Go to Post FIRSTies always get Two Xmases! - [more]
Unread 20-08-2012, 11:35
Gdeaver Gdeaver is offline
FRC #1640
Re: "Gearing for speed" criticism
To go along with this should be what is a reasonable top velocity? I see many posts where teams gear for above 10 fps. Can a driver really control a bot at these top ends? How much time per match is max v needed. I know this is game dependent, but I doubt most teams really need above 8 fps. This also ties into joy stick mapping. I submit that lower gearing gives a more precise control of the bot. Question. On a non wide open field and a robot geared to a 6to 8 fps top end, do you really need a 2 speed gear box? Our top end is about 9fps and single speed. We don't see the need for higher speed in most games and I've at times have pushed for a lower top end. I'll take acceleration and low current draw any day over a high top end.
