Go to Post I realize that I've been drawn into the trap of thinking that this is about robots and scores and winning. Reboot. Remember why we do what we do. - Mr. Van [more]
Unread 27-08-2012, 21:50
Mk.32's Avatar
Mk.32 Mk.32 is offline
AKA: Mark
FRC #2485 (W.A.R. Lords)
Mk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud ofMk.32 has much to be proud of
pic: Delrin Poly Cord Pulleys
Unread 27-08-2012, 21:52
Camren's Avatar
Camren Camren is offline
FRC #3081 (RoBoEaGleS)
Camren is a jewel in the roughCamren is a jewel in the roughCamren is a jewel in the rough
Re: pic: Delrin Poly Cord Pulleys
Interesting I assume those are machine lathed. But from what material?
Unread 27-08-2012, 21:59
Josh Fox Josh Fox is offline
AKA: Foxy
FRC #0027 (Team RUSH)
Josh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud ofJosh Fox has much to be proud of
Appears to be some sort of plastic...
Team RUSH Alumnus and Mentor, Mechanical Engineer
Unread 27-08-2012, 22:03
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
I assume delrin, because of the title.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Alex Cormier's Avatar
Alex Cormier Alex Cormier is offline
www.TwoPencilDesigns.com
AKA: Grizz, Twinkletoes, PitBull1126
FRC #1405
Alex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond reputeAlex Cormier has a reputation beyond repute
Photo title says delrin. It's a good all around plastic that doesn't wear when using polycords. It's a bit heavy though.
Two Pencil Designs - Vinyl Graphics, Bumper Numbers, and Strategy Items!
Like us on Facebook & follow us on Twitter
Facebook.com/TwoPencilDesigns & TwoPencilDesign
Unread 27-08-2012, 22:08
Camren's Avatar
Wow its sorta like looking for the 7/16's wrench in the shop. It always appears in the most obvious place.
Unread 27-08-2012, 22:29
Best Available Data
FRC #1778 (Chill Out!)
Is it actually Delrin?
Unread 27-08-2012, 22:39
theawesome1730's Avatar
theawesome1730 theawesome1730 is offline
FRC #1730 (Team Driven)
theawesome1730 will become famous soon enough
Hope that there is never enough friction generated to melt/burn the Delrin, the fumes/smoke it gives off is like tear gas
2015 GKC Engineering Inspiration
2015 Colorado Winners
Unread 27-08-2012, 22:45
Mk.32's Avatar
AKA: Mark
Hello all,
These are machined from Delrin 1inch stock.
They weigh about .3lbs each; which we found to be reasonable for the pulleys and a LOT lighter and cleaner then our last solution.
Delrin is pretty stiff stuff and as poly cord pulleys shouldn't ever experience friction to really melt/burn it.
Engineering mentor: Team 2485: WARLords 2013-
Team President: Team 3647 2010-2013
Unread 28-08-2012, 08:11
Jared Russell's Avatar
Taking a year (mostly) off
What is the OD of the grooves? No worries about the rod deflecting under tension?
Unread 28-08-2012, 08:54
Brandon Holley's Avatar
To go along with Jared's questions, what diameter round belting (polycord) are you using? If the pulleys are machined from 1" diameter stock, you may be very far below the suggested minimum pulley size.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
Unread 28-08-2012, 10:37
JesseK's Avatar
JesseK JesseK is offline
Expert Flybot Crasher
FRC #1885 (ILITE)
Most polycord has a minimum pulley diameter, and the pulley diameter gets bigger as the cord diameter gets bigger. Exceeding the minimum diameter puts extra load on the motor driving it.
For example, the hollow Yellow Round Urethane belts my team likes to use (McMaster # 6567K56) has a minimum pulley diameter of 1.5". This year we were able to get away with a 1" diameter @ 3% cord stretch, given the gearing & power of the motors we chose. If we used a weaker motor or faster gearing, we would have probably enforced the 1.5" diameter design parameter. We also relaxed the belts overnight and in between competition so they didn't wear faster than expected.
Just something to keep in mind.
GitHub
Unread 28-08-2012, 12:01
Mk.32's Avatar
AKA: Mark
The ID of the pulleys are .64 in.
We are using a smaller diameter then what was recommend but from past experience not have a lot of problems with it.
We are going to put these in later today, and I will report back about any problems.
Unread 28-08-2012, 14:18
topgun's Avatar
topgun topgun is offline
FRC #2846 (FireBears)
topgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant futuretopgun has a brilliant future
Doesn't the hollow round belting flatten out when installed? Have you had trouble with the little connectors coming out?
We have only used the solid round belting but I am wondering if anyone can give a quick pros/cons of solid versus hollow.
- T
-T
Unread 28-08-2012, 14:58
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
- T
No and no.
We have used hollow belts more than a few times and the only times I have have had one separate at the connector was when belts were installed to loosely. They kind of work like finger cuffs, harder you pull the more they hold on.
The only reason we have used hollow belting was because it was easy, no other big reason. They are both great. One advantage to hollow belting is it can be removed and replaced without removing rollers. Solid belting gives you more choices of belt thicknesses and will generally allow smaller roller diameters.
