Go to Post Dash Board: Hey Robot, here is some new data. Dash Board: Robot, did you get that data yet? Hello? Robot: Yep! Thanks! Yep! Thanks! Yep! Thanks! Yep! Thanks! Yep! Thanks! Yep! Thanks!... Other Robots: Will you please shut up? - EricVanWyk [more]
Unread 08-22-2012, 11:22 PM
DMetalKong's Avatar
DMetalKong DMetalKong is offline
AKA: David K.
DMetalKong is a jewel in the roughDMetalKong is a jewel in the roughDMetalKong is a jewel in the rough
Send a message via AIM to DMetalKong
Re: Team 548 Einstein Statement
Originally Posted by Alan Anderson View Post
An 802.11 protocol change that encrypts "management packets" could probably prevent deauthorization flood attacks from succeeding. It would also break a lot of things in the process.
I think that breaking things could be acceptable for use in FRC if the need is strong enough. As long as only firmware is changing, and not hardware, the cost of deployment would not be as great as an entirely custom solution.
Did you read the Einstein investigation report through to the end? The last two pages are all about planned possible changes, with a half dozen of them as specific solutions to observed problems.
I did read the report I was referring more to the various threads on CD that have been started about the topic.
