Go to Post I tried to make them look at disgruntled as possible. - Katie_UPS [more]
Unread 19-08-2012, 18:53
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
Shooter off of Live Shaft
We were looking back to some of this year's designs for shooters and we noticed that some teams drove their wheels through a shaft.
Our team was wondering how exactly you drive a wheel off a shaft via a CIM-ulator with an 8mm keyed output shaft similar to that on a CIM motor.
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
Unread 19-08-2012, 19:54
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Shooter off of Live Shaft
We did something similar and used a 8mm to 8mm shaft coupler that we got off McMaster to drive another shaft which the wheel was on.
Later we custom made a gearbox that had an extra long 3/8 keyed shaft that was used with an AM hub.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 19-08-2012, 20:17
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Any pictures from the first version...
Which coupler from McMaster?
Unread 19-08-2012, 21:16
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
Have you seen the AM 8mm key hub? We didn't do anything more complex than direct drive off the CIM-u-lator shaft. Worked well enough once we got our wheel balanced.
FRC 766, 2015-, Mentor
Unread 19-08-2012, 21:39
holygrail's Avatar
holygrail holygrail is offline
Gavin Wood
FRC #1939 (The Kuhnigits)
holygrail is just really niceholygrail is just really niceholygrail is just really niceholygrail is just really nice
We used a 1/2 inch coupler from Grainger and lathed the other end of the shaft down to 1/4 inch for an encoder. The set screws work fine, but I wish we had a continuous shaft from the gearbox or a hex axle instead. We used a different motor and gearbox than you though. It was a banebots 775 with a 4:1 gearbox and it has worked pretty well.
Unread 19-08-2012, 22:00
scottandme's Avatar
scottandme scottandme is offline
AKA: Scott Meredith
FRC #5895 (Peddie School Robotics)
scottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond repute
We used a CIM-SIM, but same concept. CIM-SIM > Coupling > 1/2" Keyed Shaft with wheels on 1/2" keyed bore AM hubs.
Just search "shaft couplings" on McMaster and you can drill down to what you need. We used a helical beam coupler that allows for a little bit of angular/axial/parallel misalignment, but a standard coupling would work fine as well.
It's part number 9061K163, 5/16" is close enough to 8mm (0.0025") that it worked fine. They're made by Ruland, who provides the shaft collars in the KoP. Pickier people could use the metric to metric versions and turn down their output shaft for a closer fit, but the clamp style makes it unnecessary in my eyes.
Unread 19-08-2012, 22:18
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
So basically we could do
CIM-ulator ----- 8mm AM hub ----- directly to wheel???
Unread 19-08-2012, 22:25
daniel_dsouza daniel_dsouza is offline
does what needs to be done.
FRC #2449 (Out of Orbit Robotics)
daniel_dsouza has a spectacular aura aboutdaniel_dsouza has a spectacular aura about
Our team used a belt, mainly because we needed the reduction from the cimulator. A pleasant side effect was that we could use a larger shaft for the shooting wheel.
Unread 19-08-2012, 22:31
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
This year we used:
CIM Motor ----- 8mm hub ----- S35-26LE Sprocket
S35-26LE Sprocket ----- wheel
this was all inside "our box"
So I was wondering how exactly I could do this outside "our box." So could we use a keyed shaft to control our wheel instead with the same setup?
Unread 19-08-2012, 23:34
Mk.32's Avatar
AKA: Mark
http://24.media.tumblr.com/tumblr_lz...s4zo6_1280.jpg
Edit: image was to massive so I just posted the link
Our shooter from last year, the coupler is McMaster: 2469K2
And we sourced 8mm keyed shaft stock from McMaster as well; the wheel has an 8mm AM hub.
Unread 19-08-2012, 23:53
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
So basically:
gearbox (with longer shaft?)----hub----coupler----shaft----wheel
scottandme's Avatar
AKA: Scott Meredith
Possibly a bit unstable. Better to try a solution like the photo above where the flywheel shaft and wheel are supported on both sides by something other than the gearbox itself. Otherwise that's a pretty big unsupported side load on the gearbox.
Lots of options, all just variations on the same theme. Gearbox shaft > coupler > flywheel shaft. It just depends what you have on hand, your feelings about metric hardware, and whether you have access to a lathe.
cimulator > 8mm to 8mm shaft coupler > 8mm shaft with 8mm AM hubs
cimulator > 5/16" to 1/2" shaft coupler > 1/2" shaft with 1/2" AM hubs
If you want to avoid keys you could also use a hex shaft with the end turned down to match a shaft coupler, and then use the AM hex hubs for the wheel.
Unread 19-08-2012, 23:54
scottandme's Avatar
AKA: Scott Meredith
So basically:
More or less, but the wheels attach to the hubs and go on the shafts. The CIM-SIM and Cim-u-lator output shafts are plenty long to fit a coupler, no modifications needed.
Unread 19-08-2012, 23:57
Mk.32's Avatar
AKA: Mark
So basically:
It was
Gearbox [with regular shaft] one end of the coupler goes to this shaft; then longer shaft goes to the other end of the coupler; then the wheel with the hub goes on that shaft. We supported the shaft with a bearing block at the end.
Unread 19-08-2012, 23:58
geomapguy's Avatar
Centenary '18
AKA: Graham Maxwell
FRC #1818
Thanks guys
We are trying to prepare for next season by learning as much as we can.
We are going to try to modify our shooter by using CIMulator instead of a CIM motor direct to the hub.
