Go to Post Don't limit programming to just hitting keys, there is a lot of logic/design involved. - Mike [more]
Unread 24-08-2012, 15:51
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
pic: 2012 FRC971 Transmission Actual
Unread 24-08-2012, 15:52
steelerborn's Avatar
steelerborn steelerborn is offline
Engineer at JBT FoodTech
AKA: Jonathan Stokes
FRC #5817 (Uni-Rex)
steelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant futuresteelerborn has a brilliant future
Re: pic: 2012 FRC971 Transmission Actual
Really like this setup! You guys had a great bot this year!
Do you have an overall weight for the transmission? It looks very light weight, plus with AL gears.
Good enough is the enemy of anything great!
team 1671
Unread 24-08-2012, 18:42
AllenGregoryIV's Avatar
AllenGregoryIV AllenGregoryIV is online now
Engineering Coach
AKA: Allen "JAG" Gregory
FRC #3847 (Spectrum)
This is a very nice looking gearbox.
How do you mount the two gears to the output of the CIM that allow you to do single reduction?
What is the part number/soruce for the pancake cylinder they seem really useful in this application.
Unread 24-08-2012, 19:46
James Kuszmaul James Kuszmaul is offline
NEFIRST CSA
FRC #0971 (Spartan Robotics)
James Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud of
Not entirely sure what you are asking here, but the way the gears are mounted to the CIM shaft is by pressing a hex sleeve over the CIM shaft, then using the hex to mount the gears. If I remember correctly, then the smaller gear is 15 tooth, the larger is 30, and then the two gears in the second stage are 60 tooth and 45 tooth, respectively.
Bimba FO-020.3-3FMT
FRC971 (Student) 2011-2014
FRC190 (College Mentor-ish) 2014
WPILib Development 2014-present
Unread 25-08-2012, 01:05
Engineering Coach
Bimba FO-020.3-3FMT
That's exactly what I was asking, thank you for the quick response.
Unread 25-08-2012, 02:21
DampRobot's Avatar
Physics Major
AKA: Roger Romani
If I were to design up a transmission like this, I would get a lot of flack from the programming leadership about not including space for an encoder. Did you end up including one that we can't see, or was there an argument for not including one?
-Plutarch
Unread 25-08-2012, 03:17
FRC #1836 (MilkenKnights)
Most teams who do WCD end up just connecting an encoder to another wheel(any of the front or back wheels) and then zip tying the encoder wire down to the bellypan. I can speak for 971 but I assume they did this too.
Unread 25-08-2012, 12:13
Chris is me's Avatar
AKA: Pinecone
971's drive wasn't a WCD, and since they used dead axles, I doubt this was the method they chose.
Unread 25-08-2012, 15:13
Nick Lawrence's Avatar
Nick Lawrence Nick Lawrence is offline
Commander Canada
FRC #3940 (CyberTooth, AndyMark)
Nick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond reputeNick Lawrence has a reputation beyond repute
This is actually beautiful.
Man, you guys make some of the nicest robots around.
-Nick
Alumnus of 1503 Spartonics
Founding Mentor of 5406 Celt-X
Mechanical Design Mentor of 3940 CyberTooth
Emceeing events since 2013 - come say hi!
Success doesn't always equate to match wins. It's about the wins off the field.
Unread 25-08-2012, 15:23
kevincrispie's Avatar
kevincrispie kevincrispie is offline
kevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to behold
The encoders aren't part of the transmission. They are off on the back wheels on a plastic gear I believe.
"If you want to build robots, you're going to have to break a few small appliances"
Unread 25-08-2012, 15:50
DampRobot's Avatar
Physics Major
AKA: Roger Romani
And just to be clear, did you ever end up using them? In my experience, they are often a pain to design in, and not that useful for the programming team.
-Plutarch
Unread 25-08-2012, 16:01
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Why do you find them to be not very useful?
2001-2004: Team 100
2006-Present: Team 254
Unread 25-08-2012, 16:12
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
If you just use the AM encoder bracket for the E4P ts really straight forward to design them in; from memory I think its something like .75" out to each side and .1875" down for the mounting holes with respect to the shaft.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 25-08-2012, 18:05
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Pretty easy to design in. Just drill a 1/4 hole and shove a s4 in. Literally no work at all.
-RC
R.C.
MadTown Robotics Team 1323
Unread 25-08-2012, 19:51
DampRobot's Avatar
Physics Major
AKA: Roger Romani
The theory always seems to be that they will get used for autonomous tracking or smoothing out driver control or something. Because the programming team seems to have so much trouble even getting basic functionality, they never end up getting used.
I don't mean that it's hard to design in two drilled holes. I mean that often both sides of the output shaft are used, so there is no easy place for an encoder.
Thanks for the tip about zip-tieing the encoder to the bellypan, and putting it on a wheel shaft. Wouldn't that cause them to rotate off axis?
-Plutarch
