Go to Post Profesional Gracism - n. the blessing said before Robotics competitions begin. - Cynette [more]
Unread 29-08-2012, 20:12
Walter Deitzler's Avatar
Walter Deitzler Walter Deitzler is offline
UAH Class of 2019
FRC #3397 (Robolions)
Walter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond reputeWalter Deitzler has a reputation beyond repute
WCD vs Standard
What is the advantage of a WCD over a standard drive? Why would you choose to do a WCD 8 wheeled or WCD 6 wheeled over a standard 8 or 6 wheeled drive?
(Hanging out with my buddies at 610)
Robotics, it's not just a club, it's a career.
FLL Referee (2012-Present)
2014 Gateway Robotics Challenge winners (With 2481 and 1985)
2011 St. Louis Regional Winners (With 1985 and 3284)
2010 Highest Rookie Seed
I am the guy in the golden hat, say "Hi!" to me at WORLD CHAMPIONSHIPS!!!
Unread 29-08-2012, 20:14
Re: WCD vs Standard
Hey Walter,
There are several threads that discuss the pros and cons of each style of drive. I search should yield you the results you are looking for.
Let us know if you can't find them.
-Akash
UAH Class of 2019
Re: WCD vs Standard
I tried finding them, but only found WCD vs. Swerve and many pictures of a WCD.
Unread 29-08-2012, 20:17
Andrew Lawrence
Posts: n/a
Re: WCD vs Standard
Some things I've found on my way asking the same questions you do:
http://www.chiefdelphi.com/forums/sh...&highlight=WCD
All in all, WCDs are lighter, allow for direct drive (more efficient), and the wheels a bit farther out for better turning. 6WD vs. 8WD is mainly based off of whether or not the robot has to traverse an object (climbing over the bumps in '12 and '10). 8WD also allows a smaller wheelbase, so that a robot can be more maneuverable, but the turning difference is often nothing a 6WD can't do, and the extra weight isn't worth the little bit of turning help on a flat field.
Unread 29-08-2012, 20:22
UAH Class of 2019
Re: WCD vs Standard
Thank for that Andrew, some of those links will be helpful, but as for the 6 vs 8 wd, I phrased the question poorly, that is not what I am looking for. The standard vs. WCD ones are useful though!
Thanks!
avanboekel's Avatar
avanboekel avanboekel is offline
AKA: Adam Van Boekel
FRC #5934 (Gear it Forward, Crowbotics)
avanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant futureavanboekel has a brilliant future
Re: WCD vs Standard
SuperNerd's last link is probably what you are looking for (If I am reading your question right, you want to know the pros and cons of a WCD vs a non WC 6WD, not 6wd vs 8wd).
2338 Gear It Forward | Student 2010-2013 | Mentor 2014-Present | oswegofirst.org
2013 Wisconsin Regional Winner (1732, 111, 2338)
2013 Midwest Regional Dean's List Finalist
2015 Midwest Regional Chairman's Award Winner
2015 Archimedes Subdivision Winner (1023, 2338, 3996, 1089)
2016 Midwest Regional Chairman's Award Winner
4096 CTRL-Z | Mentor 2014 | team4096.org
5934 Crowbotics | Mentor 2016-Present | crowbotics.org
Unread 29-08-2012, 21:05
MattC9's Avatar
MattC9 MattC9 is offline
MattC9 has a spectacular aura aboutMattC9 has a spectacular aura aboutMattC9 has a spectacular aura about
Re: WCD vs Standard
Do you have solid proof that WCD are lighter than any other drive?
Unread 29-08-2012, 21:07
UAH Class of 2019
Re: WCD vs Standard
Okay, so in the 4th link, I saw that WCD's use a live axle, vs. a Standard using a dead axle.
First off, could some elaborate on the difference between the two? I found the posts kind of confusing as to the difference (the live axle is spun by chain or gears or motor while dead axle is just sitting there, not powered?)
Next: Why would you choose a live axle over a dead axle, if the center wheel is lowered, thus making your robot rock between the front and back wheels? It seems that live axles (if I have their definition correct) would make the 6 wheeled work like a 4 wheeled when it turns, porblematic. But, when observing many WCD's, I do not see slick wheels or omniwheels to offset the traction/turning problems associated with a 4 wheeled.
Unread 29-08-2012, 21:15
JosephC's Avatar
JosephC JosephC is offline
FF: Breakfast Company
AKA: Joseph Cupchack
no team (FiM Volunteer Extraordinaire)
JosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond reputeJosephC has a reputation beyond repute
Re: WCD vs Standard
To my understanding, A live axle is one that supports part of the weight of a robot and drives the wheel(s) connected to it. A dead axle is one that carries part of the weight of a robot but does not drive the wheel(s). The wheel(s) rotate on the end of the dead axle.
Referee: 2015 - ?
Field Reset/Supervisor: 2013 - ?
68 Team Member: 2011 - 2013
Unread 29-08-2012, 21:21
smistthegreat's Avatar
smistthegreat smistthegreat is offline
robots is a hard job
AKA: Brian Smist
FRC #4930 (The Electric Mayhem)
smistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond reputesmistthegreat has a reputation beyond repute
Re: WCD vs Standard
All of your information is correct, but you make a couple of incorrect conclusions. Yes, live axle is when the axle itself is powered, and dead axle is when only the wheel is powered. Also, you are correct about the drop center making it turn like a 4 wheeled drive. However, this 4 wheeled drive now has a shorter wheelbase, making it easier to turn. The whole point of dropping the center wheel is to shorten the wheelbase enough to where it turns smoothly without adding slick or omniwheels
University at Buffalo | Mechanical Engineering | Class of 2016
2014-20?? | Mentor | 4930 | The Electric Mayhem
2013 | Mentor | 229 | Division by Zero
2013 | Mentor | 4124 | Integration by Parts
2009-2012 | Student | 1507 | Warlocks
Unread 29-08-2012, 21:45
Andrew Lawrence
Posts: n/a
Re: WCD vs Standard
No outer framing. Basically eliminates about 86" of outer railing (assuming a 37" long by 27" wide bot). Center wheel is direct drive, so less chain (6 chains per average 6WD, 4 for your average 6WD WCD).
Unread 29-08-2012, 22:48
BrendanB BrendanB is offline
AKA: Brendan Browne
FRC #1058 (PVC Pirates)
Re: WCD vs Standard
WCD's are known to be lighter but they aren't always lighter.
1058 PVC Pirates 2016 - xxxx
Unread 30-08-2012, 13:43
Re: WCD vs Standard
And the other implied conclusion--dead axles don't need a drop--is also an incorrect one. A 6WD, dead or live axle, without the drop will act almost exactly like a 4WD with all traction wheels (there are exceptions, like FRC25); so will an 8WD without any drop.
Unread 30-08-2012, 14:15
Garret's Avatar
Garret Garret is offline
Standing on the Shoulders of Giants
AKA: Garret Smalley
FRC #0691 (Hart District Robotics)
Garret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond reputeGarret has a reputation beyond repute
Re: WCD vs Standard
How are you getting 86" I would think that you are only eliminating 74" of railing, though I have never built a WCD so I may be off. Also I have seen plenty of plain non-cantilevered 6WD robots with direct drive on the center wheels.
However I do know that with the WCD it allows for wheels to be removed much easier because the shafts do not need to be removed.
7 Years of FRC
"You students are at the top of the mountain, at the pinnacle of success, and what is it that you do?
You become the future guides to help others climb the mountain."
Unread 30-08-2012, 18:33
UAH Class of 2019
Re: WCD vs Standard
What does 25 do? why are they an exception?
