Go to Post While one student may not be of much value to the team, do we ever stop to think about how much value the team may be to that student? - Madison [more]
Unread 07-01-2011, 11:55
craigboez's Avatar
craigboez craigboez is offline
Mechanical Engineer
AKA: Craig Boezwinkle
FRC #2811 (StormBots)
craigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nicecraigboez is just really nice
pic: 254 2010 Gearbox 1
robostangs548's Avatar
robostangs548 robostangs548 is offline
Team 548 General Motors Robostangs
AKA: Mason Falk
FRC #0548 (General Motors Robostangs)
robostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant futurerobostangs548 has a brilliant future
Send a message via AIM to robostangs548
Re: pic: 254 2010 Gearbox 1
Stunning, to say the least...
Mason Falk (Team 548)
General Motors Proving Grounds Robostangs
Northville, MI USA
Unread 16-08-2012, 12:21
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
I know this thread is over 2 years old but..... Did 254/968 use AM gears or did they make their own gears?
Unread 16-08-2012, 14:38
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
We used a mix of Andymark gears that we lightened/changed bores and Martin gears that we lightened/put our own bores in.
2001-2004: Team 100
2006-Present: Team 254
Unread 16-08-2012, 15:20
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
Funny to see this pop up I was just thinking about this gearbox last night.
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 16-08-2012, 17:18
JeremyLansing's Avatar
JeremyLansing JeremyLansing is offline
Team 967 Alumni
FRC #0171 (Cheese Curd Herd)
JeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud ofJeremyLansing has much to be proud of
You mentioned changing the bores on the AndyMark gears. We were talking about doing something similar, specifically boring a 3/8th bore out to a 1/2 and then broaching it. I was wondering if you could give a bit more information about what set up you used and how you went about it.
Unread 16-08-2012, 17:30
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Unsure what 254 does, We have bored out our dog gears to accept a R10 bearing and to broach to a bigger size numerous times. We take softjaws on the lathe and bore them out to the gear diameter. We hold the gear and open the bore via a boring bar.
-RC
R.C.
MadTown Robotics Team 1323
Unread 16-08-2012, 18:29
Cory's Avatar
AKA: Cory McBride
We do basically the same thing as RC, except soft jaws in a vise on a CNC mill. We then interpolate the bore and broach on the machine.
2001-2004: Team 100
Unread 16-08-2012, 18:38
Team 967 Alumni
Thanks for the quick replies. Since we don't have a CNC machine we will most likely be trying the lathe approach, can you recommend any good boring bars or associated tooling?
Unread 16-08-2012, 22:49
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Cory, what material do you guys use for your side plates?
1058 PVC Pirates 2016 - xxxx
Unread 16-08-2012, 22:55
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
Do you mount encoders on one of the transmission axles (and then have to account for which gear you are in) or other location?
Unread 16-08-2012, 23:11
DampRobot's Avatar
Physics Major
AKA: Roger Romani
Just wondering, what are the prices and lead times like for Martin gears? We've been using SDP-SI, and I was wondering how they compared. Just looking at their catalog, their selection in some regards is certainly larger.
-Plutarch
Unread 17-08-2012, 00:57
R.C.'s Avatar
At work we use Kenametal Holders. Normally Mitsubushi Rep's come out and pretty much tell us what tooling to use. CNMG is the style insert we use. But thats for CNC related machining.
For the manual stuff at school, we have HSS boring bars we bought in a 9 pack from MSC or Enco. TBH, if you just call MSC or a tooling rep, they'll tell ya what you need and sometimes they'll even donate it.
Gearbox Plates are 6061 - T6 and they pocket them.
They mount the encoder on one of the wheel shafts.
-RC
R.C.
Unread 17-08-2012, 02:29
Cory's Avatar
AKA: Cory McBride
Generally we get them from Motion Industries. Prices are fairly reasonable (better than McMaster). I want to say they varied from about $30 for a 50T to $8 for a 12T. Most gears are in stock in Sacramento/LA. Some have to come from the factory in Texas.
McMaster can also get you any Martin gear that is not listed in their catalog. I don't know how the lead time/price compares to Motion.
SDP is probably the worst supplier we use. For a few years we've been referring to them as (Out of) Stock Drive Products. We've had some quality issues as well. Also very expensive.
We don't do a lot of boring on the lathe, as we tend to put parts that would normally be turned on the CNC mill if they require much material removal/accuracy, but when we do, for small diameter boring we use whatever random brazed carbide bars are around.
I've never liked these as they tend to have large tip radii and are not very sharp. Something like this would be great, but kind of expensive. You could find similar HSS/carbide tipped tools elsewhere for cheap.
We have a 1" indexable boring bar that works great. Same as this. Inserts can be expensive (about $5 ea), but the ones we get are designed for aluminum (all we use it for) and are extremely sharp, which is beneficial on small lathes. You can also use the inserts for OD turning, with a different tool holder.
2001-2004: Team 100
Unread 17-08-2012, 03:37
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
I've noticed their stock of interesting robot gears being somewhat marginal for the last few years as well. I can only applaud their efforts to reduce costs sunk into inventory if they make an equal effort to producing items on demand and shipping them quickly.
And their billing system is a nightmare. The web orders don't interface properly with the rest of the order system, so if you have a problem with one, you have to get a different department to pull it up for you.
Also, I worry about their IT resources. After all, I've been experiencing the same technical problems for years now, and despite me mentioning them repeatedly, it doesn't seem to be corrected yet. (For example, they've got billing information that has been out of date for maybe 9 years, and no matter how many times I tell them to correct it, it still comes back every time.)
pic: 254 2010 Gearbox 4 craigboez Extra Discussion 5 25-12-2010 19:38
pic: 254 2010 Gearbox 6 craigboez Extra Discussion 10 22-12-2010 22:13
254 Gearbox Analysis craigboez Technical Discussion 8 22-12-2010 09:17
pic: 254/968 Gearbox - Destructive Testing Results Travis Covington Technical Discussion 23 19-06-2007 14:58
254/968 Gearbox Assembly Time Study/Analysis Travis Covington Technical Discussion 8 08-05-2007 13:40
