Go to Post "Why even bother building a robot if we're not gonna win?". The answer? To learn and grow. - MrBydlon [more]
Unread 24-08-2012, 13:42
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
pic: 2012 frc971 transmission
Unread 24-08-2012, 13:43
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: pic: 2012 frc971 transmission
Are those custom gear's or are they ones from andymark?
Also, Where do you get these special pneumatic pistons, bimba? and how are they different from the standard ones?
Unread 24-08-2012, 13:46
I loved your simple solution to saving space this year, along with the pancake cylinders for shifting. Are there any tips or tricks you might have when making an "inverted" gearbox? Were there any issues you encountered that were unique to this type of setup? What would you do differently?
Thanks!
Unread 24-08-2012, 15:11
Jared Russell's Avatar
Taking a year (mostly) off
Is there any measurable benefit to the fan above the CIMs?
Unread 24-08-2012, 15:35
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
The pistons are from Bimba. They are shorter than a standard piston (albeit wider). They also generally ouput less force, as the rod is smaller than the commonly used shifter pistons.
2001-2004: Team 100
2006-Present: Team 254
Unread 24-08-2012, 15:41
SteveGarward's Avatar
SteveGarward SteveGarward is offline
Red 5, standing by...
AKA: 7 years already
FRC #0111 (WildStang), FRC #3132 (Thunder Down Under)
SteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud ofSteveGarward has much to be proud of
Do you have a part number for the pistons? I was looking at a couple of different ones a couple of weeks back. Just curious which ones people are using.
FRC Team 111 - WildStang (Mentor, Drive Coach)
FTC Team 7458 - Full Force! (Mentor, Coach)
FRC Team 3132 - Australia's FIRST FRC Team! (Holy crazy first year, Batman!)
Unread 24-08-2012, 17:16
R.C.'s Avatar
R.C. R.C. is offline
2017... Oooh Kill em, Swerve!
FRC #1323 (MadTown Robotics)
Jared,
They really helped on the practice bot. I was talking to Austin at Davis this year and was unsure about trying out fans. After Davis we put fans on the practice bot, it really helped us get longer practice time.
On the comp bot in 2 minute matches, totally unsure 971 would have to answer that one.
-RC
R.C.
MadTown Robotics Team 1323
Unread 24-08-2012, 17:48
cbale2000's Avatar
cbale2000 cbale2000 is offline
AKA: Chris Bale
FRC #5712 (Gray Matter)
cbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond reputecbale2000 has a reputation beyond repute
I don't have any experience with them on CIMs, but I added one to the KOP air compressor on our demo bot and it dropped the running temperature and idle cooling time significantly. We had been having issues where the compressor would get so hot from running constantly it would melt the hose coming out of it (causing an "explosive" loss of pressure). Since adding the fan we have yet to see such a problem occur again, even after a 5+ hour demo that was outside on a hot day and in direct sunlight.
Somewhat related, on this years robot we used two FisherPrice (I think) motors to run our shooter system. We had been having an issue where after moderate use, the motors would heat up and then, the lower one in particular, would stall when trying to shoot a ball. The motor had been mounted to the robot using an aluminum collar we made for it (which covered about 60% of the motors surface area and was roughly 3/4" thick). To fix the problem, I took the collar off and cut small groves around it (like a computer heat-sync, and since putting it back on the robot we have yet to have the launcher stall on us again.
I could see a fan on a CIM being useful particularly in elimination rounds where you have a lot of matches close together with very short breaks between them. In years past our motors have gotten very hot (one year we even used a can of compressed air upside-down to cool down our drive motors) during finals, so an active cooling system could be a good way to alieviate such problems and maybe squeak out that little extra bit of performance during the most important matches.
TL/DR version: Temperature matters, cooler running motors will perform better.
2005-2008: FRC 703 Phoenix - Driver
2009-2016: FRC 703 Phoenix - Mentor
2017-????: FRC 5712 Gray Matter - Mentor
Unread 24-08-2012, 19:42
AdamHeard's Avatar
Lead Mentor
I'm not seeing how this is single reduction. I can't get the numbers even close to those speeds, and in the picture it looks like the gearshaft is above the wheelshaft (or the wheels would hit the CIMs).
Is there another gear reduction external to this gearbox that directly drives the center wheel?
Unread 24-08-2012, 20:08
James Kuszmaul James Kuszmaul is offline
NEFIRST CSA
FRC #0971 (Spartan Robotics)
James Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud ofJames Kuszmaul has much to be proud of
You are correct; A 15 tooth gear coming from he transmission drives a 50 tooth gear which is on the same axle as the wheel.
FRC971 (Student) 2011-2014
FRC190 (College Mentor-ish) 2014
WPILib Development 2014-present
Unread 25-08-2012, 15:29
kevincrispie's Avatar
kevincrispie kevincrispie is offline
kevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to beholdkevincrispie is a splendid one to behold
In the back of the picture, you might be able to see that some of the wheels had gears on them. These were the center wheels that interfaced with the transmissions.
"If you want to build robots, you're going to have to break a few small appliances"
Unread 27-08-2012, 01:57
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
The use of the final gear allows us to make the transmission removable while the belts and wheels can stay on the chassis all tight. Let's see a WCD do that.
We need to make the inside side plates a little stiffer by insert some bends into the plate. This will give us a flange to mount the plastic grease guards.
We need to insert alignment pins from the transmission to the chassis to ease the assembly and get the optimum gear spacing. We had to manually tune the alignment and if the screws became loose the transmission would have power loss.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 27-08-2012, 16:26
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
Yes,
Fans help out on other motors too. Try running a pair of Fisher Price motors at high load and run them intermittently in forward and reverse. They don't like that and you will see how smoking hot they get. Attach a pair of small fans to direct continuous air flow over the motor cooling slots and casing and you will see a tremendous improvement of the power output over a time frame.
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
Unread 27-08-2012, 17:15
Nate Laverdure's Avatar
FRC #2363
I love the space savings with this "inverted" setup, but in order to place the CIMs outboard of the gearbox, you risk a higher moment of inertia. This will have the effect of making the robot harder to turn.
Some quick calculations tells me that moving the CIMS outboard will increase the total moment of inertia by about 5% (for a "long" chassis) to 8% (for a "wide" chassis) for an otherwise equally-distributed robot. For a constant turning torque, this results in a similar percentage less angular acceleration.
Takeaway: for a snappy turning response, mount your heaviest items as close to the center of rotation as possible.
Unread 27-08-2012, 17:49
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
This is a good point, and 5% is something that will be noticeable to most drivers. There are a few other factors as well that go into the decision for us:
1) With most 6wd dropped center setups, turning is usually really really snappy already, sometimes too much. Especially with a robot geared above 15fps, turning response can be almost uncontrollable without a lot of practice.
2) The drive code that 971 uses (along with 254 and maybe some other teams) is set up to do controlled radius turns in normal operation, rather than controlled turn rate, which mitigates the "snap" turn response characteristic of 6wd. This makes the robot much more controllable at high speeds (the 971 2012 robot was geared to 17fps no load). Further discussion on this style found here. Because of this, we try to avoid needing to turn in place when we drive, so the moment of inertia aspect isn't really an issue for us.
