Thread Tools |
Rating:
Display Modes |
Re: FRC 2013 Kickoff Countdown
That's depressing. It's so far away. But we'll get there eventually.
Just a note, I've found it seems to go faster and is much more satisfying if you check the countdown less often. |
what if its always on... why cant I just speed it UP!!!!!
If you circle multiple times around the globe the days will go faster!
Related note: My background for my laptop is a first kickoff timer. As well as for every district/regional I attend. |
Well, I just found a new homepage. Thanks!
Would've been perfect if you had used FIRST colors and font. But I still can't wait.
#7
P.S. @vineel, you may want to double check how the time is being calculated. It's saying ... 14 hours, 15 minutes, which doesn't put me at 10:30 AM EST even if you take into account the switch to Standard Time. Are you using my local timezone (PDT)? Last edited by Eugene Fang : 24-08-2012 at 02:21. |
#8
The Kickoff broadcast began at 10:30 EST last season.
#9
Ah, robot season.... its so close.
The real kickoff starts when Mark McLeod begins his 2013 Registration thread. |
#10
I'm having a slight issue with the kickoff timer...
#11
The same thing happens on my computer. I assume its a little math fun to distract us from the why-isnt-kickoff-yet-blues a little while longer
#12
I'm guessing that those dashes are 'minus' signs, and that it's 4 months minus the days, hours, minutes, and seconds. At first I was confused, because I thought it was counting up.
Also, I have the same "issue" with the scrollbar popping in for when the wider numbers are shown (I'm looking at you, 44). Probably just needs to be a little wider than 960 pixels (at least that's how wide the panel is in Chrome at 1920x1080). |
#13
you can make it go faster if you own a Delorian
#14
Ha! Nice.
#15
check out the TFA timer!
thefirstalliance.org |
