Go to Post All I can say is - we are such geeks! - Raul [more]
Unread 22-08-2012, 18:32
rcmolloy's Avatar
rcmolloy rcmolloy is offline
Remote Mentor
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
pic: Single Speed Gearbox Iterations
Unread 22-08-2012, 18:34
Andrew Lawrence
Posts: n/a
Re: pic: Single Speed Gearbox Iterations
Very nice gearbox. Is it a direct drive? Just curious - what was its intended purpose? Was it just for fun, or designed for future use?
Keep up the awesome work! I can't wait to see the 3D model!
Unread 22-08-2012, 18:56
DampRobot's Avatar
Physics Major
AKA: Roger Romani
What motors is this for? It looks like it's some sort of CIM or two BaneBots setup...
-Plutarch
Andrew Remmers's Avatar
Andrew Remmers Andrew Remmers is offline
AKA: Andrew Remmers
Andrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond reputeAndrew Remmers has a reputation beyond repute
Send a message via AIM to Andrew Remmers
What size wheel does it drive to get that speed?
- Andrew
Exploding Bacon 2007-2011
Built and Dangerous (B.A.D) 2011-2012
Community Mentor / School Break 2012-2014
North American Robotics: The MooseEagles Founding Member 2012-Present (VEX U)
Unread 22-08-2012, 20:19
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
I'm guessing a 4" wheel, directly driven by the gearbox output, at full (normal) load CIM speed (4320 RPM according to the CIM data sheet) -- so ( 4320 / 5.74 / 60 ) * pi()/3 is about 13 ft/sec. Free speed would be faster, about 16 ft/sec.
Richard Wallace
since 2003
Unread 22-08-2012, 21:04
rcmolloy's Avatar
Remote Mentor
Richard pretty much clarified everything up from a technical standpoint. I still can't believe he grabbed that much from the crowded drawing. Thanks for clarifying up the math. I felt like I was a bit off somewhere haha.
It's a 2 cim box if you can make out the mounting holes that are perpendicular to the plane that the intermediate shaft and pinions are sitting on. I'm sure the cims will stay in that orientation as of right now but that may change with another iteration down the line.
The gearbox was created because of bordom and my want to increase my design ability. AdamHeard and I are really working close on honing in my design skills this year and I just decided to start throwing stuff at him to check out. This box wasn't terribly difficult to make but it still helps me since this is the first 2D layout that I have pretty much completed up to 90%.
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 22-08-2012, 21:22
Originally Posted by rcmolloy View Post
...this is the first 2D layout that I have pretty much completed up to 90%.
Nice job.
Keep throwing stuff at Adam Heard, you will get really good at this.
Richard Wallace
since 2003
Unread 22-08-2012, 22:35
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
You can get that entire reduction in 1 stage. Lighter, simpler, more efficient.
12:72 will work with a 4" wheel, and actually gets more reduction than you have right now. (12:69 would be right about where you are currently.)
I always use a 12t or smaller on my CIMs because it allows us to put the gear on the CIM before installing it through the CIM 0.75" pilot hole.
Instead of spending money on COTS gears, you could go find a local shop who can make you some custom aluminum 72-toothers for cheap (or free). You're not going to need a whole lot of gear, should be nice and light.
-John
Unread 23-08-2012, 00:20
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
-John
Quick question from this; because we like to be able to put the gear on the CIM before we put it in the gearbox, I bored the CIM mounting holes to about .9 so a 14th would fit though it; so does it really matter that you use a .75 pilot hole?
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 23-08-2012, 00:25
IanW's Avatar
IanW IanW is offline
Rookie Mentor
AKA: Ian
FRC #0997 (Spartans)
IanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond reputeIanW has a reputation beyond repute
The idea behind using a .75" pilot hole is to help align/center the CIM, which has a protrusion at the base of the output shaft that is also .75" in diameter.
Website
Facebook
Unread 23-08-2012, 00:26
Mk.32's Avatar
AKA: Mark
I understand this but is it really necessary?
Unread 23-08-2012, 00:34
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Mark,
I highly suggest it. The thing with the .75 hole is that it supports and locates the CIM. We've had older robots have the CIMs come loose and sometimes even break bolts because the bolts took all the load. John is spot on with the .75 hole.
We use the 14T gear still. We just slide the CIM in with the spacer and put the gear on and add the push nut/retaining clip. Its not that much time (30 seconds more).
-RC
R.C.
MadTown Robotics Team 1323
Unread 23-08-2012, 00:41
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
No, but your gearbox will perform much better (with less effort) if you do.
2001-2004: Team 100
2006-Present: Team 254
Unread 23-08-2012, 01:06
JVN JVN is offline
@JohnVNeun
As said by others... it is not a good idea to locate the motor using the motor mounting screws. That little .75 pilot hub is great because it helps ensure good center-center distance.
Aside:
I don't see any reason to use a 14t over a 12t. Whatever gear math people are doing which says 14 is better than 12... I haven't seen it, and I like to think I've played with these numbers quite a bit.
-John
Unread 23-08-2012, 01:10
Mk.32's Avatar
AKA: Mark
Cool, thanks for the tips.
definitely use the .75 CIM hole on my next boxes.
