Go to Post You mean nobody else has picked up on the hint about next year's game being called "Whack the Billfred"? - EricH [more]
Unread 13-01-2003, 00:15
Dima Dima is offline
Dima is just really niceDima is just really niceDima is just really niceDima is just really niceDima is just really nice
Send a message via AIM to Dima
"Best Idea"#2
so check this out:
by the rules you can't push against both ramp walls at the same time with one robot. Nether can you do it with a box on one end because technically you are not violation this rule but thats your intention.
How about for a change you have 2 robots "mesh together" and each one pushes on its own side of the the wall?
I know that you it would not be such a hot idea to make 2 robots that fit each other counting on being in the finals together. But sill you could have a mecanism on your robot that does something like this
Unread 13-01-2003, 00:23
Jeremy_Mc's Avatar
Jeremy_Mc Jeremy_Mc is offline
GitHubber
Jeremy_Mc will become famous soon enoughJeremy_Mc will become famous soon enough
i'm sure when they said bin they implied bot too...
or atleast the ref would assume that the rule is to be read as bin/bot/other field object.
just my opinion though...maybe you should ask about it on the first forums.
*jeremy
GitHub - Collaborate on code, documentation, etc. - http://github.com
Unread 13-01-2003, 01:22
Caroline Caroline is offline
#0192 (Gunn Robotics Team)
Caroline has a spectacular aura aboutCaroline has a spectacular aura about
Send a message via AIM to Caroline
Rule GM31:
"It is also unacceptable to grab onto or push hard enough against multiple surfaces simultaneously in order to wedge and make a immovable a robot."
I believe that the wall and the other robot would count as two surfaces, thus making this strategy illegal. Creative thinking, though.
Unread 13-01-2003, 01:27
Elgin Clock's Avatar
FRC #0237 (Black Magic)
So does that mean that you have to push or be pushed in a match if you go up against someone?? You can't just be a lump-bot? I know that worked for us alot last year @ NYC.
We would just drop down our two sets of perpendicular drive systems to the same plane and sit there and not many robots would be able to push us.
Does this mean that if we decide to do that again this year we would be DQ'ed for standing our ground and not allowing ourselves to be pushed around???
If that's true, I think at least one robot from EVERY match will be DQ'ed!!!
Unread 13-01-2003, 06:40
Noah's Avatar
Noah Noah is offline
Code Monkey
#0861 (The Gondobots)
Noah has a spectacular aura aboutNoah has a spectacular aura about
Send a message via AIM to Noah
No, the ground only counts as one surface. Feel free to lump around. (Unfoirtunatly, you don't just get points for lumping around like you did last year... our team had one match where we didn't move.. and since we started in the robot scoring zone that was some points right there! )
"It's broken? NOOAAHH!!! This is your doing, isn't it!"
"We can fix it in the software!"
"It's a BROKEN GEAR!"
Unread 13-01-2003, 10:25
Ken Leung's Avatar Unsung FIRST Hero
Ken Leung Ken Leung is offline
Dare to Live!
FRC #0115 (Monta Vista Robotics Team)
Ken Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond reputeKen Leung has a reputation beyond repute
Send a message via AIM to Ken Leung
Strange how people think this is illegal to do... Especially when at kickoff when Woodie or Dave explained about the rule of not allowing robots to grab both surface of the side wall that this is the one thing that is allowed to do, if teams choose to do it.
I remember either Woodie or Dave said that since a robot may touch only one side of the side wall, teams may build two robots that each touch one of the walls, and against each other to block the ramp...
You guys might want to take a look at the kickoff video before you say you know anything for sure...
Hardware Test Engineer supporting RE<C, Google.
1999-2001: Team 192 Gunn Robotics Team
2001-2002: Team 100, 192, 258, 419
2002-2004: Western Region Robotics Forum, Score Keeper @ Sac, Az, SVR, SC, CE, IRI, CalGames
2003-2004, 2006-2007: California Robot Games Manager
2008: MC in training @ Sac, CalGames
2009: Master of Ceremony @ Sac, CalGames
2010: GA in training @ SVR, Sac.
2010-2011: Mechanical Mentor, Team 115 MVRT
Unread 13-01-2003, 15:36
K. Skontrianos's Avatar
K. Skontrianos K. Skontrianos is offline
FRC #0102 (Dexterous Gearheads)
K. Skontrianos is an unknown quantity at this point
You cannot assume that every little quirk at a kickoff is right. Remember that written rules supercede anything spoken. Take the SHU rule for example. At kickoffs, you could turn a box on its side to make one box count for 2. Well, read Update 1 now and you will see that SHU's are rounded down which contradicts what was stated at the kickoff. If you want to try to find some eccentric loophole in every rule, go right ahead, maybe the refs will let it slide by like the tethers last year. However, don't come whine in these forums if a you get DQ for it. That wouldn't be in the spirit of gracious professionalism, would it?
www.team102.com
2000 National Finalists
2003 J&J Mid-Atlantic Regional Winners
2003 BattleCry Best Autonomous
