Go to Post The jags are powered with magic... - Aren Siekmeier [more]
  #31   Spotlight this post!
Unread 29-08-2012, 18:43
AdamHeard's Avatar
Lead Mentor
Re: pic: 2012 frc971 transmission
Originally Posted by scottandme View Post
The tentative CAD design for now has us running a 6WD Franken-WCD with the two 15mm belts running inside a 2"x2"x0.125" tube. Not really ideal from a maintenance standpoint, but I'm hoping the belts will reliable enough.
I'm also fond of the divisible by 3 trick, but I think the 18T is the minimum Gates recommends for the 5mm profile, and bigger pulleys have higher load capacity. The 20T is about the biggest pulley size that fits comfortably inside the side rail tube, accounting for the center drop. The next pulley divisible by 3 is the 24T, which is too big. Setting up the 4-jaw isn't too big of a hassle, but I would probably just make a fixture plate for 8 pulleys, probe the existing bores and have the mill drill the bores to 0.5" before broaching them.
You get a little more freedom if you aren't set on running the belts internal. That would let you pick a lighter profile tubing for your frame as well.
  #32   Spotlight this post!
Unread 29-08-2012, 20:37
scottandme's Avatar
scottandme scottandme is offline
AKA: Scott Meredith
FRC #5895 (Peddie School Robotics)
scottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond reputescottandme has a reputation beyond repute
That's true, I think it'll be the pulley diameter needed that dictates that decision more than the weight gain/loss. 2x1x0.125 is 0.8085 lb/ft vs 1.036 lb/ft for 2x2x0.125, so it's only ~1.3 lbs lighter all said and done. Probably figure some weight added when you push the gearbox further inside the chassis to accommodate the ~1.25" of belt.
It's been hard to find enough detail from some CD research, but here are some I found.
1625 ran 2x1 frame with 9mm wide belt http://www.chiefdelphi.com/forums/sh...ad.php?t=86668
2791 looks like they used 2x1 with a single 9mm belt in 2011, but I think they mentioned ratcheting going full fwd to reverse. Also needs idlers to maintain proper wrap, I would rather avoid that. (http://www.chiefdelphi.com/forums/sh...ad.php?t=94701)
2791's 2012 chassis looks like 4x2 tubing with two 15mm belts. (http://www.chiefdelphi.com/forums/sh....php?t=101454). More weight, and requires >4" wheels, but solves the belt problem at least.
  #33   Spotlight this post!
Unread 29-08-2012, 21:39
Chris is me's Avatar
AKA: Pinecone
We've run a very similar setup for two years, but we used 3x1.5" tube. The extra inch lets you get a bigger pulley in the tube and a little more room for installation, which makes the drive stronger and less likely to ratchet with quick direction changes.
Our drivetrain was literally maintenance free since we first set it up in week 4. Not a thing needed to be maintained. It was wonderful.
  #34   Spotlight this post!
Unread 30-08-2012, 09:01
Brandon Holley's Avatar
I'd guess we're venturing into a thread takeover at this point...We utilized 5mm, 15mm width HTD belts with great success this year. We ran these on 24tooth pulleys.
-Brando
MORT (Team 11) '01-'05 :
NUTRONs (Team 125) '05-???
2007 Boston Regional Winners
  #35   Spotlight this post!
Unread 30-08-2012, 09:12
Brian Selle's Avatar
Brian Selle Brian Selle is offline
Brian Selle has a spectacular aura aboutBrian Selle has a spectacular aura aboutBrian Selle has a spectacular aura about
Originally Posted by kevincrispie View Post
In the back of the picture, you might be able to see that some of the wheels had gears on them. These were the center wheels that interfaced with the transmissions.
What width/size pulleys did 971 use? HTD or GT2? Are these 3.5" wheels?
  #36   Spotlight this post!
Unread 30-08-2012, 13:22
roystur44's Avatar
Mentor/Sponsor
AKA: Roy Dumlao
FRC #4543 (Apollo Robotics)
The SDP-Si catalog will drive you crazy!!!
https://sdp-si.com/eStore/..%5Css%5CPDF%5C80502171.pdf
A 6A55M024DF0910
Yes custom 3.5" wheels. The thread slips into a slot and is tie wrapped around the axle. Quick and easy to replace threads
Roy Dumlao
Mentor/Sponsor
2006-2012 971
2013-2017 4543
  #37   Spotlight this post!
Unread 30-08-2012, 13:59
Thanks! I saw how your treads worked at worlds... very nice.
  #38   Spotlight this post!
Unread 30-08-2012, 17:51
AdamHeard's Avatar
Lead Mentor
I'm really curious to know more about people's specific implementations with timing belts, please post about it in this thread;
http://www.chiefdelphi.com/forums/sh...04#post1183704
  #39   Spotlight this post!
Unread 11-09-2012, 08:15
greasemonkey's Avatar
greasemonkey greasemonkey is offline
Truss me I'm a Doctor
AKA: Fred Parker, fredword, fredwardo, phred, frederick
FRC #3467 (windham windups)
greasemonkey is an unknown quantity at this point
what is the reduction on that?
  #40   Spotlight this post!
Unread 13-11-2012, 01:11
Originally Posted by Cory View Post
Weight is an obvious reason. Pulleys are all aluminum and belt is vastly lighter than chain.
One of the main reasons was because we could then loc-tite the pulleys on to the wheel assembly easily and get a strong enough bond to not need anything else. Chain would have been a bit more of a pain to do that with.
As stated in other places, we have had good experiences with timing belt in 2010, and wanted to get rid of more chain.
We are looking at making a couple of minor tweaks to this design to make it easier to swap wheels, move the encoder to the center wheel/last reduction, and maybe make it lighter. This design served us pretty well this last year.
