Go to Post If this was really about changing the culture, FIRST would be on Will.I.Am's website. - Meredith Novak [more]
Unread 20-08-2012, 01:14
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
Re: Shooter off of Live Shaft
Originally Posted by geomapguy View Post
Thanks guys
We are trying to prepare for next season by learning as much as we can.
We are going to try to modify our shooter by using CIMulator instead of a CIM motor direct to the hub.
Hm if you guys have the machining to do so I would definitely look at designing and building a custom gear box. We used the CIMCIM parts but in a package that was more suited to fit onto our robot. It wasn't a lot of work and came out nice.
http://team3647.tumblr.com/post/22956859964
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 20-08-2012, 01:40
RyanCahoon's Avatar
FRC #0766 (M-A Bears)
So basically we could do
CIM-ulator ----- 8mm AM hub ----- directly to wheel???
Originally Posted by scottandme View Post
Possibly a bit unstable. Better to try a solution like the photo above where the flywheel shaft and wheel are supported on both sides by something other than the gearbox itself. Otherwise that's a pretty big unsupported side load on the gearbox.
Depends on your mounting solution I suppose. The CIM-u-lators have two bearings supporting the output shaft, so they're fairly robust. We have one CIM-u-lator on each side of the wheel and haven't had any problems. Full disclosure: we only attended one regional this year, so I can't comment on how it might hold up during an extended season, but we've had a good amount of out-of-competition drive time, both during and after the season.
I would definitely want to otherwise support the shaft if it's being driven directly from a motor, though.
FRC 766, 2015-, Mentor
Unread 20-08-2012, 01:54
jennhy63 jennhy63 is offline
jennhy63 is an unknown quantity at this point
the wheels attach to the hubs and go on the shafts
Unread 20-08-2012, 02:15
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
No Way? I've been doing it wrong all this time, darn
-RC
*reported
R.C.
MadTown Robotics Team 1323
Unread 20-08-2012, 20:34
geomapguy's Avatar
geomapguy geomapguy is offline
Centenary '18
AKA: Graham Maxwell
FRC #1818
geomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud ofgeomapguy has much to be proud of
This is our current setup with the exception of the sprocket setup in the first picture
The Cowboys - FIRST Robotics Team #1818 2015-
The Bolton Bear Bots - FIRST Robotics Team #3666 2011-204 (30-26-0)
2014 Oklahoma Regional - 20/62 (6-4-0), 5/62 in OPR
2014 Arkansas Regional - 14/39 (8-7-0, Quarterfinalists with 1706 and 1939), 24/39 in OPR
2013 Lone Star Regional Dean's List Finalist!
2013 Lone Star Regional - 22/57 (6-5-0), 17/57 in OPR
2012 Bayou Regional - 16/49 (6-5-0)
2011 Dallas Regional - 10/52 (4-2-5, #6 Alliance Captain, Quarterfinalists with 2948 and 3350)
