Go to Post Uh. Oh. Wildstang is simple and has a swerve. Where have I seen that before? - EricH [more]
Unread 19-08-2012, 14:38
Adam.garcia Adam.garcia is offline
Design Mentor
FRC #0004 (Team 4 Element)
Adam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really niceAdam.garcia is just really nice
Drivetrain Critiques
Hello CD,
I have been working on this drive train on and off for this past year. I have gotten to the point where I think this drivetrain is ready to go into its manufacturing stage. But before I do so, I would like the expert advice of all of you.
Drive train Specs:
6 Wheel WCD (1/8" drop center)
2- Speed "Dog Shifting Gearbox" (13:1 (6.39 fps) & 4.8:1 (17.04 fps)
4" AndyMark Performance Wheels
Bumper Mounting inspired by 254's Skyfire
Bellypan: 1/16" G10-FR4 Garolite
Questions that I still have:
1. What should the minimum distance be from the ground to the bottom of the gearbox?
2. Is there a better/ more efficient way of designing this battery holder? Right now, it is comprised of Sheet metal, and I would like to find an alternative method using regular 1/8" Aluminum Plate.
3. As of now, all the drive shafts are 2024 Aluminum. I chose this to significantly decrease weight, but I need to ensure that it does not compromise durability. (It would never be a good thing to have the drive break on the middle of the field! What are your thoughts about this? I could always revert it back to a steel alloy.)
Thanks, and I very much look forward to hearing everybody's advice/suggestions!
“The object of education is to teach us to love what is beautiful.”
“Never discourage anyone who continually makes progress, no matter how slow.”
Unread 19-08-2012, 14:56
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
Re: Drivetrain Critiques
In the past, my team has made our battery holder out of 90 degree angled aluminum. You can see it if you look closely at the back of the bot in this picture.
http://www.chiefdelphi.com/media/img...43d1127c_l.jpg
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
Unread 19-08-2012, 15:03
James Tonthat James Tonthat is offline
FRC #0148 (Robowranglers)
James Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond reputeJames Tonthat has a reputation beyond repute
What kind of manufacturing do you have to use?
Milling, waterjet, welding?
For the width of the gearbox, those standoff/spacers don't look substantial enough. What gears are you using specifically?
Looks like you used 0.25 plate for the bearing blocks, I'm guessing similar to 33 from 2011 style. There doesn't look like there's enough overlap between the 2x1 and the plate. I'd avoid running the chain below the chassis if you can help it.
The battery box looks like it's sitting on the garolite unsupported. Looks like an unbendable part as is.
At a glance, doesn't look like there's enough spacing for wires since you have the Vics, PD, Vics, cRio side by side.
I'd recommend 7075 aluminum for the driveshafts.
James Tonthat
Mechanical Engineer, RackSolutions, a subsidiary of Innovation First International
Lead Engineer - Texas Torque - 2009-2014
Mentor - Robowranglers - 2015-
Unread 19-08-2012, 15:31
Design Mentor
We have access to a CNC Milling Machine, Welding equipment, and a waterjet. Gotta love sponsors!
We are solely using WCProducts' Gears. We have a 14 T CIM gear going to a 45. From there, the Low gear is 15 T to 60 T. The High Gear is 30 T to 45 T.
Yes, the part that is visible is a 1/4" Plate. There is .25" of overlap between the 2x1 and the plate. Is that enough?
How would I get away with out running the chain below the chasis?
That is true, I will fix it in the next version of the battery holder.
I essentially copied 254 and the Holy Cow's electronics setup. We are not going to be predrilling holes into the bellypan, so if this setup does not work, we can find another way of mounting.
I would definitely love to use 7075 Aluminum drive shafts. Do you know where I can get 1/2" 7075 Aluminum Hex?
Worst case scenario, I could always have our machinists use a 4th-axis on the Mill to get that 1/2" Hex. (It's just always nicer if we can buy it premilled in the Hex configuration)
Thanks again for your help.
Unread 19-08-2012, 15:50
http://www.onlinemetals.com/merchant...285&top_cat=60
I'm not sure how oversized these come, I don't know what tolerances the hold from flat to flat.
Had a question - why the garolite if you have a waterjet sponsor? If the frame is welded, you may not need gussets on the cross members.
Looks good, sorry I don't have the expertise to comment on anything else though.
Unread 19-08-2012, 15:53
Design Mentor
Had a question- why the garolite if you have a waterjet sponsor?
I've been talking with Adam Heard, and he said that it'd be best to leave the bellypan as is for now until we have had some first-hand experience with professional wiring. Our team does not yet the minimum spacing between many of the electronic components. A fully pocketed Aluminum Bellypan is definitely something we will incorporate into a future revision of the drive train.
