
orvie6 orvie6 is offline
orvie6 is an unknown quantity at this point
I do not have one available...actually, I was mistaken...it is a 1/2 VW..and most of the unwanted holes have been welded shut!! So to use the mechinal tach wont work..besides...too heavy and cable too long!! and no connection for an electrical tach.
Unread 16-08-2012, 17:20
Nate Laverdure's Avatar
FRC #2363
How about a hall effect sensor instead? You could set it up to sense the passing of gear teeth, or bolt heads...
Unread 16-08-2012, 18:11
DonRotolo's Avatar
Back to humble
FRC #0832
Originally Posted by orvie6 View Post
..and since I dont plan on flying this is any kind of bad weather,
Aye, but weather has a way of sneaking up on you.
I agree, your ears will give you a good indication, using this as a secondary reference may be acceptable. Again: Tape it to the cowling and see what happens!
