Re: 2012 Beta Testers
Beta Testing was awesome last year (http://team1912.com/beta_testing.html) and we hope to do it again this year!
I had a lot of fun doing it last year and we're hoping to get accepted for Java again.
We applied , we were also last year but because we moved to another lab/workshop we didn't have the time for it.
We applied for out first time this year. We are hoping to be selected.
We are applying as well.
Just wondering what are the chances of a team to be selected? |
We just finished filling out the Survey... however, when we submit it, it seems to only refresh the page. Anyone else encountering this? We don't get any sort of confirmation that it went through!
Edit: Found our issue... apparently form errors don't really show up well on the site when viewed in Firefox! Last edited by Jon Stratis : 27-08-2012 at 15:29. |
#7
Thanks for posting reminder... we may do this again, still thinking about it. I do want to ask a question as there is a goal I'd like to pursue. Is there anyone at all that was able to use vision through the driver-station using c++ wind-river? If so please let me know as we would like to gather information on how to do this (e.g. for Beta Exhibition). Thanks.
#8
118 used C++ and a Beagle Bone. I don't really see an issue with doing it on the dashboard. What are your concerns?
Greg McKaskle |
#9
I've never heard of a beagle bone... thanks for info on team 118. I should hook up with them and see if they can help. Hopefully enough teams have tested this new path... and from what I've heard it's been positive results with minimal latency. P.S. If I can figure all of this out... it would be cool to overlay cross hairs on the video image that comes to the driver station... I'll save this research for next iteration. |
#10
You may be able to find step-by-step instructions, but perhaps you don't need them.
To get an image from the dashboard to the camera, you simply do an http get to start the mjpg stream. You can alternately request individual jpegs. You can do this in LV with the default dashboard, in Java with smart dashboard. You can also write a C/C++ dashboard, but there are no tools in the kit for doing this -- you can use Microsoft or gcc for PC development. Once you have the image, you can use any laptop image processing library you like -- some use OpenCV, some use the NI IMAQ libraries. To send info back to the robot, you can use UDP, TCP, or the smart dashboard. The smart dashboard is the simplest approach, and with some sample code, the UDP and TCP aren't too bad either. As for placing marks on top of the image, the NI IMAQ vision control does this pretty easily, and I'm assuming you can modify the image or similarly overlay it in smart dashboard. Once you start the project, you can ask additional quesitons. Greg McKaskle |
#11
Thanks for this preliminary information... I think for CD I'll just ask some high top level questions for the good of the group... and figure out the best direction to go. What I'd like to do is have a solution that many c++ teams can use without needing to write any JAVA code. So I remember the default dashboard having callback tags or something like this, but it sounds like there is no easy way to somehow bridge the callbacks into a c++ environment. Let me know if this is not true... I know for c# it's possible to write bridge code as we do this for our products at work. If it is possible then perhaps we could offer the bridge code for others to use (since everyone gets the default dash board). Ok so let's look at the C++ dashboard option... I presume this would be something to the effect where it becomes the replacement exe (to replace the default one), and at that point we could easily interface with it. If we went down this route, would it be something we could offer to other teams? I'd be happy to port over the default dashboard from JAVA to c++ for this exe if that sounds like the best direction. If I can get past this first hurdle... it will help clarify the next step for us. Thanks in advance for helping us out. |
#12
I've spoke with 118 and they went the "http get" path...using UDP packets. (Thanks 118 for this info). We'll pursue this direction as well but instead we'll use Windows and Visual Studio. I figure it will be a more feasible alternative for teams to consider using vision processing on the driver station, but it will be interesting to see how wireless latency compares against high cpu usage video processing on the cRIO. There's probably some info on this comparison else where in CD (I'm going to re-read 341's posts on their latency).
