Go to Post If anybody ever uses a terabyte in the next few years the world would probably come to an end - spadercool [more]
Unread 28-08-2012, 11:57
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
Re: pic: 2012 frc971 transmission
Belts have better damping characteristics under load. Try running a chain setup vs a belt setup over 12 inches to a high speed shooter wheel and you will see a big difference in the speed control, efficiency and the damping.
Belts are quite. There is less friction loss with belts which means higher motor efficiency. Chain tends to stretch over use belts do not. Lastly belts are easy to align they are more forgiving in long runs and when properly tensioned don’t require chain guides
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
