Go to Post Dash Board: Hey Robot, here is some new data. Dash Board: Robot, did you get that data yet? Hello? Robot: Yep! Thanks! Yep! Thanks! Yep! Thanks! Yep! Thanks! Yep! Thanks! Yep! Thanks!... Other Robots: Will you please shut up? - EricVanWyk [more]
Unread 23-08-2012, 15:51
ToddF's Avatar
ToddF ToddF is offline
mechanical engineer
AKA: Todd Ferrante
FRC #2363 (Triple Helix)
ToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond reputeToddF has a reputation beyond repute
Re: pic: Single Speed Gearbox Iterations
Here is our prototype from earlier in the summer:
Todd F.
mentor, FIRST team 2363, Triple Helix
Photo gallery
video channel
Triple Helix mobile
Unread 23-08-2012, 15:56
AdamHeard's Avatar
Lead Mentor
What I like;
-Combing the upper standoffs with the CIM bolts! So many advantages here.
-Overall profile looks clean and logical.
-Pocketing is a solid start, that's the hardest thing to do right... and everyone has a different opinion of what looks good.
-Combining the lower standoffs with your frame mounting.
-Using the same plate for both plates.
Unread 23-08-2012, 17:55
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Originally Posted by JVN View Post
Whatever gear math people are doing which says 14 is better than 12... I haven't seen it, and I like to think I've played with these numbers quite a bit.
-John
The benefit could be a better running gear mesh. I believe a 12 tooth gear has an undercut at 20 pitch and 14.5 degree pressure angle, while I think a 14 tooth is out of the range requiring the undercut geometry. That said, for typical FRC applications, I'd still go with 12 tooth gears, since they fit through the hole, as others stated. And yes, I too highly recommend a close-fitting .75" hole to locate the motor.
Unread 23-08-2012, 18:46
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
Would a better running mesh mean more a more efficient or quieter stage in the gearbox? And would there a mathematical method of calculating at what point there is an undercut?
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 23-08-2012, 19:21
AdamHeard's Avatar
Lead Mentor
I'd have to confirm this, but an undercut shouldn't be any less efficient. It just needs the tooth to be reduced in size near the base to prevent impact of teeth; the involute surface should still be maintained.
It really is a substantial strength decrease; but as shown by numerous robots running them they are still strong enough.
Unread 23-08-2012, 19:25
Garret's Avatar
AKA: Garret Smalley
Thanks, I never realized the strength decrease but it makes a lot sense thinking about it now.
7 Years of FRC
Unread 23-08-2012, 20:30
PAR_WIG1350's Avatar
AKA: Alan Wells
FRC #1350 (Rambots)
In the first stage of a gearbox the force would be lower than it would be in later stages so the effect is minimized, identical gears in later stages might not fare as well. This is why the gear teeth in the fisher price gearbox get larger with each successive stage.
Unread 23-08-2012, 21:05
AdamHeard's Avatar
Lead Mentor
I'm not sure what you're getting at with this post, this matches what I said about increasing toothsize as you go further in the stages.
EDIT: Reread, you're referring to the undercut gears not the plastic gears. Your Point is valid.
Unread 23-08-2012, 22:02
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Suggestion,
A couple of pressed in stainless steel guide pins would make this baby slide right in/out and align to the mating shaft and frame. Using guide pins can reduce the number of bolts to the frame and provide a accurate fit.
See how a car transmission bolts to a engine. Usually a couple of pins on the bell housing that mate to blind holes on the engine. The pins help to align the shafts and just a couple of bolts to hold the transmission on.
Roy
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 24-08-2012, 07:54
mwilbur's Avatar
mwilbur mwilbur is offline
AKA: Matt Wilbur
mwilbur is a glorious beacon of lightmwilbur is a glorious beacon of lightmwilbur is a glorious beacon of lightmwilbur is a glorious beacon of lightmwilbur is a glorious beacon of light
What I like;
You're spot on with our thinking, but note that the plates are mostly the same because the CIM-side plate uses a 7/8" OD (FR6) bearing on the output shaft rather than the 1.125" (FR8) bearing on the output plate side. Otherwise, there are no differences between the plates, although we had considered tapping the screw hole in the CIM-side plate to elimnate the nuts.
The "design" is really more or less a copy of what we've observed in the Cheesy Poofs' gearbox designs. We wanted to start simple with a single speed gearbox, then move forward at a comfortable pace to determine what works best for us.
Matt Wilbur
Head Coach, Triple Helix
FRC Team 2363
Menchville High School
Newport News, VA
Triple Helix... it's in our genes!!!
Unread 24-08-2012, 08:40
Nate Laverdure's Avatar
FRC #2363
I believe a 12 tooth gear has an undercut at 20 pitch and 14.5 degree pressure angle...
Both the 12-tooth and the 14-tooth pinions will be undercut, but the 12-tooth more severely so. From page 141 (PDF link):
Originally Posted by Boston Gear catalog
On 14.5 PA gears undercutting occurs where a number of teeth is less than 32 and for 20 PA less than 18.
The formula for the number of teeth (z) required to eliminate undercut is:
z = 2 / sin^2(a)
where a is the pressure angle. Interestingly, this isn't dependent on pitch.
Unread 24-08-2012, 09:59
AKA: Alan Wells
FRC #1350 (Rambots)
z = 2 / sin^2(a)
It is independent from the pitch since all gears of the same pressure angle and tooth count are geometrically similar. All 14.5 degree pressure angle gears with 24 teeth are the same profile, just at different scales.
Unread 24-08-2012, 18:34
rcmolloy's Avatar
rcmolloy rcmolloy is offline
Remote Mentor
AKA: Robert Cory Molloy
rcmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond reputercmolloy has a reputation beyond repute
Hey guys I really appreciate all of the discussion and its helping out a LOT. There is a bunch of things that I've seen, like the CIM .75 shaft guide extrusion, that have really helped me out with more detailed design.
On that note, wouldn't it be possible to have a press fit of x OD and .75 ID to fit over the CIM that would allow the possibility to help guide into larger sized holes? I feel as if the trade off would only help getting a much larger reduction in a smaller packaging and ultimately a smaller finished assembly. If anyone opposes to the fact or sees it as being not beneficial then please let me know!
FRC 1647: Iron Devils - 2009 - 2011
FRC 973: Greybots - 2011 - 20XX
"While I was a student in FIRST, it was all about becoming inspired. Now as a mentor/engineering student, it's all about making sure learn everything I can so I can carry that on inspiration for future generations while having a hell of a lot of fun!"
Unread 24-08-2012, 18:41
Chris is me's Avatar
AKA: Pinecone
This is totally possible, but if you want a larger reduction in a smaller package, that's exactly what a 12T pinion would do for you!
Unread 24-08-2012, 19:38
rcmolloy's Avatar
Remote Mentor
Ah ok! I suppose I just had my logic a bit backwards when writing the post. Also, proved it with a little bit of math too haha.