Unread 19-08-2012, 15:55
AdamHeard's Avatar
Lead Mentor
A sponsor isn't an unlimited resource. We've run both garolite and waterjetted pans on multiple robots. I honestly couldn't say one performs better (the waterjet is stronger, and is certainly cooler. Can't say that extra strength is truly necessary tough). I know for sure that the waterjetted pan is 10x the resource and cost investment at least.
So a waterjetted bellypan is a huge resource dump for minimal competitive gain, and if that same amount of sponsor time was invested in making parts for other system it would be far more useful (a waterjetted bellypan easily equates to the gearbox for every system on the robot in most cases, plus several sets of spares).
To elaborate more on the differences. G-10/fr4 is what we use, which is primo grade garolite. Mcmaster has it in 1/16" which is what we routinely order. It's hard to directly compare a solid composite pan to a pocketed aluminum pan in strength, but the more I think the more I'm pretty sure they are comparable in strength. We've run both on multiple projects, and the garolite is actually stiffer with less sag/deflection under load.
Unread 19-08-2012, 16:05
Makes sense, thanks for the explanation!
Unread 19-08-2012, 16:16
The 7075 from OnlineMetals, I found usually comes out to be around 0.500 - 0.503. Usually a pretty good fit on a broached part.
Sorry, I meant the bellypan.
Adam, we used our bellypan to fixture the chassis before welding, what's your experience with using garolite to do the same thing? (Or do you do something different altogether?)
The overlap on the bearing plates, I'd look at doing more, going to more of rectangle shape if you have to instead of the teardrop shape. Although, doesn't hurt to try it as is.
James Tonthat
Unread 19-08-2012, 16:18
AdamHeard's Avatar
Lead Mentor
We've never tried it. The G-10/fr4 is "fire retardent" so it might handle heat at a reasonable distance, but certainly shouldn't get too close to the weld.
We've never had it on during welding, when we welded our chassis we fixtured with other means. Since then we've just not welded the chassis. If we did again, we'd probably fixture with disposable gussets.
Unread 19-08-2012, 16:21
Design Mentor
I have heard a lot about using the bellypan to fixture the chasis before welding. Can you please explain more about how you perform this task?
(I am still relatively inexperienced when it comes to the complete fabrication of such a drive train)
I'd prefer the teardrop shape, as it provides a nice and easy point of contact for the CAM. However, I will look into making the circular part wider to allow for more contact with the 2x1 frame.
Unread 19-08-2012, 16:51
akoscielski3's Avatar
akoscielski3 akoscielski3 is offline
Mentor (1114), Alumni (772)
AKA: Aaron Koscielski
FRC #1114 (Simbotics)
akoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond reputeakoscielski3 has a reputation beyond repute
I would recommend using steal axles. Some may disagree but I have had personnel experience where an axle has completely bent because we got hit on the side of our robot. Axles aren't always the easiest thing to replace, and in a competition environment you won't want to have to change them, especially during the Elimination rounds.
Hall of Fame Team 1114 Simbotics
2013-Present
Host of Simbot Solidworks Series
Team 772 Sabre Bytes
2010-2013
Dean's List Finalist 2013 Waterloo Regional
Unread 19-08-2012, 17:15
apalrd's Avatar
apalrd apalrd is offline
More Torque!
VRC #3333
How large are the slots in the frame for the bearing blocks to slide in?
In 2011, we used 1/2" slots with 1/2" keyed axles and 1/2" OD spacers between the bearing blocks. Once everything was tensioned, we ran it in and the axles opened their own holes in the slots and everything was great.
We had no issues with 7075 aluminum axles, but did preventatively replace two because they keyways were opening (after two tournaments and significant pre-ship practice and development). We also ran 7075 axles this year, including many 1/2" dead axles and two 1/2" keyed primary drive axles (which drove the one live-axled wheel directly, and all of the others via chain).
Kettering Motorsports
Unread 19-08-2012, 17:37
Design Mentor
The slot is 2.25" and the width of the bearing is 1.375". I'm thinking this should be changed drastically. I think I should decrease this distance.
Do you have any pics of your setup?
Unread 19-08-2012, 18:11
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
They look pretty much identical to ours, which have never had issues.
2024 is definitely not good enough for your axles. Go to 7075, or stick with steel.
the bellypan is used for fixturing by riveting it to all of the frame members, which holds them in place as the frame is welded. This results in a better aligned, more square frame than if everything has to be tacked together. It also saves hours of your welder's time. We could never go back to the way we were doing it before at this point.
2001-2004: Team 100
2006-Present: Team 254
